Question about Lexmark Wheelwriter 15 Series II Typewriter
IBM Selectric II correcting
Can I clean and lubricate this machine myself, or do I need to pay someone to do it?
  • 328 Answers
You can use Marvel mystery oil with an small droplet oiler. Do not use spray oil or 3 in 1 oil. These will make the problem worse. But, it really should be cleaned and serviced by a qualified tech. I am in Clearwater Florida if you need me.
Posted on Jan 12, 2009
IBM Selectric II jammed
The lubricants dryp over the years. Try spraying everything with WD40 you can't hurt it.
DickyO
Feb 23, 2013 | IBM Correcting Selectric II
On my ibm selectric II, the ball element is stuck and the cap came off. How do I get the ball off the post?
Take a razor blade and slide it under the remainderof the cap cut the cap off there are 5 connections, after removing the cap you will find a spring retainer pull it off.
DickyO
Feb 01, 2013 | IBM Correcting Selectric II
My IBM Selectric II will occasionally not print letters or parts of letters. Why does it do this?
Your Selectric II (a wonderful machine) is in need of cleaning and adjustment. When I did this, I got $65.00 for the service ... that was years ago. I don't know anyone who does this work any longer though a search on Google may get you results for a shop in your area. There may be a FixYa.com advertiser who can help you. Look at the ads around this answer (that is what pays the bills, after all).
Thanks for your question @ FixYa.com
Mar 25, 2011 | IBM Office Equipment & Supplies
Ibm selectric II typewriter prints a different letter than the one typed. the typing ball appears to be very sluggish.
By this time in thier life selectrics have become very gummed up which causes many many problems, you need a chemical cleaning and lubrication. It may be cheaper to buy an IBM Wheelwriter on EBAY.
DickyO
Mar 07, 2010 | IBM Office Equipment & Supplies
IBM Selectric II Will type letters, but will
Several possible causes. Needs lubrication most commonly. Sometimes the velocity cable is hung up on the left side and under the carriage. remove the ribbon and shine a light down on the left side and look for a cable hung up on the pulley, make a hook with a paper clip and lift the cable up and past the pulley
Aug 31, 2009 | Office Equipment & Supplies
IBM Correcting Selectric II; correction ribbon frozen in front of typing ribbon.
Move the grey lever on the R. side of the carrier to the R. and remove correction tape, try the machine, if it seems to work OK install a new correction tape.
DickyO
May 28, 2009 | IBM Wheelwriter 30 Typewriter
Ibm selectric II has a sticky tab and return and exp doesn't work
It probably needs a good clean & oil best done by someone that knows the machine.
May 08, 2009 | IBM Office Equipment & Supplies
Correcting IBM Selectric II Typewritter correcton ribbon won't engage
Selectric I and II type elements are identical (88 char) where Selectric III uses a different element (96 char). The 88 character element will have white lettering and the 96 character element will have yellow. Directly underneath the lift-up tab to remove the element will be a 3-digit number. That's the last 3 digits of the element's part number, which will be preceeded by 1167 for 88 character, or 1352 or 96 character. For example, if you have a '052" stamped on the element, and it's an 88 character style, the P/N will be 1167052.
The correcting mechanism is an intricate additional function of the backspace function. To test it/adjust it/or repair it requires the machine be hand-cycled using a hand cycle wheel which is screwed into the right hand side operational shaft. It's unlikely that an un-trained party would be successful repairing this..
May 15, 2008 | IBM Wheelwriter 30 Typewriter
IBM Selectric II
Yes. From not being used in so long It needs a chemical cleaning or washout and lubrication. It may need a part or two also. Everything is gummed up. I have been repairing selectrics for 35 years. Lawrence
Apr 20, 2008 | Lexmark Wheelwriter 15 Series II...
IBM Selectric II Won't advance properly
Sounds like the carrier is hitting the paper androller as it slowly moves. If you havent used it for a while it might need cleaning and lube. Lawrence
Mar 08, 2008 | Office Equipment & Supplies
Lexmark Wheelwriter 15 Series II Typewriter Logo
121 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
