Question about Frigidaire PLCS389DC Dual Fuel (Electric and Gas) Kitchen Range
F20 error frigidaire range model PLES389ECC - Frigidaire PLCS389DC Dual Fuel (Electric and Gas) Kitchen Range
szwaan
  • 209 Answers
SOURCE: frigidaire ples389ece range
http://www.frigidaire.com/support/ResultsPage.asp?strModel=ples389ece&User=&Search=Search
That website has a manual for your Range and it should explain the F20 code.
I'm gonan look through the manual and check out what F20 means so ill be back in a bit.
Posted on Jan 20, 2008
  • 119 Answers
SOURCE: Error code F30 on a frigidaire ples389ecc oven.
THAT CODES MEANS EITHER THE PROBE SENSOR OR THE ELECTRONIC CONTROL IS BAD. UNPLUG. WITH WIRING DIAGRAM AND OHM METER, TEST THE TWO WIRES GOING TO PROBE. IF YOU GET ABOUT 1100 OHMS, YOU HAVE A BAD CONTROL. IF YOU GET 0 OR INFINITY, IT'S THE SENSOR OR THE WIRES BETWEEN THE PROBE AND THE CONTROL
BOYNISMO@YAHOO.COM OR 714-334-1998. I CAN WALK YOU THROUGH IF NEEDED
Posted on Jan 14, 2010
blueextc3221
  • 15935 Answers
SOURCE: Frigidaire Classic Range, Model # FEF366CCB, F1 error
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
^%$RF
Posted on Oct 01, 2010
taran_2005
  • 10515 Answers
SOURCE: Electric Range Frigidaire Professional Series
The last expert is correct.
According to the Frigidaire technical documentation, most likely the cause of the problem is a bad Electronic Oven Control (EOC).
Check the wire harness and the P4 connector at the EOC. If the wire harness and the connector are fine, replace the EOC
You could try to disconnect the power supply for few minutes, say 15 minutes and see, if that could help the situation unless you need to replace EOC/Clock/Control board.
I don't think it is sensor as this is a common problem on these units and 99% it is faulty EOC.
Let me know,if needed further assistance.
Note - Kindly perform the repair, if you have prior appliance repair experience. These ovens are quite dangerous to work. It could not only damage the oven but could also harm you,if done in an appropriate way.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 18, 2010
SOURCE: Problem with the Frigidaire PLES389D
Oven stays locked during cleaning cycle. then it has a preset cooling cycle which is about 2 hours. This is a long period but normal
Posted on Apr 29, 2011
Frigidaire gallery error code f9
How do I reset an F9 on Frigidaire oven? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Oct 26, 2009 - My Frigidaire oven, model feb24s5asb, door is locked and says f9. The door locked is beeping, I need code to know what the code means and how to unlock it.How do I reset an f9, door ... F-9 Error Possible causes: Door motor failure/jammed. Latch motor switch failure. ... Frigidaire Ovens Gallery 30 in.
F9 Error Code - Can't get it to stop beeping - Appliance Repair Forum
forum.appliancepartspros.com/.../400915-f9-error-code-cant-get-stop-be...
Jan 9, 2012 - 6 posts - ‎5 authors After that it flashed betwed F9 and dr and won't stop beeping. ... say that the last time I used the self clean, the dorr would not unlock and I got similar error codes. ...Frigidaire BFEF374EB1 Frigidaire Canada/electric Range Frigidaire Door Lock F9 error code and now F1
1 post
Dec 6, 2010
Frigidaire Door Lock and F9 error code
Jul 10, 2010
Frigidaire Error Code F20 - Upon Cleaning
Dec 3, 2008
Frigidaire error F-9
Feb 18, 2008
More results from forum.appliancepartspros.com
Oct 29, 2015 | Toaster Ovens
Frigidaire ples389ece range
Jan 20, 2008 | Frigidaire PLCS389DC Dual Fuel (Electric...
ERROR FF20 AND FF5
Hello Heather, this is JK. I understand that you received two error messages, F20 and F5. Typically, the F20 error indicates a communication failure between EOC and ESEC system and the F5 indicates that there is a runaway temperature. Based on the fact that you received both error messages, you may need to replace the EOC (Electronic Oven Control). Hope this helps!
Apr 19, 2014 | Frigidaire Kitchen Ranges
Electronic Relay Control
Good Afternoon C, error code F20 does indicate part replacement on the ESEC-UIB (User Interface Control), located behind the console on the side of the actual display. I would recommend, however, running a quick test to ensure that this is not a false error code. You do this by resetting your oven by flipping the breaker or unplugging the unit for approximately ten minutes. If resetting the unit does not correct the issue, please reach out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
Jul 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
F20 error code on Frigidare electric range
Hello rjshomesnj - Typically error code E20 indicates that the range has detected a communication failure between EOC (electronic oven control) and ESEC system (electronic service element control). In other words, the range has an issue with the switch for the burner. I will personally recommend contacting a certified technician to move forward accurately and to assist with the repairs. You can often locate qualified servicers by visiting the manufacturer website.
Mar 01, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Problem with the Frigidaire PLES389D Electric Kitchen Range I have a frigidaire PLES389ECC. door will not unlock after cleaning. message reads loc
Jan 22, 2011 | Frigidaire PLES389D Electric Kitchen Range
F20 error
F20 is a door lock problem. Try resetting the breaker. if the code comes back replace the door lock.
The first thing I would check is the door lock switches and the wire harness.
Here are the break down diagrams for the Frigidaire range Model PLES389ECB
Apr 21, 2010 | Frigidaire ATF6000ES Front Load Washer
Dec 26, 2009 | Frigidaire PLEF398AC Electric Kitchen...
F7 f20 error
Hi BBlackie,
Happy to help you!
Go online to www.Frigidaire .com and you can enter your model #
and download the manual.
But I think that this problem will be solved only by service!
A & E factory service is good and nation wide!
1-800-905-9505
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
Jul 25, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire PLCS389DC Dual Fuel (Electric and Gas) Kitchen Range Logo
79 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
