Wascomat washer showing error "E01" what does it mean?
Error code "E01"
5 Suggested Answers
  • 641 Answers
SOURCE: Whirlpool Duet Washer-error code "sud"
The SUD message relates to overdose of detergent detected during the Wash Cycle. This may signify a bad pump, an extra heavy load, excessive detergent or excessive suds. If too much detergent was used, run the washer through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent. Check the drain hose and make sure it is not plugged or kinked. Good luck
Posted on Sep 06, 2007
SOURCE: what does error code 6P mean on an Amana washer model LW9203W2B
SH: Open thermistor. Unplug appliance and let rest for 15-30 minutes, then plug back in. If code continues, unplug appliance and call for service.
bP: Pressure switch error sensed. Washer will not operate when this error is displayed. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
rP: Water supply problem in spin cycle. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
LO: Lock Out mode. To activate, press START and STOP/OFF pads at the same time. To deactivate, repeat the procedure.
AU: Flashes when a factory preset cycle is put on hold. A normal function.
Clean Filter: Flashes when a cycle is selected as a reminder to clean the filter before starting a cycle for optimum drying results. Code clears when the door is closed and the START pad is pressed.
Posted on Sep 01, 2010
blueextc3221
  • 15935 Answers
SOURCE: What does error code ob mean on a Whirlpool
The OB indicates and out of balance condition has been detected by the motor control. You say this happens when the washer is empty also. One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*@^%
Posted on Sep 21, 2010
SOURCE: what is meaning of error motor shortening in wascomat washer
change the inverter
Posted on Jan 22, 2011
How to start a diagnosis test on Bosch dishwasher model SHE3ARF6UC/21 will not start because of E01 code
Error code E01 means that your Bosch dishwasher is experiencing trouble with the motor.
Feb 19, 2018 | Bosch Washing Machines
I have an ninja 4 in 1 cooker. it comes up with an eo1 message. what can i do?
  1. The thermostat may temporarily lose calibration due to temperature changes resulting in an E01 error message on the display. Repeat the following steps to reset the unit.
  2. 1. Unplug the unit from the wall socket for approximately 10 seconds.
  3. 2. Plug the unit back into the wall socket.
  4. 3. Press the POWER button once. Within one second, press the COOK button once. The unit should now be reset
or Cooking pot is not inside the cooking system housing. Insert the cooking pot.
Search Results
SOLVED: When I turn it on I get E01 - Fixya
www.fixya.com/support/t305866-when_turn_get_e01 Dec 19, 2007 - When I turn it on I get E01 When I turn on power it is giving me E01. ... I had the same E01 error code. .... How to fix on a ninja crockpot e01. According to the manual it means the cooking pot is not inserted into the device.
ninja cooking system e01 error Questions & Answers (with Pictures ...
www.fixya.com > Forum > Tags Find solutions to your ninja cooking system e01 error question. ... ...fix error code eo1 and err i getting an error code eo1 and err and it not cooking For one, you ...
SOLVED: How to fix on a ninja crockpot e01 - Fixya
www.fixya.com/support/t17203774-fix_ninja_crockpot_e01 Mar 19, 2013 - how to fix on a ninja crockpot e01 - NINJA SEARious Slow Cooker question. ... According to the manual it means the cooking pot is not inside of the device. Same thing happened to ours .... you can use it. Here is a tip that will tell you how to fix the EO1 error code. ... ninja cooking system e01 e01. Feb 07 ...
Ninja cooking system e01 - Fixya
www.fixya.com/support/t23385060-ninja_cooking_system_e01 Feb 7, 2014 - ninja cooking system e01 e01 - NINJA SEARious Slow Cooker ... I have an E01 error code on my West Bend slow cooker, how do I fix it?
[PDF]3-in-1 Cooking System - The Home Depot
www.homedepot.com/catalog/.../3f/3f5a04f4-303f-482a-a702-eeb5ecab0bdb.pdf In the event of a loss of power, an error .... The Ninja® 3-in-1 Cooking System Steam Oven offers a revolutionary new way to cook your .... "E01" Appears on the.
ninja 4 in 1 cooker eo1 error - Google Search
Apr 02, 2017 | Kitchen Appliances - Others
Dryer shows error 8-overheating in or out air. I run thru the reset sequence but it continues to show the error code.
Your thermocouple is reading high, which could be a multitude of factors. We'll go through them from easy to hard:
First, check your dryer vents and make sure they are clean and that you have proper air flow coming in and out of the dryer.
Next, make sure that your motors in your dryer aren't running too hard (check for how easy it is to rotate the drum and the fans when the dryer is off).
If you're still facing problems, try cleaning your heating element, and finally replace the temperature sensor. If none of those things work, you're facing an internal computer issue which isn't likely user serviceable.
Nov 02, 2015 | Wascomat Parts Wascomat 986918 Washer...
What do error codes e06 and e01 mean?
E01 and e06 codes - Fixya
www.fixya.com/support/t14040885-e01_e06_codes
Aug 19, 2012 - e01 and e06 codes washer will not do anything other than lock the door. - Whirlpool Duet: WFW94HEXW Laundry : question. ... Error message E06 onWhirlpool. Unplug the machine and wait 10 minutes before restarting it.
Aug 24, 2015 | Maytag Washing Machines
Washer error F06 E01
The error codes F6 E1 for Maytag Maxima 6000 front load washer means that the MCU AND CCU are not communicating. You need to check the wiring and plugs to make sure they have a good connection.
Feb 10, 2015 | Maytag Washing Machines
Wascomat w655s what is error code E13 ?
www.teetersproducts.com/.../Used%20Equipment/.../Wascomat%20-%20...
Jul 13, 2014 | Wascomat Parts Wascomat 973957 Washer...
Bosch vision error code E01 on washer
error code e01 means the computer thinks the door is open even when it's closed you can repair this using this guide:
Bosch Front Load Washer Error E01
Aug 23, 2013 | Bosch WFVC5440UC Washer
Bosch Nexxt Washer Error Code E01
means that the computer is seeing the door as opened even though it may be closed, you can fix this by following this guide:
Dec 01, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
Got carl lewis treadmill MOT566 IT SHOWING ERROR CODE E01 WHAT DOES THIS MEAN
1) this means a) problem with the speed sensor b) main motor problem c) main motor board faulty. see the block diagram attached.
God bless you
Jun 24, 2012 | Exercise & Fitness
Washing Machines Logo
122 people viewed this question
Top Washing Machines Experts
