Question about Cuisinart CSB-33 Quick Prep Handheld Blender
Missing blade on cuisinart csb-1 quick prep - Cuisinart CSB-33 Quick Prep Handheld Blender
2 Suggested Answers
  • 16 Answers
SOURCE: Cuisinart Quick Prep is not working properly
I think the ice was too hard for a hand blender. I think the impact has caused the blade to separate from the shaft or caused the shaft to separate internally. If your blender is still under warranty you might be able to get it fixed. Note: none of the "Smoothy" recipes in the manual call for ice. One uses ice-cream. One uses "partially thawed frozen strawberries" and one uses sherbet.
Posted on Oct 11, 2009
Why does water leak out when filled passed the top of blade
About 11,000 results (0.81 seconds) Search Results
    [PDF]Instruction Booklet Premier™ 11-Cup Series - Cuisinart
    https://www.cuisinart.com/share/pdf/manuals/dlc-2011.pdf
    Cuisinart11 cups (total processed weight varies by food) ... PowerPrep® metal dough blade, metal ... bowl at the top with ... filled out. WHEN. REMOVING BLADE: CAREFULLY REMOVE. THE METAL BLADE BY .... (If machine does not ... not put base in water or... These features, plus the .... have passed into the ... food from leaking.
    [PDF]Download Manual - Cuisinart
    https://www.cuisinart.com/share/pdf/manuals/dlc-10s.pdf
    Cuisinartmatching outline O on top of .... base in water or other liquid. General ... does not fit fully in the outlet, ... as you would sharp knives, out of ... 11. KNEADING YEAST DOUGH WITH DOUGH BLADE. 12. KNEADING BREAD DOUGH ... loodfrom leaking...... uid onto dough as it passes under ..... Fill the feed tube wilh the pieces,.
    [PDF]Food Processor - Cuisinart
    https://www.cuisinart.com/share/pdf/manuals/dlc-xp.pdf
    Cuisinart
Feb 08, 2016 | Cuisinart Prep 11 Plus Dlc2011chb Food...
How to put motor and blade sections back together?
There are two phillip head screws holding the blender end together where it came apart. They are hidden under plugs on either side of the imprinted information. Simply drill a hole in each plug and remove them by putting something in the hole (small screwdriver) and pulling them out. Loosen the screws, enough to pull the body apart far enough to insert the blender end back in. Tighten the screws back up and your good to go. I left the plugs out, they don,t serve any purpose.
May 16, 2013 | Cuisinart CSB-33 Quick Prep Handheld...
My model csb 77 hit a bone and a plastic part in the motor assembly broke. Can I get it repaired? Can I take it apart and do it myself? Pete
No solution acording to the company. They do not sale this part..You'll have to buy the whole motor for 25$. I think they do that part on purpose to make you buy more. I have the same problem.
Jun 15, 2011 | Cuisinart CSB-77 SmartStick Blender
Quick Prep fell and popped into two pieces. I have the key match for the two haves but am unable to get the slots from the mixer end to slide into then male ends on the base end. Is there a way to...
There are two phillip head screws holding the blender end together where it came apart. They are hidden under plugs on either side of the imprinted information. Simply drill a hole in each plug and remove them by putting something in the hole (small screwdriver) and pulling them out. Loosen the screws, enough to pull the body apart far enough to insert the blender end back in. Make sure you line up the drive pieces and the logo goes on the side with the switch.Tighten the screws back up and your good to go. I left the plugs out, they don,t serve any purpose.
Nov 29, 2010 | Cuisinart CSB-33 Quick Prep Handheld...
Blades not turning, motor spurtering
I would say that these high speed motors are prone to wearing out their brushes quite quickly, but are not really designed to come apart.
I suppose it is their mode of failure.
If you can find spare brushes for the motor, then do, but the unit is likely to be clipped and solvent welded together, so may be cracked during repair.
Feb 20, 2010 | Cuisinart CSB-77 SmartStick Blender
Oct 11, 2009 | Cuisinart CSB-33 Quick Prep Handheld...
The handheld blender makes a horrible screeching noise all the time. I don't see anywhere to lubricate it or even take it apart. What's a person to do?
Time to use your warranty or throw it out. Not a serviceable product, you can't order a set of bearings for this. sorry
Aug 06, 2009 | Cuisinart CSB-33 Quick Prep Handheld...
Cuisinart CSB-33 Quick Prep Handheld Blender Logo
104 people viewed this question
Top Cuisinart Blenders Experts
eyecam
ray gallant
richie46
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
