Question about Microsoft Windows XP Professional
Inserting an object in MS applications
Whenever, I try to insert object from file in Excel or Word; what I got are icons from Word or Excel. I'm not finding others like jpg or even Acrobat. Only somekind of a package.exe icon is present and it is not working.
  • 7 more comments
  • ymtong Jan 12, 2009
    I'm using Microsoft Office 2003.
    I'm using Microsoft Office 2003 with Windows XP Professional. Having problems with inserting objects from file in MS applications..only icons like Excel, Word turns up. I can't find jpg., pdf., and other icons. There is this package.exe thing which does not help....where have all the icons/associations gone?
    I'm not working on inserting WordArt....this does not help me...
  • ymtong Jan 13, 2009
    I wish to repost this problem and if someone could offer a solution?
    Inserting an object from file (the other one is create new) in a normal MS application like Excel or Word. The object(which is a file) will appear with its associated icon on the Excel worksheet or Word Document.
    When I try to insert object from file; browse for file to insert; then click display icons(only icons associated with MS applications appear) not jpg or even pdf...it jus appears as package.exe...which does not work...
  • ymtong Jan 14, 2009
    I'm not trying to insert a picture. I just want to insert an object...create from file...display as icon.
    I'm here having a pdf file; but clicking display icon; does not bring out anything apart from teh package.exe thing.
  • ymtong Jan 15, 2009
    Had provided additional info. and screen shots. Not sure if any help can come along quick?
    OK..I will try..just saw the proposed solution...
    Will it work without uninstalling the Microsoft Office 2003 applications?
  • 238 Answers
Create a new embedded object
  1. Click in the document where you want to place the embedded object.
  2. On the Insert menu, click Object, and then click the Create New tab.
  3. In the Object type box, click the type of object you want to create. Only programs that are installed on your computer and that support linked objects and embedded objects appear in the Object type box.
  4. To display the embedded object as an icon — for example, if you want to minimize the amount of space the object uses in the document — select the Display as icon check box.
Note You can also insert a Microsoft Excel worksheet as an embedded object by clicking Insert Microsoft Excel Worksheet on the Standard toolbar.
Create a linked object or embedded object with existing information
=From a Microsoft Excel file
  1. Open both the Microsoft Word document and the Microsoft Excel worksheet that contains the data you want to create a linked object or embedded object from.
  2. Switch to Microsoft Excel, and then select the entire worksheet, a range of cells, or the chart you want.
  3. Click Copy .
  4. Switch to the Word document, and then click where you want the information to appear.
  5. On the Edit menu, click Paste Special.
  6. To link or embed the object, do one of the following:
  • To create a linked object, click Paste link.
  • To create an embedded object, click Paste.
     7.  In the As box, click the entry with the word "object" in its name. For example, click Microsoft Excel Worksheet Object
Note If you link data from a worksheet and select the Keep Source Formatting and Link to Excel option, the linked data will match the formatting in the Excel source file. If you select the Match Destination Table Style and Link to Excel option, the linked data will be formatted in the Word default table style.
With either option you can change the formatting of the linked object in the Word document. Formatting changes you make will remain when the data is updated in the source file.
=From other program files
  1. Open the file that contains the information you want to create a linked object or embedded object from, and then select the information.
  2. Click Copy .
  3. Switch to the Microsoft Word document, and then click where you want the information to appear.
  4. On the Edit menu, click Paste Special.
  5. To link or embed the object, do one of the following:
     6.  In the As box, click the entry with the word "object" in its name. For example, click Microsoft Word Document Object
=From an entire file
  1. Click in the document where you want to place the linked object or embedded object.
  2. On the Insert menu, click Object.
  3. Click Create from file.
  4. In the File box, type the name of the file you want to create a linked object or embedded object from, or click Browse to select from a list.
  5. To create a linked object, select the Link to file check box.
An embedded object is created if you don't select the Link to file check box.
     6.  To display the linked object or embedded object as an icon — for example, if you want to minimize the amount of space the object uses in the document — select the Display as icon check box.
Note When you create an embedded object from information in an existing Microsoft Excel workbook, the entire workbook is inserted into your document. The document displays only one worksheet at a time. To display a different worksheet, double-click the Microsoft Excel object, and then click a different worksheet.
*I hope I fixed your problem.
Posted on Jan 15, 2009
    President:
  • 846 Answers
First off I would uninstall Microsoft Office, then scan with anti-virus (such as AVG)CLICK HERE
and anti-spyware like Adware CLICK HERE
Run a registry repair program if you have one if not here's a free one
http://www.download.com/Wise-Registry-Cleaner-3-Free/3000-2086_4-10605508.html
Reboot~ then install Office again, open Word and try again that should fix your problem, if not then repost with any new info and well try to fix any problems that may remain.
Thank you for stopping by Fixya!
Posted on Jan 13, 2009
  • 1 more comment
  • Quickfx PC Repair Jan 13, 2009
    Ignore my first post after reading your latest comment I understand better, ill post back with a new solution in a moment.
    Ok heres the problem, when you choose to insert an object from file (for instance I choose a hotfix for windows) it asked me on the object screen some choices (tic boxes that you can select)
    Link to file - Click Yes
    Display as icon- Click yes
    Now you can only display as an icon that Microsoft has in its files, there is a change display button that appears after you have clicked Display as icon. Click there and you can change to icon you want, now when you want to use contents you RIGHT CLICK the Icon, select PACKAGE OBJECT-ACTIVATE CONTENTS
  • Quickfx PC Repair Jan 18, 2009
    well in trying to insert an object it will insert an icon along with it, has to. It apperently sets the default to package.exe and that icon seems to be your only choice. But I tried inserting an object on 2003 and 2007 it did the same thing but worked just fine when i saved the document and opened it again. Object opened up just fine for me.
    Genius:
  • 1,605 Answers
You need the original Microsoft Office 2003 CD.
install the additional tools from the CD.
in order to do that, I suggest that you unistall the office from the control panel>>ad and remove programs.
install the Office from the CD, select custom and select all subcategories program.
the insert object is uder the format and tools. on the CD.
  • Microsoft Master
  • 19,396 Answers
I will try to answer:
"I'm using Microsoft Office 2003 with Windows XP Professional. Having problems with inserting objects from file in MS applications.."
A: You can insert objects using the Insert menu on Top bar in MS Office application.
You can insert only certain file types. Using the 'Insert File' command however will insert only file Icon and and link to file.
"only icons like Excel, Word turns up. I can't find jpg., pdf., and other icons."
A: If you open the dropdown menu under insert and press the downarrows to expand dropdown menu, you will see that you have more options in there.
To insert a picture use insert picture.
You cannot merge part of a PDF file , or even a different text file, on an Office document just doing insert.
You need to open the other document and do copy and paste.
  • 158 Answers
U mean to say that you are inserting objects?
  • Prashant Bharadwaj
    Prashant Bharadwaj Jan 13, 2009
    Re-installing Office all over again can fix this
    Brigadier General:
  • 8,619 Answers
Hi!
Did you recently installed any kind of software or program or downloaded any kind of file from web?
Seems to be trojan or virus that has deleted your system files. Scan your system with a good antivirus.
And to solve this problem restore your system to a previous date(when your system was last working fine). You can do it from start menu->programs->accesories->system tools->system restore.
Ask for clarification.
Thanks
Rylee
Posted on Jan 12, 2009
  • Rylee Smith
    Rylee Smith Jan 12, 2009
    Note that after you restore your system your data after that date would get deleted.
  • Rylee Smith
    Also if you want your files to open right after restore then reinstall MS Office
  • 10,515 Answers
Read the article from microsoft :)
http://support.microsoft.com/kb/312802
Thanks.
    Genius:
  • 1,550 Answers
Are you using latest microsoft office ?
  • SAM ANDERSON Jan 12, 2009
    Hope this link helps you
    http://support.microsoft.com/kb/285820
Excel Corruption files
Without seeing the file, it is difficult to diagnose what is going on, but I will offer some ideas.
What version of Excel are you using? Are you using Excel 2003? Was the file you are trying to open created in Excel 2007 or Excel 2010. If so, it might be using the new format and therefore will not open in Excel 2003 and older.
It is possible the Excel file is data that was imported from a source in which Excel cannot import. Does the Excel spreadsheet contain any imported data?
Try to use: XLSX Viewer Tool here : http://www.xlsx.viewertool.com/
Those are the most likely causes of the corrupt data. Is every file you open in Excel corrupt, or just this one workbook? If it is just this one workbook, then, yes, it sounds like it is corrupted. If every file you open with Excel is corrupt, then your version of Excel could be corrupt, but that is unlikely.
Jul 10, 2015 | Microsoft Excel for PC
Excel workbook error
I came across this issue today. An update to the Office Compatibility Pack that was still on a computer caused the default PROGRAM for .docx and .xlsx files to be the Microsoft Open XML Converter program and make the "Default Programs" in Control Panel think that Excel and Word were actually the Microsoft Open XML Converter scholarship essay writing assistance program as well.UNINSTALLING the Office Compatibility Pack in Programs and Features and then a simple reboot fixed the issue.
Also:
1: Try to repair it manually when MS Excel does not automatically STARTS File recovery mode.
Click the Microsoft Office Button, and then click OPEN.
Now select the corrupted workbook that you want to open.
Click the arrow NEXT to the Open button, and then click Open and Repair.
Choose either Repair (to recover as much of the FILE data) or Extract data (to extract values and formula when repair process is not successful).
2: Open with Open Office: Try to open your Excel file in Open Office. It is an open-source Office suite that is able to open & SAVE Microsoft Excel files.
3: Save in HTML Format: Open your Excel file and save it in HTML format. By saving the workbook in HTML format, you may be able to filter out the corrupted elements.
4: Save in SYLK Format: Open your Excel file and save it in SYLK format. By saving the workbook in SYLK format, you may be able to filter out the corrupted elements.
5: Try 3rd party software like Excel Repair Toolbox
link: https://www.repairtoolbox.com/excelrepair.html
Jun 18, 2015 | Microsoft Office Excel 2007
Excel 2007 document recovery repeating document on Terminal Server
MS Excel File can get corrupted due to virus attack, missing MS office files, power failure and other possible reason that can be fixed by only use Stellar Phoenix Excel Recovery fix corrupt Excel (.XLS/.XLSX) files and restore everything (including charts, chartsheets, cell comments, worksheet properties etc.
Jan 04, 2015 | Microsoft Excel for PC
While installing 'Microsoft Office 2007 Enterprise'..... the problem is that half-way through, there is this annoying message, everytime !!!!!!!!!!.... : "Error 25004. Config.Xml not specified. A...
it seems there is a problem with the installation file itself. if you have downloaded it from the internet then please look for a different file as this one may be corrupt or if you have purchased an original version, please contact microsoft help-care.
hope it works.
Feb 18, 2011 | Computers & Internet
Ms execl is not opening in my laptop
just reinstall the application if it is original software or when it is pirated just download another one by torrents or any other method
first of all backup your excel type files
Mar 02, 2009 | Microsoft Office Excel 2003 for PC
Not able to access MS office
http://support.microsoft.com/kb/933347
Here is what you need. Just click the Link Above. Please Rate My Response! Thanks!
PREM
Feb 28, 2009 | Microsoft Office Professional 2007 Full...
EXCEL security
I think your confuse on the terminology.
MS OFFICE = MS word, excel, access.......
There won't be any icons, but if you go to all programs, there will be a folder called "MS Offfice".
May 20, 2008 | Toshiba Satellite A135-S4527 Notebook
Create a MS Word Report
This from the Word Help files - search for Embed.
You can simply select an area in Excel copy it and paste it into your word document, but embedding allows the data in your Word document to be automatically updated as you change the figures in the Excel Worksheet.
From the Help pages:
You can insert objects (object: A table, chart, graphic, equation, or other form of information. Objects created in one application, for example spreadsheets, and linked or embedded in another application are OLE objects.) into a Microsoft Word document when you want to include information from files created in other Microsoft Office programs or in any program that supports linked objects (linked object: An object that is created in a source file and inserted into a destination file, while maintaining a connection between the two files. The linked object in the destination file can be updated when the source file is updated.) and embedded objects (embedded object: Information (object) contained in a source file and inserted into a destination file. Once embedded, the object becomes part of the destination file. Changes you make to the embedded object are reflected in the destination file.).
default.aspx?assetid=za060473201033 default.aspx?assetid=za060474651033 Embedded object
default.aspx?assetid=za060474661033 Linked object
default.aspx?assetid=za060474671033 Source file
For example, a monthly status report might contain information that is separately maintained in a Microsoft Excel worksheet. If you link (link: Used to insert a copy of information created in one program into a Microsoft Word document while maintaining a connection between the two files. When the information changes in the source file, the changes are reflected in the destination document.) the report to the worksheet, the data in the report can be updated whenever the source file (source file: The file that contains information that was used to create a linked or embedded object. When you update the information in the source file, you can also update the linked object in the destination file.) is updated. If you embed (embed: To insert information created in one program, such as a chart or an equation, into another program. After the object is embedded, the information becomes part of the document. Any changes you make to the object are reflected in the document.) the worksheet in the report, your report, or destination file (destination file: The file that a linked or embedded object is inserted into. The source file contains the information that is used to create the object. When you change information in a destination file, the information is not updated in the source file.), contains a static copy of the data.
default.aspx?assetid=za790050001033The differences between linked objects and embedded objects
The main differences between linked objects and embedded objects are where the data is stored and how you update the data after you place it in the destination file.
Linked objects When an object is linked, information is updated only if the source file is modified. Linked data is stored in the source file. The destination file stores only the location of the source file, and it displays a representation of the linked data. Use linked objects if file size is a consideration.
Linking is also useful when you want to include information that is maintained independently, such as data collected by a different department, and when you need to keep that information up-to-date in a Word document.
When you link to an Excel object, you can use the text and number formatting from Excel, or you can apply the formats supplied by Word. If you use the Word formats, you can preserve formatting when the data is updated. For example, you can change table layout, font size, and font color without losing those changes once the object in the source file is updated.
Embedded objects When you embed an object, information in the destination file doesn't change if you modify the source file. Embedded objects become part of the destination file and, once inserted, are no longer part of the source file.
Because the information is totally contained in one Word document, embedding is useful when you want to distribute an online version of your document to people who don't have access to independently maintained worksheets.
default.aspx?assetid=za790050001033Edit and update linked objects
To edit a linked object in your document, use the Links command on the Edit menu.
By default, linked objects update automatically. This means that Word updates the linked information every time you open the destination file or any time the source file changes when the destination file is open.
If you prefer, you can change a linked object's setting so that the linked object is updated only when you choose to manually update it.
To ensure that your document is always up-to-date, you can also update linked objects whenever you print the document.
To prevent updates, you can lock individual linked objects. When you lock a link, Word uses the last information available from the source file.
You can also permanently break the connection between a linked object and its source file.
default.aspx?assetid=za790050001033Edit embedded objects
To edit an embedded object, double-click it, and then make changes to it in the source program (source program: The program used to create a linked object or embedded object. To edit the object, you must have the source program installed on your computer.). If you don't have the source program, you can convert the embedded object to the file format of a program you do have.
Apr 13, 2008 | Microsoft Office Professional 2007 Full...
MS Access and ASP.net application
You probably need to be inserting the value of a text object (ie, a String) , not the object itself. In VB.NET, a String object is an actual, not unlike a Java String object. In "classic" VB, a String object isn't really handled by the interpreter as an object in the C# / Java sense, so it can be referred to directly without resolving the value via a method call. So attempting to insert an object reference into a database field from C# code will probably not work unless the database knows to call toSting() on the object, which I am 99.99999% sure it cannot (depends on the database-- in this case Access, and more particularly, what version you are using, and if there is any .NET framework interoperability).
Calling myString.toString() though returns a String object in C#, so using that is likely not going to work. What you may need to do is return a character array using the 'chars' and 'length' properties of the C# String object.
Finally, after all this, your problem could be a lot simpler: the value(s) you are trying to insert may not be right for the field-- check the length of the values being inserted, etc. Use .trim() to eliminate leading and trailing whitespace, for example. If you post your INSERT statement and an example of the data you are using, I may be able to tell you more. Also, you are in ASP.NET and data transfer from web containers to Access databases is notoriously bedeviled work.
Mar 07, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
296 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
