Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
How do i reset the paper selection on my HP officejet 8500
I'm using Avery 5162 labels but they are misaligned when I print them. Avery tells me I need to reset the paper selection on my printer to Photo Paper Matte or labels. How do I do this?
SOURCE: Just trying to print 2181 Avery Laser Labels - "Paper Size or type is incorrect"
I have had this same problem trying to print DVD lable sheets.
I spent hours trying to work it out, HP support said it was the software(hmmm)
The answer to the problem is, the printer senses the printed block colour band on the preprinted lable sheet. I am using Fellowes - Neato DVD tempate sheets which have a black, block of colour on the leading edge, I'm not sure about Avery.
I found the quick fix is, turn the sheet around end for end against the manufacturers instructions. The opposite end is plain and goes through OK. You may have to calibrate the software to compensate if the printing starts in a different position this end, my sheets are the same within about 1mm.
You could also cut the block colour off the sheet if the direction was critical, and make allowance for the starting position.
I find the printer is good apart from this problem.
I hope this helps, it worked for me.
Regards, Rob.
Posted on Mar 17, 2008
  • 105 Answers
SOURCE: printing to 4 x 6 paper
Hello oyam26,
For any paper mismatch issue, first thing you do is try to set the paper type to plain. This will fix the issue in most of the cases.
gud luck
Posted on Nov 05, 2008
nalin_elliot
  • 224 Answers
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. CauseAny of the following issues can cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
Posted on Oct 03, 2009
SOURCE: I want to print a photo using the photo paper
I had to adjust the advanced print settings on my computer.
SOURCE: The Hp officejet 6310 all-in-one will print
problem fix
Posted on Jan 04, 2010
Printing avery labels
You need to check the driver settings inthe printer properties and make sure that you are selecting labels as the paper stock. Often times this will adjust the fusing temperature so the toner is melted thoroughly on the label. You may also check the toner..some compatible brand toners do not do well on Avery labels.
Mar 27, 2013 | HEWLETT-PACKARD CP1025 Laser Printer
Printer will not print onto Avery Clear Label paper
click START.,go to PRINTERS N FAXES n click it.,the window with list of printers on ur pc will open.selest ur printer icon n rightclick it.then click the PROPERTIES option.then click PRINTING PREFERENCES,u will find a PAPER SETUP or PAPER option.click it n select the type of paper as per ur requirement.apply the settings n carry on printing hassle free.thanks.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Jun 27, 2008 | HP Photosmart 2610 All-In-One InkJet...
Kodak printer will not print on avery label paper. Have been on teck support with anurag s for about an hour and tried again to print labels.
Hi , i have been using avery templates and label paper at work for ages and always printed off without problems on my lexmark . I bought a Kodak however and all of a sudden I could no longer print off my labels , when I put paper in it just came out blank and said paper wrong size .I could not find any solutions at all and was tearing my hair out . I just kept trying different things and all of a sudden I changed a setting and it worked perfectly.When you go to print your label change the ' scale to paper size ' function to A4 and then it will print.
hope this helps
Feb 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I am trying to print labels and the printer command says manual feed insert paper. What do I have to do?
1. Pull up a blank Microsoft Word Document.
2. Select "Tools" under the toolbar feature. Slide the cursor down to Letters and Mailing. Slide it to the Right and down. Select "Envelopes/Labels."
3. A box will open up. Make sure that the "labels" tab at the top is selected. The default is "envelope", so you must click on the "labels" tab.
4. Below that, you will see a "print" box. If you want a full page of labels (excellent for Christmas lists, etc.), make sure the "Full Page of Same Label" radio button is selected. If you only want to do one label, make sure the "Single Label" radio button is selected.
5. Off to the right side, you will see the word "Option." Press on that. Locate your label. Whatever labels you are using should have their classification number listed on the bottom left corner of the outside of the box. They tend to be 4 digits (ie. 5162 is the number for Avery White Mailing Labels.)
6. Once you have located your number on the box, find the corresponding number under the "Options Tab." Highlight it. Press Okay.
7. You will see "New Document" in the upper right hand corner. Press that.
Presto! You can now fill in an entire box of labels and send out very classy looking envelopes!
Feb 08, 2011 | Brother Office Equipment & Supplies
Problem with printing from Tray 1
It can be set from more then one place. In MS Word you would go into the tools setting then choose the envelope drop down, select labels and in the options for the label you choose the format as an Avery Equivalent. That is where you can tell MS Word which tray to pull from. Also in the printer properties, under advanced options you can designate what type of paper is in each tray. Good Luck
Jul 23, 2009 | HP LaserJet 4600dn Color Printer
How do i print labels using epson r2400 photo printer?
If you are using the Avery template, make sure you change the page setup settings from Manual Front (default) to Default Tray (sheet). Then when it tries to fix the layout, select ignore (on Wrd 2007 anyway). Then select Photo / Glossy paper and hopefully away you go.
Mar 31, 2009 | Epson Stylus Photo R2400 InkJet Printer
Label printing (stick on labels)
Very easy. Follow this link...
http://www.avery.com/avery/en_us/Templates-&-Software
you can download the free Avery software. Buy whichever labels you want. Then using this software you just put in the item # (the number on the pack of labels you buy) This software will work for any size label they make, and it will let you design & print them. I have the same printer & use the Avery Design Pro for labels.
If you find this helpful plz rate it 'fixya' for me. Thank you kindly.
Feb 10, 2009 | Canon MP610 Photo All-In-One Printer
Printer labels do not line up with document as typed in Word using the Avery set label size. I type labels for Christmas cards. Previous years have had no trouble at all on other printers but now top of...
The only way I could get round it was to type one page of the labels, then print on plain paper. Check with label size then go back to screen and individually change the labels that were misaligned. Then when I printed on to a label page it was correct. Time consuming but at least I didn't waste any labels that way, only paper.
Nov 21, 2008 | Office Equipment & Supplies
Problems with avery mac label expert
To reset the size in your printer to the correct A4 size, do this:
Go to your Applications folder on your hard drive.
In it, you will find a Utilities folder.
Inside that folder, you will find a folder called "Printer Setup Utility."
Inside THAT folder, you will find a list of printers you have connected to your Mac.
Click on one. You will see, at the top of your screen, a set of menus. Click on the "Printer Setup Utility" menu at the far left.
Choose "Preferences" from the drop-down list.
You will see a dialog box with three options: Printing, Sharing, and Faxing. If Printing is not automatically displayed, click on the Printing tab.
At the bottom of the Printing dialog box, you will see another pull-down menu: "Default paper size in page setup"
Choose A4, or whatever size you wish.
Close up all the boxes, and print your labels to your heart's content.
When you're done with your labels, don't forget to repeat this process to switch your printer back to your ordinary size paper.
Hope this helps.
-lizwb
Apr 18, 2008 | Computers & Internet
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
