Question about Onkyo TX-SV525 Receiver
Bose Acoustimass Subwoofer not working; front/center are working
All Bose Acoustimass satelites are powered from Acoustimass with powered subwoofer. Subwoofer worked initially. I unplugged speaker wires and plugged them back in inside of cabinet and the subwoofer didn't work.
  • Scott Patchett Jun 15, 2007
    I received email from fixya (do not reply) soliticing guaranteed solution. I paid for this service through paypal and have not had any contact or activity on this problem in 5 days - the issue has not been resolved.
    Thanks
    Scott
    New Friend:
I have Bose Acoustimass 6 with Pioneer amplifier.
When i connect the audio device, the woofer, front speakers with center speaker is working fine but the rear end audio output is not responding.
Can you please help me with resolving issue.
Posted on Jun 11, 2016
  • 97 Answers
From the speaker output from your amp, connect left and right to the sub box. Turn on amp and try to play some music. If the sub is working, turn amp off and connect the satellite speakers and turn amp on. Make sure amp is on speaker "A" and the lines are coming from the same connectors on the rear of amp. Check your amp with another speaker to make sure it is working if you have no output. Does the Bose box have its own power cord (self-powered)? If it is self-powered, the internal amp might have tripped or is not working. If unit is not powered, the crossover or thermal protection could be damaged. Refer to Bose for parts.
Posted on Jun 22, 2007
    Genius:
  • 1,074 Answers
Check your wires and the woofer they might be defected.components can be working one min and the other minute when you try to put them on they dont function.the out put signal for your accoustimass should also be checked.this can be done by a qualified tech.good luck my friend.hope that this solution will solve your problem.
Posted on Jun 19, 2007
    President:
  • 3,130 Answers
Ok, have you tryed to unplug all of the wires from the sub, including the power wire from the wall. Install of the speaker wires to the sub, and plug back in the sub. Also what are the numbers on the speakers and the sub.
Posted on Jun 18, 2007
How do I replace a speaker on my Bose Acoustimass 10 subwoofer?
The speaker probably needs not be replaced, only reconed or reconditioned. I would look into simplyspeakers.com or similar to get it done and then do the remounting yourself.
Nov 15, 2014 | Bose Audio Players & Recorders
Bose subwoofer has no power when pluged in
Make sure your power outlet and your audio source are ok. If they are then the subwoofer's power supply is probably dead.
Oct 17, 2012 | Bose Acoustimass 5 III System
Bose acoustimass series 5 subwoofer doesn't work
I guess it is powered.If so,check the fuse,then transformer.If these are Ok,then there's probably a fault in the power circuit.
Sep 29, 2012 | Bose Stereo Subwoofer Speaker Acoustimass...
Unable to receive optimum output. The bass is totally flat !
Hi, ok the Bose Acoustimass III system consists of two small cube speakers and one subwoofer unit called the Acoustimass bass module. If the subwoofer stops working, three points can be the cause of the failure. The Bose Acoustimass III is a passive system, meaning the speakers do not power themselves, but instead are connected to a receiver or amplifier. Thus, the amplifier, the speaker between the amplifier and the subwoofer, or the subwoofer itself could be the issue.
Things You'll Need:
* Amplifier
* Speaker cable
* Extra subwoofer
Instructions
Disconnect the speaker cable from the back of the Bose Accoustimass bass module and connect it to a subwoofer that is known to be working. If the subwoofer works, the bass module needs to be replaced.
Disconnect the speaker cable from the back of the receiver or amplifier you are using and from the back of the subwoofer in Step 1.
Connect a speaker cable that is known to be working between the back of the receiver or amplifier and the back of the Accoustimass module. If the module starts working, then the cable was the issue.
Disconnect the speaker cable from Step 3 from the back of the amplifier or receiver, then connect the cable to the subwoofer port on the back of an amplifier or receiver that is known to be working. If the subwoofer works, the receiver was the issue. If the subwoofer still does not work, verify that the speaker cable is in the subwoofer port of the receiver/amplifier and that the cable is connected securely to the subwoofer.
If you think you did the connection properly,Fine... If not you can use the manual from the below link and know how to connect it properly..
products.bose.com/pdf/customer_service/owners/og_am5iii.pdf
Have a nice day..
Feb 19, 2011 | Bose Acoustimass 5 III System
Is the subwoofer from the Bose acoustimass 10 series IV Home Entertainment Speaker System a power sub?
The entire speaker system is passive. That is, it requires amplification for each channel.
From the manual: "Compatible with A/V receivers rated from 10 to 200 watts per front channel and 10 to 100 watts per rear channel; rated from 4 to 8 ohms".
Dec 09, 2010 | Bose Acoustimass 10 Series IV Home...
Please Help ....i have Bose Acoustimass 10, 5.1 system connected
Usually the LFE out is only a line out and is not amplified in any way, so first of all is your subwoofer self amplified or not? Cause if not, the LFE output won't be of much use to you. So if it's not self amplified you need an new amplifier to put between the receiver and the subwoofer. Any amp that supports RCA line-in input will do. Even a car stereo amplifier will work provided you can get a 12volt power supply to run it in the house. If the subwoofer is self amplified though, then all you need is to make an adapter cause none are readily available in stores to go from a RCA connector to 2 wires. You can buy a virgin RCA connector that you can wire yourself at The Source, Circuit City, or any electronics store you have locally, or if you have an old RCA to RCA wire you don't need anymore, you can just cut it in half, strip the 2 wires and you got you adapter right there.
Jul 07, 2009 | Bose Acoustimass 16 Speaker
Bose Acoustimass 15 subwoofer is completely dead.
Clarify, did it ever work for you? Were both receivers used properly configured for the subwoofer? Did you also test the other speaker moduels running off the subwooferto see if they work?
Speaker Receiver setting
• Left and right LARGE
• Center LARGE
• Left and right surround LARGE
• Center surround* LARGE
• LFE/Subwoofer ON
With an Acoustimass 16 Series II system or upgraded Acoustimass 15 Series IlI system only.
Apr 23, 2009 | Yamaha RX-V663 Receiver
Center, and rear surround speakers
Sounds like the rear volume is just turned down. Cant be the amp if the front and subs are working
Aug 28, 2008 | Bose Acoustimass 15 System
No power to the Acoustimass bass
Hi, have you checked the internal fuse in your sub?
May 06, 2007 | Bose Lifestyle 35 System
1,217 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
