Question about Watches
How do i change the battery on a marco max quartz watch
3 Suggested Answers
skyreacher36
  • 74 Answers
SOURCE: Can the batteries be changed in Britain?
of course you can just pop into any jewellers or watch shop they will fit it for a small fee
Posted on Jul 27, 2009
  • 56 Answers
SOURCE: New quartz analogue watch losing 5 minutes a day.
not often so . beleive you me from an avid fine watch collector . it's the batteries. hopt this helps.
Posted on Jan 24, 2010
How to change a battery
If watch expensive, take it to Shop to get it changed , if watch waterproof, it needs to be changed at a shop, as when battery changed , shop checks that the watch is still 100% waterproof.
Mar 07, 2015 | Tw Steel Grandeur Diver chronograph Quartz...
I have a Movado Series 800 Subsea. It stops running when it's not worn. If I shake it, it starts up agin. I know it's a quartz hence a battery. Is it kenetic? The manual does not say.
It is not kinetic, the watch should run whether it is worn or not. A kinetic watch requires motion in order to wind a mechanical movement. A quartz movement requires a battery and that is all. You might want to change the battery.
Feb 17, 2014 | Watches
Changed battery, now buttons on sides do not work, where to get it repaired?
mcdevito75 here, Most likely during the battery change you moved the quartz movement away from the contact buttons. Re-Open your watch carefully and make sure when you press the buttons, each button is pressing against it"s spot on the quartz movement.
Jun 17, 2011 | Mio Motiva Petite Heart Rate Monitor Watch
I just replaced the battery on a fossil watch and it won't work. How to you reset it? or what else needs to be done? Please help me. thanks.
mcdevito75 here, Your Fossil watch should work with the battery change, of course it will need to be re-set. You"ll have to double check the battery install, make sure the battery contacts are clean, use a piece of paper towel and carefully clean the battery contacts. Hopefully your new battery is not dead. Another thing to check for, is that the buttons contacts are lined up with the quartz movement. While you double check your battery install, carefully press 1 button at a time, and make sure each button is making contact with the quartz mechanism, many times during a battery change to quartz movement may move just slightly but enough to keep the buttons from contacting the movement, this will keep the watch from working. Hopefully 1 or all of these is the answer for your Fossil watch.
Aug 22, 2010 | Watches
My watch ar2434 is not functioning properly. the seconds hand moves for some time and then stops. i changed the battery but the problem still persists. what could be the problem?
mcdevito75 here, The quatrz movement could need a little quartz oil or the quartz movement could be going bad, but foirst check make sure you have the correct battery and that it didn:"t work loose Return to whoever changed the battery to have it checked.
Jul 21, 2010 | Watches
Watch not working!... no use if i put a new battery..... the guy says i had to change the battery immediately and now my watch got spoilt by the old battery.....it seems it leaked and spoilt...... now how...
mcdevito75 here, Sadly, once a battery, any battery leaks, it leaks out acid that eats away metal. Once your watch Battery leaked acid, it ate away electrical contacts, wires as thin as hairs, and tiny linkages with--in the quartz movement of your watch, ----- there is no reversal of this acid corrosion. You have 2 choices, 1 and if this is possible, have your watch repair person replace the quartz movement with a new one, if replacement movement is available, and 2 replace the entire watch. Sorry.
Jul 10, 2010 | Armitron Digital Sport 406623BLK Watch
New battery want work? I tried two new ones and nothing worked? Need help.
mcdevito75 here, You may need to start your watch by pressing the MODE button. Most quartz watches will stop once you"ve changed the battery, of course the possibility is there that the watch quartz has burnt out also. See a small watch repair shop in your area.
Jun 30, 2010 | Fossil BQ9177 Wrist Watch
Jan 24, 2010 | Timex 27191 Wristwatch
How do I change the quartz battery on a Longines La Grande Class
Just unscrew the screw at the back if your model have screw if not the other one snap to open.Use a pocket knife then open it look the number battery and replaced it with same number battery. Its you use Renata battery it is swiss 3years to last.
Hope it may helps;
Regards;
VOTIT
Jun 16, 2009 | Longines La Grande Classique L4.709.2.42.9...
Adjusting a digital watch
Yes you can adjust digital quartz watches,there be a trimmer inside to adjust the fast and slow.,but that is last option to do if nothing happens.I think when changing the battery you did not clean the battery terminals,so that film residue will gone out.Film residue comes from the liquid comes out from the old battery.this is the most common problem of the battery.After all you clean,next is short ,the terminals.If you forgot this step this is very problem at all,the not working so you better watch out.
Jun 16, 2008 | Columbia Elkhorn Countour Watch
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
