Question about GE Profile JK915 Electric Single Oven
GE Oven JKP15
My start button on my oven will not work
  • 1 more comment
  • jack ford Jun 10, 2007
    We replaced the control panel and it did not fix the problem
    All the button work bake, broil, light, etc. But you have to push the start button to turn on the oven. I can not reset the clock because once you set it you have to push the start button. I spent $300.00 for the control panel and it did not fix the problem the start button still does not work
  • KatieBrooke Dec 17, 2007
    I am having the same exact problem! I have tried everything and was wondering, did you ever get it fixed?
It is the connector for the ribbon cable on the back of the control panel. I bought a new panel as well and figured out it is the ribon cable connector in the back doesn't hold the ribbon well . I am looking for the part to replace it on line with no luck yet ( the whole board area is 178.00 us dollars so i just want the 5 dollar or so ribbon cable connector to soder in.
Posted on Dec 02, 2008
    New Friend:
  • 129 Answers
If you have clock display try to unplug to check if it reset itself if not problably you need a new contol panel. let me know to fin the part # for you
Posted on Jun 10, 2007
  • 1 more comment
  • Luis Amado Jun 10, 2007
    Il' l check the schematics to see if you have maybe a door switch problem or a broken or bad connection , please tell me more about the problem since the beguining thanks
    tell me if with the old panel you had the same problem.? if so your door switch is the problem
  • Luis Amado Jun 12, 2007
    any luck , need or may more help thanks
Owner manual pdf
Dec 09, 2013 | GE JKP15 Electric Single Oven
My broiler element has burnt out and i need a replacement its a GE built-in oven model number JKP15
See this link, then click on the exact model number for your appliance. Navigate to the section of the oven containing the part you require:
Apr 02, 2011 | GE JKP15 Electric Single Oven
JKP15 Electric Single Oven: Oven keeps beeping with F7 error...
F5 Loss of relay drive circuit If this fault code cannot be cancelled, replace the oven control (also called clock or ERC).
May 07, 2010 | GE JKP15 Electric Single Oven
GE JKP15 does not self clean and minutes cant be set on clock
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Mar 30, 2010 | GE JKP15 Electric Single Oven
My oven has power but it does not work. When I
Your control panel is faulty and will need to be replaced. You can get another one at or
Jan 13, 2010 | GE JKP15 Electric Single Oven
Oven comes on for 5 min then shuts down everything even the keyboard
Same problem here on JKP15WOW1WW. The cycle starts like this:
1) Open circuit Breaker
2) Open oven panel and push ribbon connector to ERC. Replace planel.
3) Close circuit breaker
4) Run to oven, notice clock flashing some time but not 12:00 and start Bake. Bake button beeps and starts bake coil.
5) Within 5 minutes hear a beep and all buttons on panel are unresponsive. Bake continues. if oven light is on it continues to glow. Only button that responds with a beep (and not to clear bake or oven light) is Clear botton.
Nov 11, 2009 | GE JKP15 Electric Single Oven
GE JKP15 Oven Overheats Randomly
50 degrees is not reprogrammable so you must replace the control. sounds like the relay may be sticking on the control board.
Jun 12, 2009 | GE JKP15 Electric Single Oven
GE JKP15 Electric Single Oven - Code F7
If possible i will need the letter that come next after the JKP15.
Aug 19, 2008 | GE JKP15 Electric Single Oven
Ge oven fuse
checkin model # jkp15, f3 shows up as a shorted oven sensor here, No fuse even shows up for this particular model
Feb 22, 2008 | GE JKP15 Electric Single Oven
GE Profile JK915 Electric Single Oven Logo
285 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
