Question about Krups FME4 Coffee Maker
I lost my manual for krups fme4 and i need to set the time of day can u help me
Go to the krups website and download the manual:
go to consumer service, then instructions---maybe this link will work:
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={FA4AA2D9-9799-4F8F-8136-8FEB029407FD}&SelectedProdRef=FME4
Posted on Mar 30, 2009
How do I descale this coffee maker(FME4) if it won't brew because it thinks there's no water. I put vinegar into the water reservoir as directed but how do I get the machine to start.
you just do the same thing as if you are making a coffee but if you don't have the water pump working you will have problems getting the water out
Oct 12, 2014 | Krups Coffee Makers & Espresso Machines
Krups fme4 wont brew
Please explain what your device does, and make sure you explain it completely and clearly.
Feb 14, 2014 | Krups Coffee & Spice Grinder - White
Door popped off my Krups FME4 drip coffeemaker.
Just had the same problem today so I thought I would share with you how to fix it. The spring runs up through the door that opens, pop off the silver top and the wire where it makes a L, lock it into the top and put the silver top back on. The switch on the right is only to hold the door open. Good luck.
May 06, 2010 | Krups FME4 Coffee Maker
I am needing the double sensor (don't know what
those are named "contact thermostat" why you think they are brocken?
Feb 14, 2010 | Krups FME4 Coffee Maker
On FME4 coffee maker the error message CALC
it means de"CALC"ify its detecting calcium build up the manual says to run white vinegar without the filter followed by two clean water cycles goto krups.com to download the manual
Oct 10, 2009 | Krups FME4 Coffee Maker
FME4 won't brew; thinks there's no water
I believe that the description you made of the horizontal dashed lines indicates that the unit needs a descaling. If it also says "CALC" on the LCD display, then that probably means that calcium build-up needs to be removed. I am looking for my instruction manual because my machine is currently doing the same thing and in the past I've followed the instructions to descale it using a solution of water and vinegar. The weak acid from the vinegar removes the calcium deposits in the machine. Use distilled water and you won't have to descale it!
Jun 12, 2009 | Krups FME4 Coffee Maker
Door spring came off filter basket door on Krups FME4 coffee mak
yhere should be a little post th spring goes on in the vack of the basket ...out in pkace hold untill in place
Dec 10, 2008 | Krups FME4 Coffee Maker
Lost manual
The manual is here: http://www.wholelattelove.com/manuals/Krups/FMF5%20Manual.pdf
Here is the relevant information from it:
Setting Auto On
This programs the coffee machine to start automatically at the set time each day.
• Press the prog button (o) briefly : the display will blink “prog“ for about 1 second, followed
by “8888“.
• Press the prog button  briefly: the hours will blink “88 _ _“.
• Adjust the hours in steps by pressing the h/min button (n).
• Press the prog button briefly: the minutes will blink “XX 88“.
• Adjust the minutes in steps by pressing the h/min button .
• Confirm the setting by pressing the prog button briefly:
• The display (q) will show the time and a “ “.
• Press the h/min button to cancel the programming.
Aug 19, 2008 | Krups FMF5-14 Stainless Steel 10-Cup...
Instructions
hi,
 the instructions of how to use d coffee maker, ll be given along the maker in a pamphlet or a small manual...read it...u ll find d instructions to operate it
good luck,
trendsetter
Jul 03, 2008 | Krups FME4 Coffee Maker
The display reads CALC.
I have a Krups model FME4 and it means that you should descale the machine. Here's a link to the use and care instructions for my model, I assume it would be the same for yours.
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Use+and+Care/ResultUseAndCare.htm?SelectedService=Use%20and%20Care&SelectedGuIDService={EC10140D-AA43-4DCA-8D3A-A5A4823D9E52}&SelectedProdRef=FME4
My problem is that CALC continues to display even after I've descaled several times. Good luck with yours.
Oct 30, 2007 | Krups ProAroma 453-42 Coffee Maker
Krups FME4 Coffee Maker Logo
501 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
