Question about Canon imageRUNNER 2525 AllInOne Laser Printer
Canon imagerunner 2525 not showing number for some received faxes in fax log
Some incoming faxes do not show a fax number in any of the received logs and therefor cannot be forwarded.
SOURCE: canon laser class 2050p
yes. imageclass 2050 p
Posted on Jan 09, 2008
MyTechGuru
  • 93 Answers
SOURCE: Canon MP830 has stopped receiving
Follow the below instructions to set the receive mode using the operation panel.
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
  • FAX only: When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only.
  • Manual RX: When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually.
  • Ans. machine connect: When you want to receive voice messages on your answering machine and receive faxes automatically.
  • FAX/TEL auto switch: When you want to receive faxes automatically as well as voice calls.
  • DRPD: When you have subscribed to a DRPD service with your telephone company.
  1. Press the <Stop/Reset> button repeatedly to return to fax standby mode.
OR
Ring Count Change the ring count on the fax when the receive mode is set to Fax/Tel or FaxOnly modes. Change the ring count on your answering machine when it is connected to the fax and the receive mode is set [Ans mc connect] (Answering Machine Mode).
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button.
  3. Press the left or right arrow button to select [Maintenance/settings], then press <OK>.
  4. Press the left or right arrow to select [Device settings], then press <OK>.
  5. Press the up or down arrow to select [FAX settings] (item <1>), then press <OK>.
  6. Press the up or down arrow to select [RX settings] (item <3>), then press <OK>.
  7. Press the up or down arrow to select [Incoming ring], then press <OK>.
  8. Press the up or down arrow to select [ON], then press <OK>.
    Note: The default setting is [OFF].
    1. A window will appear displaying the number of rings before the machine will answer. Press the up or down arrow to select the number of rings (from 1 to 30 rings).
    2. Press <OK> to set the number of rings.
  9. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Posted on Aug 15, 2008
crayzeetrayn
  • 837 Answers
SOURCE: Canon Pixma MX300 fax vs voice
I haven't checked the manual specifically but if you are "manual-less" here's a link
Posted on Dec 27, 2008
  • 3 Answers
SOURCE: SLEEP MODE PROBLEM
I had this problem with one of my copiers once. I called to service technician. He reloaded the most recent system software. That solved the problem.
Posted on Jul 18, 2009
hquiteculo
  • 19 Answers
SOURCE: Canon ImageRunner 2020i
first do you have to selec the try with do you are going to use for copy.
Posted on Jul 28, 2009
Describe your canon imagerunner 1023 how to
1) on copier you have a button add. functions-something like *
2) with + or - trough the menu press OK at FAX sett. or under report sett.- If I recall its under Fax sett.
3) try to find report sett. then OK
4) you must enable the RX REPORT than OK
For transmision report you must enable TX REPORT
Jan 13, 2010 | Canon imageRUNNER 1023iF Black and White...
How to print to fax using the canon imagerunner 2020i
On the installation cd's of the machine there is a fax driver if you install the fax driver the fax is showing as a fax in the printers and faxes in the controll panel.If you print to the fax a window will open where you tipe the name and number you want to send the fax to.There is also a option if you want to add it to the addresbook.After editing the info add it to the receipient list and send.Your document will faxed from your computer via the IR machine,if your machine is connected to a fax line.
You can edit the address book easy by logging to your machine via your broser tipe the ip address of the machine in your browser and press go.If the machine is connected via local LAN.
Nov 16, 2009 | Canon Office Equipment & Supplies
How can i generate incoming call report ?
To print a report:
  1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
  2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
    • Phone Book: Phonebook list
    • Sent Report: Sent fax report
    • RCV Report: Received fax report
    • System Data: System data list
    • Scheduled Jobs: Scheduled job information
    • MSG Confirm: Message confirmation
    • Junk Fax List: Junk fax number list
  3. Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
  • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
  • Sent Fax Repor: This report shows information of the faxes you recently sent.
  • Received Fax Report: This report shows information of the faxes you recently received.
  • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
  • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
  • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
  • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
  • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
  • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
Aug 04, 2009 | Xerox PE120i Laser Printer
Samsung SCX 4521F: Incoming faxes 'receiving' but fail to print
Has the main board been changed??if yes the liu board(modem) board needs replacing.
Jul 18, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Wish to print outgoing fax log date/time/number
I don't think there's a log you can print but you can do the following. Not quite what you want, but better than nothing...
You need to set the fax confirmation option to log faxes before you send anything. The default option is off, so you won't be able to get a fax log for anything you've already sent unfortunately.
1. Press Setup
2. Press 2 then press 1. This displays the Print Report menu
3. Select Fax Confirmation
4. Press c00424037.gif to highlight one of the following, then press OK
Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
May 06, 2009 | HP Officejet 5610 All-In-One InkJet...
HP LaserJet M1522nf MFP No Fax detected
The book says
No fax detected
The product answered the incoming call but
did not detect that a fax machine was calling.
This could be really tricky. The missed faxes could be just random wrong number or recorded sales calls that are dialing you machine.
If you are sure they are fax machines calling then we get into phone line issues and that sort of thing. If you get static or noise on the line it can affect your machines ability to hear the other machine. I saw somewhere tha replceing the cord form the wall to the fax helped some people with a similar problem.
You can always try turning the machine off and unplugging it for awhile this is a common suggetion from HP for almost any product with a problem.
Hope this helps
Mar 12, 2009 | HP Office Equipment & Supplies
Cannot Send or Receive Faxes
here you might find an answer:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc240c_all
Mar 29, 2008 | Brother Multi-Function Center MFC-240C...
Canon imageRUNNER 2525 AllInOne Laser Printer Logo
53 people viewed this question
old marine
old marine
