Question about Brother Office Equipment & Supplies
Mfc-9440cn Error 71 Unable to Print
The error is "ERROR 71 Print Unable". Dont know what to do.
faxman789
  • 297 Answers
SOURCE: Print unable error message
Try this link for your solution...is related to 3A...
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002500/000055/faq002555_001.html?reg=us&c=us&lang=en&prod=mfc9440cn_all&Cat=11
Posted on Jan 17, 2009
komguy
  • 2306 Answers
SOURCE: Brother MFC-9440CN error 5A print unable
Error 5A unable to print is a problem with the high voltage power supply PCB, or with the engine PCB. A shop could tell you which one after some testing. Expensive repairs...
Posted on Jun 29, 2009
pineworks
  • 4041 Answers
SOURCE: Print Brother Mfc-290c Error Print unable 4F
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 18, 2010
  • 1570 Answers
SOURCE: My printer Brother MFC-9440CN is unable to print.
Hi there !
I am here to help you to solve your problem.
I believe your print spooler service stop running or your spooler is confused pending some queue at the print spooler service.
To resolve this, follow this procedures.
Go to START MENU
Choose RUN (For Windows XP) or Choose Commamd prompt, right click mouse and run as administrator ( For Window vista and windows 7)
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C: drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer and must also turn off your printer and then switch it on.
It will work fine right now
I hope it helps you
Posted on Jan 27, 2011
djgillstudio
  • 107 Answers
SOURCE: "Print unable 32" on a
hello,
well first, this error seems to mean alot of things. to start, pull drum, toner cartridges, belt and waste assembly out of printer, turn off and pull power cord first. first thing to check is, inside the front of machine, there is a black sensor flag that is triggered when waste toner cartridge is in machine. make sure flag moves freely and does not get stuck, if it gets stuck, you will need to carefully pull it out, leave cables attached, but carefully, take out so you can work on it, what is happening, is the foam that minimizes the noise caused by solenoids, well they make noise, just a clicking noise, this foams becomes a glue, and the sensor flag sticks to it. so if you have done any type of solenoid service, its easy. if not I will talk about later. but this is only one area you need to check. the next area is in the back of machine. you will need to remove the back cover first. it only has 2 screws, the fuser unit, has also 2 screws. the next part you will be looking at the covers now that cover the high voltage unit. the high voltage is under the plastic white foam. there are 2 covers , one is right in front, no screws hold it in, there are 2 small holes,left and right , using small flat bladed screwdriver, pull gently out, and lift up cover. the cover that has foam on it lift right side and push to the left, the covers lifts right off. you will see 4 red cables, remove them carefully, also there is a flat cable, disconnect very carefully, you will also see white cable with many leads as well as a red cable, disconnect these too. there are only 2 screws that hold this in place, so remove them. the high voltage slides towards rear of machine. Now with the unit out of machine, look at it. you will see there are 3 sensors clustors on this device, to are open, the third one, its located next to one of these, it has a cover that is covering it. it also has a solenoid attached to it, this the problem, because it will stick in the open position, causing problems, so you will need to do a solenoid fix, i have found using regular office tape, works well, since it will not stick to plastic. you will also see that you will need to remove the metal cover, as well as remove solenoid. now put machine back together, and test. if this does not repair this error, you really have a problem., i hope this helps
Posted on Aug 16, 2011
Print unable 71
Print Unable 71 means Polygon Mirror Failure on the Brother HL-4040, MFC-9840 and MFC-9440.
Pretty safe to say it means the same thing on the MFC-8880.
The Polygon Mirror is part of the Laser Unit, and its rpm isn't within specs.
The Laser Unit must be replaced.
Jan 08, 2015 | Brother MFC-8880DN Mono Multifunction...
I have brother DCP 7055 it shows print unable 71 error pls suggest
I have brother DCP 7055 it shows print unable 72 & some time it show 71 error pls suggest
Dec 18, 2012 | Brother Dcp-7055 Laser Print Copy Scan...
Brother MFC 9440CN - I am getting "Document Jam"
Take the cover off of the ADF, rub clean the rollers with a damp cloth. Make sure there is no paper stuck in the area Also, check that the sensor flags are activating. just move them back and they should bounce back to normal position. Cleaning should do the trick.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Jan 21, 2011 | Brother MFC-9440CN Laser Printer
My yellow toner is out and the printer will not print in just black
The MFC-9440CN should be able to work even if one or more of the color cartridges are empty.
here's what you can do to print in black only.
1. Unplug the power to the MFC-9440CN
2. Clear the print queue on your computer so that there are no jobs waiting.
3. Right click on the MFC-9440CN printer icon and select "printing preferences"
4. Select "mono" as the color mode.
5. Turn the power back on for the printer.
Now when you print it will be in black only and it should work even if all 3 colored toner's are empty.
Thanks,
Pat
Mar 26, 2010 | Brother MFC-9440CN Laser Printer
I have a MFC-9440CN Brother printer. It displays Print Unable 32. What is the problem?
http://www.youtube.com/watch?v=6Bob34TLrPQ&sns=em This YouTube video shows how to fix this problem with a small piece of tape! Save the 100 bucks.
Feb 06, 2010 | Brother MFC-9440CN Laser Printer
Jun 29, 2009 | Office Equipment & Supplies
GOT ERROR 71 PLEASE HELP
any of the error 7X codes are to do with the fuser. Call an engineer
Jun 04, 2009 | Brother MFC-8220 Fax
376 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
