Question about Kitchen Ranges
Whirlpool WGP 54800 - Element does not shut off when desired temp is reached. Is this a simple fix? - a relay or somesuch?
Display beeps when display says that desired temp is reached but the element does not cycle or shut off.
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the complete model number of the unit?
Posted on Dec 07, 2012
  • 3 more comments
  • Wayne Hewitt Dec 07, 2012
    per the tag, WGP 54800 Type 30P serial IMH4391971 I have done a bit more experimenting and suspect that the real problem is that the holding shut-off tempo is very much higher than the display. Temp set to 200 is measured at 220 in oven. Set at 300, measures at 370. When we had it set at 350 it did not reach whatever it thought it wanted so I saw it as a 'not shutting off' rather than as a limit issue. Am going to clean the probe in case it has a coating on it.
    The control is cycling the element off and on at the lower temps. Is it likely it is just the probe itself?
    Whirlpool Accubake System
  • Richard Roth
    Richard Roth Dec 07, 2012
    Pull the probe out and at room temperature it should read around 1100 Ohms. Post back the results.
  • Wayne Hewitt Dec 08, 2012
    Probe was cleaned. Left probe in place. 1070 ohms at 71f, 1340 ohms at 230f (set at 200f)
4 Suggested Answers
  • 244 Answers
SOURCE: Digital clock on LG electric stove doesn't display
buy new clocl display/circuit board
Posted on Mar 13, 2009
  • 12 Answers
SOURCE: Amana Electric Range Mod# AER5715QAW bake element not wokging
replaced the electronic control
Posted on Jun 14, 2009
  • 61 Answers
SOURCE: Kenmore gas range beeps and displays code E1-F2
I'm not sure if the error codes are the same for gas ranges as they are for electric, but this is the solution for that same error code with the electric version. you might give it a try with yours and see if it works the same for gas as well (I would assume the electronics are similar between the two).
you probably don't need to replace any parts to solve this problem. E1 -F2- = the keytail (connector ribbon) that plugs into the control board is not making good contact. first unplug your range and then remove the two screws on the underside of the back-splash controls panel to access the back of the control board. now simply cut a slip of heavy paper such as a business card to the width of the ribbon and slide it into the slot along with the ribbon connector. that will help press the contacts on the other side together snuggly. screw the back-splash back in place, plug in your range, and the problem might vanish. if the error code returns, try pulling out the connector, cleaning the contacts with a pencil eraser, reinserting it into the slot and repeat above with the paper.
the paper trick worked for me for about two weeks, then the problem happened again. the next fix I tried was to unplug the keytail (the ribbon connector) from the slot on the control panel. there is a clip in each side of the black plastic receptacle (the place where the keytail plugs in on the electronics control board). pres them inward to separate the top portion of the receptacle, which I think helps to clamp the keytail into the bottom portion. the top and bottom fit tightly together, so you might need to use a small screwdriver at the joint to pry them apart, however, I did not find it necessary to remove that clamp in order to remove or replace the keytail on mine.
smoke and other sticky cooking fumes cling to the contact wires on the keytail and the pins in the receptacle (as well as other surfaces) and that buildup interferes with the electrical connection they need to make. once the keytail is free, clean it well with a mild cleanser (I used a slightly soapy, damp dish sponge) and dry it with a clean paper towel. FYI, one side of the keytail has the exposed wires which make contact with pins in the receptacle on the control board. the exposed side is on the inside surface of the curled keytail ribbon, the outside surface is translucent plastic insulation (you can feel that the outside is smoother than the inside because the inside has the contact wires exposed). the inside is the side you want to make sure is clean because those are the wires that need to make electrical contact with the pins in the receptacle.
next, use sharp scissors to carefully trim a small uniform strip (roughly 1/16 of an inch or less) off the end of the keytail. then plug it in again (remembering to use the top portion of the receptacle to secure it in if you had removed it). doing this provides a fresh spot on the exposed wires to make contact with the pins in the receptacle. my theory is that over time the wires wear out at the points where they make contact with the pins. trimming the edge allows you to insert the keytail deeper into the receptacle and therefore, the pins will contact the wires in the keytail at a new, unworn spot. it's been over a week now and so far, it seems to have fixed the problem on my stove. if I get the error message again in the future, my next step will be to try paper trick again (at least as a temporary solution), but I doubt it will be necessary any time soon.
be sure to try all other solutions first before ordering any parts. I first changed the control board for $125 and there was no change. then I ordered the touchpad, but ended up fixing the problem before it arrived. I sent the touchpad part back to Sears Parts Direct after I figured out I didn't need it and they eventually refunded $15 less than I'd paid. of that difference, $13 and change was for shipping, so the other dollar plus must have been a miscalculation or a restocking charge or something, but I didn't bother following up to find out. I also had to pay about $3 to ship it back to them via USPS because I didn't hear the UPS guy when he dropped it off on the doorstep, so I wasn't able to simply refuse the delivery.
good luck with your repair.
Posted on Nov 18, 2010
F6E1 WHIRLPOOL OVEN CODE
what is the model #? sounds like a fused relay on the control board, or an element that is grounded to the frame. call a tech on this one, 240V appliances are not to be trifled with!
Mar 24, 2016 | Whirlpool 30" Self-Cleaning Freestanding...
Random beeping oven
Check the connections to the oven heating element for oxidation. If the wire insulation at the connector looks like it has been overheated, you almost certainly have a bad connection.
Nov 12, 2017 | Whirlpool RBD306PD Electric Double Oven
I set oven temp. It seems to heat ok, during the bake cycle it beeps then shuts off, no display for oven function but the time display remains. Replaced the relay/display board but same.
the beeping is probably saying that set temp is reached just probably oven is still heating so dont turn it off look after an hour if it still on and very hot and worry about display changing its probably how the programmer wanted it to be
Aug 08, 2013 | Kitchen Ranges
AC will not shut off when desired temp is reached. Have replaced batteries.
thats simple. this is caused by weak power button of board. let me know if you dont know how to do this.
May 31, 2012 | Heating & Cooling
Takes for ever to reach temp
you may want to check to make sure both elements are working, if only one is working it will take longer to reach temp and to cook
Sep 18, 2010 | Fisher and Paykel AeroTech OS302 Electric...
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
My dacor oven model ECS130SBK is very slow to heat. Sometimes reaching the desired temp. after a long wait. Sometimes it never gets there.
I found the bottom element was not getting any power by using a volt/ohmmeter and a test method described elsewhere. (Shut off power, hold down COOK TIME while turning on power. then within 30 seconds press each mode you want to test and only that element/fan/etc will turn on. Cancels by itself after 30 sec.)
I traced the wire back to the relay (wire checked good) and there was no power getting through the relay although it clicked. Removed the relay board to replace it and found a cold solder joint on the "out" terminal with obvious past arcing carbon. Cleaned and soldered the pin and the oven now works normally.
WHY THE SLOW TO HEAT? The oven turns on all the elements to preheat faster and when it reaches your set temp it beeps and now only turns on the element you selected to maintain the temperature. (Bake or Convection) Our malfunctioning ovens would then cool since the element is not working properly and it must go back into preheat and keep cycling.
BY THE WAY- Don't ever use 4 hours on self clean it kills the boards and/or display. I also put a house fan in front of the oven and blow it into the lower grill to take away some of the heat on the two boards. Learned the hard way!
Jun 08, 2009 | Dacor ECS130 Epicure Electric Single Oven
GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Mar 14, 2009 | Ovens
What is the correct procedure for setting temp
You should still have a lower element. If the lower element doesn't get hot when the controller is set for 350 degrees, that's the problem.
Let me know
Feb 01, 2009 | Whirlpool GR465LXLS Electric Kitchen Range
I have a Frigidaire Gallery gas range and oven #plgf389aca
i need to shut off the self cleaning on my stove.
Dec 11, 2008 | Kitchen Ranges
Kitchen Ranges Logo
103 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
