Question about Samsung LN46B750 46 in. HDTV LCD TV
REMOVING THE STAND ON A SAMSUNG LN46B750 TO WALL MOUNT IT
HOW DO I REMOVE THE STAND TO WLL MOUNT THE TV
SOURCE: removing stand from tv
UNSCREW the FOUR (4) screws on the back panel (marked with an "S" next to their recessed holes.
Work with the panel screen-side up (ie on its back - we did it with the LCD on the bed), and just JIGGLE the stand back and forth until the screws drop out. This make take some doing, but using force is a no-no (as the screw mounts are only plastic). Obviously the screws MUST be undone, so just keep unscrewing them while someone else jiggles for you.
Thats it. The plastic cover (from the manual & warranty bag) covers the hole.
Posted on Feb 09, 2008
SOURCE: how to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
SOURCE: how to remove base on samsung 2333hd
We had the same problem, we just wiggled it back and forth, gave it a good tug, and hey presto! We got it out. I'm not sure whether this is the "official" method of doing it, as nothing is mentioned in the instruction manuals.
Posted on Jun 07, 2010
tvhelp-Dave
  • 178 Answers
SOURCE: samsung LN37b650 television stand removal. how do
Mounting on the wall, be sure use the short screws and no power tools. Hopefully it can help you and get a good commend.4933675.gif
Posted on Jun 10, 2010
dsdelarosajr
  • 43 Answers
SOURCE: how do i remove stand from samsung syncmaster 2333
its a snap-type plug-in stand, just hold the stand firmly and pull the monitor equally upward, then it will snap quickly....... but a proffessional reminder! Before mounting your SyncMaster on a wall, be sure to plug the two (2) stand holes located at the buttom of the monitor. My Samsung SyncMaster 2333HD LCD TV was twice intruded by adult-size lizard, both incident resulted to main power board damaged!!!!
Posted on Feb 24, 2011
Can you tell me what size screws I need to mount my Toshiba Model 46G310U on a wall?
M6 or M8
http://support.toshiba.com/support/search?s_query=mounting+bolts
User Manual
Page 6
... stand. 3) Once you have removed all four screws holding the pedestal stand in place, remove the pedestal stand ..., level, stable surface that can support the weight of the surface. Four screws Hook Sturdy strap (as short as possible) 46 / 55" TV VESA Mounting Pattern 32" TV VESA Mounting Pattern Four screws Hook Sturdy strap (as short as possible) Four screws Hook Sturdy strap (as short as a quilt or blanket. Make ...) 200x200 mm 200x200 mm 400x200 mm 400x200 mm Screw Size M6 M6 M8 M8 (unit in mm) 40" TV VESA Mounting Pattern Removing the Pedestal Stand 1) Carefully lay the front ...
Toshiba 46G310U Mounting Screws
Sep 24, 2017 | Televison & Video
Remove stand from w4207 TV
Put tv on bed face down and look at the stand and locate and remove any and all screws holding stand to the flat screen set. Then after mounting the wall plate per instructions mount the tv to wall mounting.
Sep 08, 2015 | Westinghouse W4207 42 in. HD-Ready LCD TV
How do I remove the base stand to wall mount a Samsung model T24C55OND flat screen TV
The wall mount attaches to the top 1/3 portion of the TVs rear panel. The bottom of the back of the TV should not interfere with your wall mount if it's the correct size. Full instructions are listed starting at page 39 of the manual.
http://downloadcenter.samsung.com/content/UM/201404/20140426112621559/[X13_NA]BN46-00319C-04ENG-0312.pdf
Jan 08, 2015 | Samsung Televison & Video
What motherboard should i put in my HP - Compaq Pavilion p2-1013w
Dismantle the computer so the motherboard and mounting plate is free. Remove the motherboard off the mounting plate.
Most mounting plates have several standard mounting stand off positions so it can fit various motherboard from different manufacturers. Go to a computer parts shop with the mounting plate and select the motherboard of your choice then position the motherboard over the mounting plate to see if the motherboard mountings line up with the mounting plate holes.
You may also need to install a switch mode power supply with a higher wattage rating.
Mar 19, 2013 | HP Pavilion p2-1013w Refurbished Desktop...
How to remove stand from television?
Lay your tv on its back and then look under the stand part and you will see the bolts or screws holding the stand in place.
May 30, 2012 | Samsung Televison & Video
How do i remove stand from samsung syncmaster 2333 to mount on wall
Feb 13, 2011 | Samsung SyncMaster 2333HD 23 in. LCD TV
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Cant find how to remove the stand on our newly purchased Soniq QSL323CT1 anywhere in the manual. We are trying to mount it on the wall.
1. Disconnect all cables.
2. Cover a level and stable surface with a thick and soft cloth.
3. Gently lay the TV, face down, onto the cloth. Make sure the Table-Top stand is hanging over the edge.
4. Rotate the cable holder 90 degrees, and pull it out completely.
5. Remove the screws (3 or 4 in rear next to cable holder, depending on which model wall-mount kit you have) being sure to hold the Table-Top-Stand firmly while removing the last screw.
6. Do not remove any other screws from the TV.
They also say not to remove the stand for any reason other than wall-mounting the TV. Their should be instructions with the wall-mount kit.
Hope this helps!
Thanks
Smith.
Sep 07, 2009 | Televison & Video
Removing back stand supports
First I am not to sure about the brand you got there, But if it is not wall supportable you do not need to reove anything but by a wall mount that will hold the bottom in place and yes there are wall mounts for this tpye of arrangment see not all flat panels go on walls thus hence you cannot remove the stand easy. Try finding a wall mount the has a L shape to it, it will hold the bottom of the tv and it comes with a little strap to hold it back into securement. Please do not try to remove the stand I would suggest a diffrent wall mount- Rulds2008 TV expert for 20 years
May 14, 2009 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Samsung LN46B750 46 in. HDTV LCD TV Logo
96 people viewed this question
Jerry Greenberg
Jerry Greenberg
