Question about Casio fx-300ES Calculator
How do you type letters on a fx-85GT PLUS calculator?
SOURCE: How do I do a standard form equation on the
how to calculate sin 2 theta from fx-991ms calculator
Posted on Nov 28, 2010
  • 102366 Answers
SOURCE: Model FX-85GT PLUS- When dividing
There isn't a problem per se. The calculator is simply showing you the result as an improper fraction.
Press the S--D key to toggle the result between symbolic and decimal forms. To have the results always come up in decimal, press SHIFT [SETUP] 2 to select the LineIO mode.
Posted on Dec 28, 2010
  • 102366 Answers
SOURCE: How do you get more
Press SHIFT then MODE. You can then press 6 to select Fix, followed by the desired number of digits after the decimal point, or press 8 and select one of the two Norm modes.
Full details are on pages E-5 and E-6 of the manual. If you need a manual, you can download it at
http://support.casio.com/pdf/004/fx-83_85GT_PLUS_E.pdf
Posted on May 11, 2011
  • 7993 Answers
SOURCE: HOW CAN I INSERT THE
Same question, same answer.
Sorry, but you cannot.
You can type in a formula that involves the memory variables X,Y, A, B,C,D, E, =, . Such a formula is meant to be evaluated to get a solution (X by default). Once you type the formula you press the Shifted function SOLVE and you will be prompted for the constants, for Y etc. when you press the EXE/= key you get the value of X.
If you turn off the calculator or change the calculation MODE, it is wiped out of memory.
To make a long story short, you cannot STORE formulas in the calculator. Better try to memorize them (commit then to YOUR OWN memory).
Posted on May 24, 2011
  • 7993 Answers
SOURCE: please ca you show me
If you have the so-called xRoot key you procede as follows; 10[xRoot] 1.797
If you do not have an xRoot key you use the equivalence nth root of x= x to the power of 1/n
In the case of the 10th root you type (1.797)^(1/10) or (1.797)^(0.1). Here the [^] caret is the general power key. On some calculators it is marked as [X^y] or [Y^x]
Posted on Aug 22, 2011
How to change a decimal value to binary number in fx-85GT PLUS ? Thanks!!
Let's do the preocess so it will work on any calculator.
As an example, convert 68 from decimal to binary.
The decimal columns are 10^0, 10^1, 10^2, 10^3, etc.
The binary columns are 2^0, 2^1, 2^2, 2^3, etc.
Flipping to the normal left to right, we get 2^6, 2^5, 2^4, 2^3, 2^2, 2^1, 2^0.
64 32 16 8 4 2 1
We divide our number, 68, by 64, and get 1 with a remainder of 4. We next divide our remainder by 32, 16, 8, and finally 4, where we get 1 with no reminder.
In binary, this works out to 1000100. To check, we multiply the ones by the respective column values and get 64 + 4 = 68.
Good luck.
Paul
Feb 28, 2016 | Casio FX-85GT Plus Scientific Calculator...
What does the ! button do/mean on the Casio fx-85GT Plus Scientific calculator?
It is the factorial function, used to calculate permutations and combinations in statistics.
n! = n x (n-1) x (n-2) x (n-3)... x 1
Good luck.
Let me know if you have any questions.
Paul
Sep 13, 2015 | Casio FX-85GT Plus Scientific Calculator...
How to command cosh using casio fx-85GT PLUS
Press the HYP key to have access to all available hyperbolic functions.
Aug 18, 2014 | Office Equipment & Supplies
Please ca you show me how calculate the tenth root of 1.797 on a casio fx-85GT plus
Aug 22, 2011 | Casio fx-300ES Calculator
HOW CAN I INSERT THE EQUASIONS IN TO CASIO FX-85GT PLUS, SO IN THE EXAM I WILL EDIT THE NUMBERS ONLY?
May 20, 2011 | Casio fx-300ES Calculator
How do you get more than one decimal place in your answer on a casio calculator fx 85gt?
May 11, 2011 | Casio fx-300ES Calculator
How to use mod in casio fx-85GT PLUS
Do the division, it will be displayed in fraction form.
Then press "Shift S--D" to transform the result in mixed fraction form.
The modulus is the nominator of the fraction.
Example: We need 73 mod 7, we input 73/7= , then we press "Shift S--D" and we get mixed fraction: 10 3/7
3 is the result of 73 mod 7
(and 10 is the result of 73 div 7)
Mar 24, 2011 | Office Equipment & Supplies
Model FX-85GT PLUS- When dividing 55/21 the calculator will not produce the answer and instead will just show 55/21... What is the problem?
Dec 28, 2010 | Casio Office Equipment & Supplies
Casio fx-300ES Calculator Logo
106 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
