Question about Apple iPhone 3G
IPhone 3g Power & Volume buttons aren't working
My iPhone 3g was unlocked using universal sim and jailbroken via quickpwn. After using bossprefs to toggle switch on/off button, the power and volumes buttons were not working. I had restore to factory setting via iTunes and ended up with firmware 2.2, but such buttons are still not working. The iPhone is even in locked status now and couldn't be unlocked as the required power button is not working (leaving me with only the home button which is functioning).
If this is considered a hardware problem, what parts of the iPhone should be repaired?
I can't send it to Apple as there's no support in my country, therefore I have to fix it myself.
  • 2 more comments
  • Anonymous Jan 27, 2009
    Same problem, with 2G.
  • monkey_lo174
    monkey_lo174 Sep 02, 2012
    ummm yeah that helped NOTHING !!!!!!!!!!!!!!!!!!!!
  • kristi shawgo
    kristi shawgo Oct 29, 2014
    enable AssistiveTouch in the Accessibility options.
  • kristi shawgo
  • 100 Answers
This is probably a hardware problem, even though it started happening after a configuration change.
The part that connects the on/off button and the volumes is the same part. This flex cable connects these buttons (and some other parts) to the motherboard. This cable is frequently damaged when the Iphone is wet.
The good part is that it is a cheap part, and relatively easy to install.
You can find a replacement here:
Posted on Aug 19, 2009
I am using apple iphone 3g jailbroken.i bougth in canada and i am here now in the philippines. i cannot use it because no signal. i inserted other sim but it can't can i unlock my iphone.thanks
I think your phone is SIM lock to be able to make it open line and to use other sim network bring it to a reliable cellphone technician they have the necessary tools and skills on how to unlock and make your phone open line..
Jul 08, 2011 | Apple iPhone 3G
I found a iphone and it is locked, and I need to unlock it to use it.
Up until recently, those of us with an iPhone 3G had to use it on the AT&T network. Not anymore! After months of development and research, the guys over at the Dev Team have released the worlds first 3G unlock method. Unlocking will allow use of the iPhone on any network, and also the ability to install 3rd party applications not available via the App Store. This article will walk you through the steps in order to finally free your iPhone.
  1. 1 First, you will need to download the QuickPwn software. It is available in both Windows and Mac formats, and both download links are provided in the resources area of the article below.
  2. Step 2
    Make sure you are running the most current iTunes and iPhonemag-glass_10x10.gif versions. You must have iTunes 8.0.2. You can check what versions your iPhone is running by going to Settings->General->About on your phone and then looking for Version and Modem Firmware listings. The most current version is 2.2 (5G77) and the firmware is 02.28.00. If you do not have these running on your iPhone, the unlock will not work.
  3. Step 3 Create a backup of your iPhone using iTunes.
  4. Step 4
    Launch the QuickPwn program, making sure you have your iPhone on and plugged in via usb. Press the big blue arrow button to continue.
  5. Step 5 Next, QuickPwn will search for the firmware file on your computer. It should be able to find it on its own, so just press the blue button to continue.
  6. Step 6
    Next, QuickPwn will ask you if you want to install Cydia, Installer or to replace boot logos. In order to unlock, you MUST install both Cydia and Installer. Once done, press the blue button.
  7. Step 7 This is the tricky step. And not because its hard – its just so time-sensitive! In order for QuickPwn to begin its magic, the iPhone has to be in “Recovery Mode”. To achieve this, you are going to have to press some buttons! Don’t worry though, QuickPwn will highlight each step, and even count the seconds for you! First, you will hold down the HOME button for 5 seconds (the home button is the circular one on the face of the phone). Once that 5 seconds has passed, you will continue to hold the HOME button down, as well as the POWER button for 10 seconds. The power button is the one on the top of the phone, that you (duh) use to power the phone on and off with. After those 10 seconds go by, keep holding the HOME button down, but release the POWER button. Keep holding the HOME button down until QuickPwn tells you that the process has begun.
  8. Step 8
    Now, sit back, and try not to have a heart attack. QuickPwn will write the modified files to your iPhone, and for the most part, will keep you informed of what it’s doing. You might see some random lines of code on the screen of your iPhone, but it is nothing to be scared of.
  9. Step 9 Once complete, your iPhone will reboot and then be recognized by iTunes. When asked if you want to set this up as a new phone, or restore from a backup, select the backup option. This will allow you to choose the restore point we just made before starting this whole process. The restore process can take a while, so don’t sweat it. This is especially true if you had a ton of music and applications on your iPhone. It took about an hour or so for it to complete mine.
  10. Step 10
    Once complete, look for the Cydia icon on your phone. Open it, and go to the "Sources" section. Click the + at the top of the screen, then type this web address to add the following source:
  11. Step 11 Install the Yellowsn0w program and reboot your iPhone, making sure your with SIM card is inserted. Wait about 90 seconds for carrier lock; if you are still unable to connect, pull the SIM card out and try again
Nov 24, 2009 | Apple iPhone 3G
Itunes iphone
You will to UNLOCK your phone for your sim card to work.
Use unlock softwares, it always works like Quickpwn and others...
Search google for example : Iphone 3g 3.1.2 unlock
Oct 01, 2009 | Apple iPhone 3G Black Smartphone
Unlock iPhone 3G Baseband 2.30.03
Jailbreaking is possible. But not software unlocking. For that you must buy something like a Turbo Sim. For jailbreaking try the program called Quickpwn
Jun 05, 2009 | Apple iPhone Smartphone
Phone unlock
check out
Once phone is jailbroken download an app called yellow snow. This will unlock the phone. read up on site on how to do. Very quick and easy
May 28, 2009 | Apple iPhone 3G
2 2 Jailbroken iPhone 3G locked after upgrading can it be unlocke
i am sorry i found a wesite that will possibly help you (
i hope it works and please rate me
Mar 16, 2009 | Apple iPhone 3G
IPhone 3g power and volumes buttons are not working
You need to repalce the volume buttons, you can send you iPhone to Dr Cell Phone Repairs they do all kinds of iPhone 3G Repair . This repair should cost you only $74.99. For more information visit
Jan 04, 2009 | Apple iPhone 3G Black Smartphone
My iphone doesn't turn on
Try doing a factory restore using iTunes or QuickPWN and if you need to jailbreak it again, be careful what apps you download from cydia...some of them cause problems with jailbroken iPhones, just research online for which ones are notorious for problems
Jan 03, 2009 | Apple iPhone 3G
Tmobile sim still doesnt work after being unlocked.
if you have a 3g you cannot upgrade to 3.0 firmware and unlock it.
2g solution
3g solution
Jan 02, 2009 | Apple iPhone Smartphone
Apple iPhone 3G Logo
1,015 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
