Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Prints light shade
The printer does not give a copy in the exact shade as the original. We have replaced the black and white print cartridge and still has the same light shade.
  • 45 Answers
Call Kodak for a new printhead.
Posted on Jan 13, 2009
Getting light print on b&w, changing density makes zero change. Toner changed, no effect.
Check whether you are running as Black and White or Gray Scale. Many printers only print straight black by using all four toner cartridges- Cyan, Magenta, Yellow, black. If are running colored print in black and white and u choose grey scale it will automatically give you a screened image as a light print.
Mar 27, 2015 | Office Equipment & Supplies
I replaced my black and magneta ink cartridge today and documents will print out only nice shade of blue.
may i assume you removed tapes at the electronic side of cartridge?
shake the cartridges.
Now your computer should have a utility for settings the cartridge for
first time after loading them. Thisis to make sur the colors are mixing
to give the right shade.
Normally 1 single shade means the color cartridge is ending so may be you
double check you are not returning the same ending cartridge in the printer.
Hope that helped
Aug 03, 2011 | Brother MFC295CNAll-In-One InkJet Printer
Canon Pixma 3600 I want black & white printing only for documents Question: How do i turn off the colour cartridges for black & white printing only?
The Grayscale print option optimizes the look of color slides for printing on a black and white printer by adding shading. The Pure Black and White option prints your slides in monochrome.
  1. Open the presentation you want to print.
  2. Click on the word File in the Menu Bar.
  3. Select the option Print.
  4. The Print dialog will appear.
example:
sayurisan20_3.jpg 5.In the Color/Grayscale section, choose the Grayscale option to print in black, white, and shades of gray. 6.Choose the Pure Black and White option to print in black and white only. 7.Click on the OK button.
Jun 06, 2011 | Canon Office Equipment & Supplies
Samsung CLP-300 Printer not printing black well
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It's best to do this each time you install a new cartridge. get more information and help from here .
Jan 10, 2010 | Samsung CLP 300 Laser Printer
When I want to print using the photo or black ink cartridges, my printer uses the tricolour cartridge. If I take the tri colour cartridge out, the printer alerts that there is a cartridge missing and still...
If what you are trying to print is a black in white image then you cant print that when you dont have the other colors installed. The reason is because your image/photo has shades of gray, and for the printer to produce gray, it needs the other colors as well. It needs colors to get the light black or gray shades of the photo....
If however, you are trying to print text only, the printer should be using the black cartridge and not the other colors... I believe that there should be an option in the printers preferences to select black ink only... look for it under advance tab...
hope this helps
Sep 05, 2008 | HP Office Equipment & Supplies
Shades of gray printing as brown
does the black do a complete nozzle test print.if not clean several times and try nozzle test again
Dec 26, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Printing black shaded on complete page
I assume you mean the pages are coming out dirty or gary versus white and black text.
change the drum/cartridge, if you get the same results it could be the hi-voltage power supply. most common is the drum.
Dec 13, 2007 | Brother HL 1430 Laser Printer
Photocopying
According to " HP Officejet R, PSC 500 and Color Copier - General Copying Issues and Solutions", under the problem heading "Black is not Black", notes that:
"The unit will perform mono (or black) copies using the color cartridge to create a composite black in Normal and Best modes. This is necessary to create the correct grayscale shades. NOTE: The HP PSC 500 all-in-one product cannot perform black copies. Scan the image in and print it out in greyscale.
The color cartridge may be out of one color of ink. Run a self-test page to verify that all the colors are there. Replace the cartridge if they are not."
In other words, the device only uses the black ink cartridge when used as a computer printer. When used as a stand-alone copier, it uses the color ink cartridge, and all three ink colors must be present and working to give a black and white copy. Perhaps you can refill the color cartridge with black ink in all chambers?
Nov 13, 2007 | HP PSC 500 All-In-One Printer
400S Black lines at top of copy
Sounds like the drum is worn out. Usually do 60-70K before replacement. Shading more noticeable at top of copy. Could also before worn upper fuser roller.
Nov 09, 2007 | Canon imageRUNNER 400S Copier
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
65 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
