Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Temp is rising
The refrigerator sounds like it is running but the temp is 20 F on the freezer and 47 F on the refrigerator. I put the display panel is service mode and checked the errors. The error that was showing for option 1 was a CP error, which according to this paper shows a Compressor output error....Does this mean that the compressor went out or is there something I can do to get it working again?
Thanks,
Jeff Bartlett
    Guru:
  • 462 Answers
First Check the voltage to the compressor. Usually just 2 wires. If you do not have voltage and you are sure it should be running (it is turned on and plugged in) Check the controller (thermostat or Sensor/board assembly) because your problem is not with the compressor as of yet.
Assuming you have power to the compressor and the fan motor there is running up to speed the coils under neath are clean here are the items to look for to check out your compressor:
Getting to this step: Either your compressor is broken inside or the start components are not working properly. Ohm the compressor terminals to ground and across to each other.
If any read anything to ground the compressor is bad.
Your readings between the compressor terminals should all be different and you should have 1 low 1 medium and 1 high resistance reading.
Add the low and mid reading together and the sum should be close to the highest reading. If it reads say 20% more or less then retest it a couple of times to confirm your not slipping on the terminals.
Assuming the above checks out: Get a new Start relay (start capacitor if so equipped) relay and overload (and capacitor if it has one) In other words everything that is external and attached to the wires or terminals on the compressor, and replace them on to the compressor. Then if it starts problem solved if it still does same thing the compressor is bad (broken mechanically inside the compressor) and you have to decide to replace compressor or replace the refrigerating compressor be it AC or Refrigeration.
A few times I have gotten a compressor to start after leaving it off for 6 to 12 hours then retrying it. See the compressor unless left off for 6 to 12 hours and sometimes as long as 24 hours Is tight due to linear expansion from heat. And about 1/2 the time it is ok after new start components are installed. The other 1/2 the compressor will be ok for a day or 2 then stop again. Most likely from a “hard spot” in the movement of the internal parts in the compressor.
30 years of doing refrigeration and this has not changed.
Please rate me as high as you can and ask me to clarify anything you don’t understand.
Posted on Apr 14, 2009
Temp on screen rises & flash high temp.
Hallo
The compressor winding's could also be faulty.
regards
May 19, 2016 | Frigidaire Refrigerators
Freezer temp. keeps rising
try to turn off the freezer and adjust the temp. settings to a minimum.. Make it 20 minutes for your fridge to turn off before you turn it on. If the temp. keeps on rising, refer to your freezer manufacturer to repair the thermostat inside of it.
Aug 27, 2011 | Frigidaire Refrigerators
Rs265...both sides will cool down/freeze respectively, but will allow temps to rise without reading on control panel. have to disconnect/reconnect power to restore operation. The temps on the control...
Thats sounds right. These digital frigs are very nice except when you are trying to fix it!!! Expensive!!! Call Samsung and ***** like you never ***** before!!! this is unacceptabullshit!!! Tell them (even if it is out of warranty) that Consumers Report we love the negitive review you will give them if they dont come out and fix it!!! There should be many peolpe complaining about the same problem They can even send you a voucher check for a new one. Why not they have billions!!! You have to be pissed and demanding.
Mar 27, 2010 | Samsung RS265LABP Side by Side...
Frezer temp is 20 deg. fridge temp is 47 deg.
Remove the freezer shelves and bins. Remove the freezer back panel to access the fan motor.
May 26, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Temperatures fluctuating
Wonder why the "repair men" can't find a defective temperature control or circuit board.
Nov 06, 2017 | Frigidaire Refrigerators
WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH
You need to look inside the freezer at the rear wall cover and see if it is frosted over. If your refrigerator is not defrosting that can cause the refrigerator side and the freezer side also not to cool to the desired temp.
Mar 30, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
Freezer Temp display sya -47 deg and won't change
Check with mfg for a hard reset of the electronics. There may be some sort of hidden code with which to accomplish this.
Sep 05, 2017 | Refrigerators
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
75 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
