Question about Gaggia Unica Bean To Cup Coffee Machine
The 'no coffee bean' sign is on on my Gaggia Unica machine and there are beans in the hopper, do you know what is wrong?
I have gone through the circuit primer as all red lights were on and now the no coffee sign is on. The machine is tamping but no coffee seems to be getting through..
4 Suggested Answers
  • 833 Answers
SOURCE: Beans stick in hopper
The problem is that beans have particles and oil on/in them, jamming the switch which is giving you this message. Invert the unit on a hard surface covered with newspaper and give it a couple of strong taps against that surface. The junk should fall out and get you going again. Clearly, you're missing something when disassembling the unit.
Posted on May 09, 2008
  • 1089 Answers
SOURCE: gaggia titanium coffee beans empty
Hi
If the big knob in the bean hopper is on a small #, that could be your problem. try opening the knob to the largest # and try again. If it clears and makes a cup, then on the next cup, while the grinder is operating turn the knob down again, but to a larger # than you had before. Grounds can get compacted in the chamber and prevent new grounds from entering. That is why it grinds but doesn't make a coffee. If that doesn't help, try opening the door above the brew unit funnel when the brew units is out. It should pull down on a hinge. This is the clicking you hear when you make a coffee.
Posted on Oct 20, 2009
EsWorld
  • 1618 Answers
SOURCE: coffee beans empty but not
Could Be one of 2 things, the grind is set too fine and the beans are not getting to the millstones, or there is something blocking the chute for the grounds.
Posted on Dec 31, 2009
Bean hopper is full, machine starts to grind the coffee but right before it starts to pull the shot, it stops & says "add beans to hopper".
the add beans to hopper signal most likely is triggered by the machine not sensing enough load put on the grinder (hence it thinks its out of beans) , this most likely is set by the grind (fine/course ) id say the grind is set to an improper size and the automatic sensor is picking up on that
another thing is the coffee / if its way too moist and not dry enough then its also going to trip the sensor as well
Feb 26, 2016 | Coffee Makers & Espresso Machines
My Gaggia Unica won't grind the coffee beans, it just whirs and stops making the drink
More than likely the machine is stuffed with coffee grind. Need to take it apart and clean it. See https://www.youtube.com/watch?v=JQbP2v8C-sA
Sep 20, 2014 | Gaggia Unica Bean To Cup Coffee Machine
I use an oily bean with my Gaggia Brera which has the integrated grinder on it. I know this may eventually clog up the grinder; and so, is there a way to clean the grinder without taking it apart? Is...
Oily beans means the coffee is old and/or over roasted. I reccomend using fresher beans. i recommend buying less coffee more often. i usually use a paper towel and wipe out the "hopper" where the beans sit.. hope that helps
Mar 07, 2011 | Gaggia Expresso Machine
My machine is having a problem grinding the coffee it is gringing it but very slowly
HI
Its probably set to fine in the bean hopper. The big knob in the bean hopper should be set around 8. If its lower than that you need to turn it up. If you have 2 knobs in the bean hopper you can turn the small knob towards the + side, but not all the way for stronger coffee.
Jan 15, 2011 | Gaggia Syncrony Logic 74884 Espresso...
Grinder does not stop
I need more information to solve this.
If you mean the grinder just spins but doesn't seem to be grinding anything - and then after 30 seconds or so it tells you the bean hopper is empty - then the problem is sticky, oily beans that aren't sliding down into the grinder.
You want to buy freshly roasted (roasted less than a week ago) beans. Coffee beans from the supermarket are old, stale and sticky with rancid oil. Even Starbucks and Peets - although the sign says "roasted daily" if you read the fine print, the beans in the store are rotated out 90 days after roasting. The oils turn rancid and get sticky after a couple of weeks so you really need to get beans from a local roaster or order them from a roaster who ships them fresh.
I have been using RedBird espresso blend and these beans work perfectly with this machine. They also are the best tasting of any espresso blend I've ever tried. The price is reasonable (cheap even) and the roast date is written on the bag. I get my beans 2 days after they were roasted.
http://redbirdcoffee.com/redbirdespresso.html
In the meantime, until you get some coffee beans that are not oily, you can stir the beans in the hopper. Use a wooden coffee stirring stick or a chopstick and just lift the hopper lid and stir the beans so they slide down into the grinder. You will probably have to do this before each coffee and maybe even 2-3 times just to get one coffee.
Once you get some fresh roasted beans that don't have that oily shine to them you will be grinding without any problems.
Oct 22, 2010 | Gaggia Titanium Espresso Machine
Grinders do not always work and seem as if they are worn
The titanium doesn't like oily beans. Best results with fresh roasted beans that don't have an oily shine to them.
The workaround when beans won't go through the grinder - have a wooden coffee stirring stick (or a chopstick etc) and stir the beans in the hopper so they get down into the grinder.
Sep 27, 2010 | Gaggia Titanium Espresso Machine
Coffee beans empty but not
Dec 31, 2009 | Gaggia Titanium Espresso Machine
Gaggia titanium coffee beans empty
Hi
Oct 20, 2009 | Gaggia Titanium Espresso Machine
Bob,
Thanks for the help but I was well past that stage. After cleaning half a dozen times, changing beans three or four times, soldering the contacts on the switch, changing it, replacing the whole doser flap sled and anything else I could think to do I finally fixed it. It took me months but in the end it was the doser trap door not allowing the dozer flap to move back and hit the switch when the grounds came down. A simple light bending out fixed it. So...we had a rare mechanical issue. The machine does have a design flaw in that it has a long three inch shoot for the grounds which makes it susceptible to clogs. Do not use oily beans!
Feb 20, 2008 | Gaggia Titanium Espresso Machine
Gaggia Unica Bean To Cup Coffee Machine Logo
44 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
