Question about Magellan GPS
Where is reset for Magellan Roadmate X13-12056 GPS
No Power, nothing. Was working fine and then one AM - nothing!
5 Suggested Answers
  • 1111 Answers
SOURCE: My magellan GPS Roadmate 1400 hard reset
there is a little pin hole on the side on the unit. you need a paper clip to reset it
Posted on Jun 15, 2009
  • 3 Answers
SOURCE: Magellan roadmate 300 wont turn on!
I think the problem is with the internal power jack which tends to break. the part is MG361213 and is available at laptopjacks.com. You have to take the Unit apart and remove the old jack and resolder the new one which is a three pin unit.
Good Luck
Posted on Jan 26, 2008
SOURCE: GPS Magellan RoadMate 360 no sound
http://rapidshare.com/files/96200369/sound.rar.html
Sound files for 360
Posted on Nov 15, 2008
stephen_sher
  • 6 Answers
SOURCE: magellan roadmate sd card error
I had a similar error and I fixed it. That is, as far as I know...
Here's my theory: The SD card is acting like it has an error on it. This often happens when it is removed improperly.
HERE'S HOW TO FIX IT:
  1. Remove your SD card from your GPS
  2. Insert your SD card into an SD card reader or connect it to your PC
  3. Wait for windows to go through it's process of discovering your the "removable storage device" your just connected (see step 2)
  4. (This step may be different depending on what version of Windows you are using or depending on how you have your OS laid out). Look at the lower right hand corner of your desktop. There should me a small icon there with a green circle and a check mark. It looks like this...877f33f.jpg
  5. Click that with the right mouse button.
  6. It will say "Safely Remove Hardware" - Left click that message.
  7. A window will pop up allowing you to select your SD card and "Safely Remove" it (it will have a letter name like "drive F" for example).
  8. Wait for the windows to tell you it is ok to remove your hardware - then remove your SD card form the PC
  9. Make sure your GPS is turned off.
  10. Insert the SD card into your GPS.
  11. Turn on your GPS
  12. That's all! I hope I was able to help.
IF THIS HELPED, please leave a comment indicating that it did! If it did not help, please let me know that as well.
Posted on Jul 17, 2009
My magellan 1700 won't turn on, even after I reset it and put in a new battery
if you have a volt ohm meter see if theres voltage at the power adapter plug
May 12, 2014 | Magellan RoadMate 2000 GPS Receiver
Tip
How To Reset Your Magellan Maestro/Roadmate GPS Units
Factory Reset
Do not attempt to perform a factory reset on the Roadmate or Maestro GPS units by holding down both the "Reset" and "Power" buttons. This will cause the GPS unit to format its own hard drive. Doing so will erase all data, including the GPS software, from the unit.
  1. Locate the button marked "Reset" on the left, right or bottom of the unit.
  2. Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
  3. If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
If your Maestro GPS Touch Screen Doesn't work, try performing a Hardware Reset
  1. Remove the Magellan Maestro from the holding cradle.
  2. Hold down the "Power" button on the right side of the device, until the unit powers on.
  3. Straighten the end of a paper clip. Place the paper clip in the reset hole, located on the left side of the GPS unit. Hold down the "Reset" button for 10 seconds. Remove the paper clip.
  4. Turn the Magellan Maestro unit off by holding down the "Power" button. Turn the unit back on again. The device is now reset.
If your Roadmate GPS is locked up, try performing a Hardware Reset
  1. On the RoadMate, press + + - - + -
  2. The "hidden menu" will appear.
  3. From there, you can access the shell and perform a hard reset.
on Feb 15, 2011 | GPS
How do you reset a magellan roadmate 1220?
As a general rule, for Magellan RoadMate models the RESET BUTTON is on the right side inside a small hole; the use of a pointed object (tip of a pencil, a ball-pen, etc.) is required to apply pressure on this button in order to perform the RESETTING PROCEDURE.
You may also can try to hold down the POWER BUTTON for 10 seconds to power off the device; then repeat the same procedure (holding down the POWER BUTTON) for other 10 seconds to power on Magellan RoadMate.
Mar 08, 2011 | Magellan RoadMate 1220 GPS Receiver
Reseting the Magellan Roadmate 360 to the factory settings
Hello there:
here is a couple of linkds that i was able to retrieve hopefully they will help you ok
best regards michael
  1. [PDF] Magellan User Manual 3519k - Adobe PDF - View as html The Magellan RoadMate 800 is a vehicle ... segments totalling 360 degrees. Starting at the Prime Meridian (which is ... 11.2 Resetting the Magellan RoadMate ...www.magellangps.com/assets/manuals/MRM_800NA_en.pdf
  2. Magellan RoadMate 360 Manuals, Support and Troubleshooting - GPS Free download of Magellan RoadMate 360 User Manual. Troubleshooting ... Resetting the Trip Computer " • Viewing a Saved Trip Report " • Deleting a Trip Report " ...www.retrevo.com/support/Magellan-360-GPS-manual/id/421ag200/t/2 - 109k - Cached
  3. Magellan_RoadMate_360_North_America_Manual Documents_and_Forms ... Magellan RoadMate 360 North America User & Instruction ManualGet access the the ... Resetting the Trip Computer. Viewing a Saved Trip Report. Deleting a Trip ...store.payloadz.com/str-asp-i.388383-n.Magellan_RoadMate_360_North_America_Manual_Othe... - 189k - Cached
Sep 18, 2009 | Magellan RoadMate 360 GPS Receiver
My magellan GPS will not turn on or charge. I tried
these models and many other magellan model have issues with the power port failing..if you have a friend that has the same model, borrow his/hers and try the cradle on your gps and see if that works..im sure that power connection on that model is on the cradle.
Jun 14, 2009 | Magellan RoadMate 700 GPS Receiver
May 27, 2009 | Magellan RoadMate 1400 Car GPS Receiver
Magellan roadmate 3000t not working properly...
This happened to me, I had to send it back to Magellan for repair.
Mar 12, 2008 | Magellan RoadMate 3000T GPS Receiver
Does not reset location
I too have sometimes to wait for 20 mins before my Roadmate picks up all the satellites it needs. The problem is worse if I'm surrounded by buildings.
I have at last decided to bin the Magellan as it's been nothing but trouble and Magellan Support just don't seem to care to respond.
Am now getting a Tomtom Go series with all preloaded, maps/ traffic/ cameras - it auto updates each time it's put on its cradle attached to PC/internet.
Nov 07, 2007 | Magellan RoadMate 700 GPS Receiver
Keeps seeking but no GPS positioning
get a new unit like any magellan mastreo series or roadmate 800 ,i had a 700 they start having alot of problems after i did my research on here.
Sep 06, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700 can't power up 2nd time in car
Are you willing to part with it, I may be able to use it for parts denisdsouza@hotmail.com
Jun 19, 2007 | Magellan RoadMate 700 GPS Receiver
GPS Logo
1,910 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
