Question about Sharp XR-10X Multimedia Projector
Have power, but no image
I have the same problem, I have LED lights, but no image is being projected after replacing the bulb 2 months ago. Is it costly to replace the ballast? and, would a semi-experienced person in electronics be able to replace it?
  • Anonymous Apr 01, 2009
    apparently there are issues with the bulbs. I have replaced two in the last 9 months. There is a group forming a class action suit because of this issue.
  • christito35 Apr 30, 2009
    i would like the info for the suite mine also powers up but does not show an image
I have gone through two bulbs in the last nine months. When I was searching for an answer I found a website which is investigating a possibnle class action suit against Sharp because of poor bulbs. If anyone wants the info I can pass it on to them.
Posted on Apr 01, 2009
Http://www.lieffcabraser.com/defects/sharp-projector.htm
Here is the link to the website about the class action suit against sharp for faulty projector bulbs
Posted on Jun 11, 2009
TV turns on, hear sound but no picture. Bulb isn't coming on. TV goes off after about 2-3 minutes. Bulb was just replaced 5 months ago.
Need the model number of the set and also if any lights on the TV come on or blink when the picture goes out or not.
Feb 09, 2013 | Televison & Video
Had check fan no 2 on tv. I replaced. The bulb is about 6 months old as well. I power on both fans are working the bulb comes on but the tv shuts off after a few seconds before the picture even comes on....
U recheck the tv projection lamp connections,the door latch and the lamp door closed properly and tightly.Yes,if the tv projection lamp LED light indication "LAMP" word it is still flashing or staying on the tv projection lamp some how dying again.The tv projection lamp should be replacing it again.
Sep 02, 2011 | Samsung HL-S6188W 61" HDTV
I have a Panasonic PT-52LCX66 television that I bought just over 4 years ago. I have replaced the bulb for the second time just 3 months ago and now the set will just shut off after about 3 minutes of...
Tv making and have clicking sounds as tv shutdown as lights flashes?Yes.The board that call the Ballast board might be dying and dead soon.This Ballast board job responsible only are to ingnite the tv projection lamp only.
Jun 30, 2011 | Panasonic PT-52LCX66 Projection Television
Power light flashed red 4 times then repeats no pic,new bulb/fan!
Check the fan that cools the bulb. It is directly behing the bulb. It should turn on when the power comes on. It apparently has a safety to protect your tv(and home). mine is in the process of going out. looking for online solutions as we speak.
Jul 19, 2009 | Sony KDS-R50XBR1 50" HDTV
My tv sony kds-50a2000 dont tur ON
I have a Sony KDS-50A2000 50 in. HDTV Television. I just replace the lamp because I got the message that appeared on the TV. Lamp needs to be repaced. I replace with a Sony lamp and now TV cut off after 2 to 3 hours off watching the TV. Any Idea what is going on with this TV
Jan 02, 2009 | Sony KDS-50A2000 50" HDTV
Sony WEGA Large Projection TV
I sounds like the projection bulb has failed. I think there is a red lamp on the front that lights up when the bulb fails however.
This sounds very similiar to what mine did when the bulb failed about 2 months ago. Once the buld fails the TV will shut itself down and keep doing that until the bulb is replaced.
Dec 17, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Mitsubishi WD-62525 Red Status Light After Cap Replacement
which caps did you replace? As the normal repair for the first generation dlp is to replace the (4) 1000 uf caps. the (2) 2200 uf caps and the (2) 3300uf caps on the power pwb when you get the 34 error code.
Sep 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
PT-50DL54 panasonic 50" DLP
to get rid of "replace lamp" push the blue action button on the remote and the volumn down on the tv set for a couple of seconds. this has to be done at the same time, good luck.
Bob
Dec 09, 2007 | Panasonic PT-50DL54 50" Rear Projection...
Sharp XR-10X Multimedia Projector Logo
390 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
