Question about Kwikset Avalon Complete Lh Handleset Rustic Pewter
The Thumb piece fell off front door handleset. How do you fix this?
While trying to open the front from the outside, the thumb piece fell off. The pin that hold it in is either broken or missing. How do you repair this?
2 Suggested Answers
  • 59 Answers
SOURCE: kikset dead bolt is loose on front door from the outside...
there should be a small allen screw on the shaft of the thumb turn on the inside. loosen the allen screw, pull off the inside thumb turn and take a small flat blade screwdriver and gently pry on the edge of the cover. It will come off. the 2 screws are under the cover plate. If this helps, lt others know. thanks
Posted on Sep 24, 2009
How do I repair?
Sounds like the trigger achor pin ( roll pin) is broken. youll need a punch and need to drive it all the way through where the pin is make sure you get it all out.
Aug 23, 2015 | Air Tools & Compressors
How do I reassemble kwikset lock set LIP 5 SMT?
Contact:
Consumer Services
19701 Da Vinci
Lake Forest, CA 92610
1-800-327-LOCK
It's difficult to know without seeing it in person or with good pictures.
Aug 03, 2014 | Kwikset Locks & Locksmithing
How do I fix a Schlage deadbolt. B60 series will not unlock from the inside unless the key is inserted from the outside
With the door open, remove the interior trim (thumb turn) from the door, and using the key, turn the deadbolt to the locked position. Now re-install the thumb turn, in the locked position, and with the key removed see if you are able to unlock the deadbolt. I suspect that the tailpiece (part that sticks out of the lock cylinder and into the thumb turn) is not in the correct position.
May 02, 2014 | Schlage B60 Series Double SecureKey 5-pin...
My driver side door handle is broke on the outside and inside, I cannot get the door open to remove the panel.
You may be able to remove the front fender and drive the pins out of the door hinge.
Jan 01, 2014 | 2001 Chevrolet Tracker
My right front door outside handle will not work on my 2008 chevy express
the rod conecting to the handle could have fell off, or handle where rod conects is broken
Feb 02, 2013 | 2008 Chevrolet Express Passenger
Why won't the door latch extend fully anymore? It extended fully for a few days after being installed.
Why does the interior knob or lever on my front entry handleset sometimes cause the latch mechanism to jam and the exterior thumb press to lock in place?If the front entry handleset is newly installed, the latch mechanism may be binding. If the exterior handleset is left sitting in the bottom of the bore hole through the door, the rectangular spindle that extends through the latch may be somewhat tilted and binding. This can be checked by loosening all screws, slightly lifting the exterior handle, and then tightening the screws before releasing the handle. This may make the spindle more level with the latch and eliminate the binding. If this does not resolve the problem, or the handleset has been installed for some time before the problem occurs, the latch mechanism may be failing and need to be replaced.
May 03, 2011 | Schlage FE365-CAM-ACC Lifetime Polished...
We have the thumb press elongated handle on the outside of the front door entry. I was ready to enter the front door when I pressed the thumb handle and the whole set fell apart. Need instructions to put...
For the Lido Keyed Entry, go to this page:
http://www.kwikset.com/Products/Details/Door-Levers/740LL-26D-SMT.aspx
and click on "Installation Guide", found under the red text " Technical Documents"
If I've steered you to the wrong lockset, the product main page foe Kwikset can be found here:
http://www.kwikset.com/Products/Categories/Handlesets.aspx
Feb 13, 2011 | Kwikset 4 Lido Lh Passage Levers Satin...
Left drivers door will not open from inside it does open from outside how to repair
you will need to remove inner door panel, either the handle itself broke where the rod connects,or the rod fell off or broke at the door latch, or the door latch lever bent or corrodded, the outer and inner handles use the same door latch but not the same mechanisms or rods to operate the latch. Once you remove the door panel and the inner dust shield with the window up look in the bottom of door for clips or a rod or broken parts. and note latch and handle for boken or bent and missing pieces. once you start looking it all becomes self explanatory.
Jan 15, 2011 | 1999 GMC Suburban
Kwikset Avalon Complete Lh Handleset Rustic Pewter Logo
344 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
marty morrison
marty morrison
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
