Question about Panasonic Televison & Video
HOW DO I CONNECT OUTSIDE ANTENNA TO PANASONIC TH-50PHD6
USING CONVERTER BOX TO HOOK TV TO OUTSIDE ANTENNA
SOURCE: converter box
1) Connect the coax cable from the antenna to the converter box input.
2) Connect the coax cable output of converter box to the input of the VCR.
This is the only way it will work but you will have many limitations such as using the programming features of your VCR.
The boxes are fine if you want to play prerecorded DVDs or tapes. If you want to record tapes you have to leave the box on and have it set to the station you want to record.
Posted on May 30, 2008
SOURCE: Hook up Converter box
if you have cable or satellite, you do not need these boxes
Posted on Jun 13, 2008
nickstorm
  • 93 Answers
SOURCE: GE Spacemaker TV/Radio combination Model #7-7650
Yes, you will need an external antenna to pull in the digital signals. It will not work with the built-in antenna on the GE. Alternately, you can use an external antenna (ie, rabbit ears), connect them to the converter box, then connect the converter box to the antenna jack on the back of the TV (I think it has one). Granted, not an elegant solution for a kitchen TV, but it beats not using it anymore.
Cheers
Posted on Nov 11, 2008
  • 280 Answers
SOURCE: don't know if it's digital transmission ready
If the set was made in the last 2 years it should have the digital tuner.
Posted on Jan 30, 2009
glenmann62
  • 91 Answers
SOURCE: How I hook up an XBOX 360 to digital converter box
you don,t , the xbox 360 will have component cables and posibly an hdmi output , but you can plug the component cables directly to the tv in a auxillary input and on your menu screen it will either say video1 or video2 or video 3 ,you can put the cables from your xbox into those inputs on the tv and as long as your tv is also at that input you should have a signal , hope this helps ,glenn
Posted on Mar 03, 2009
Have Panasonic The;37pw5 plasma tv . How do I get broadcast tv?
You will need some sort of digital (ATSC) to analog (NTSC) OTA signal converter (set-top box) with an antenna. The Panasonic TH-37PW5 only has NTSC (in the US) or PAL (UK) tuners. There may be a few low power NTSC stations still broadcasting in the U.S. However, you need to be close to their transmitter to receive the signal. You can use one of the original converter that were available with the government coupon. There are some newer models available. Look at your choices carefully. You will need a converter with RF, composite video or component video output. Any model with only HDMI out will require an additional converter connected between the set-top box and the TV.
The specifications for the TH-37PW5 are available on page 38 of the manual. This is available from Panasonic here: ftp://ftp.panasonic.com/television/om/th-42pw5_en_om.pdf .
I hope this helps.
Dec 14, 2016 | Panasonic Televison & Video
IS RCA DIGITAL TV CONVERTER BOX DTA880 COMPATIBLE WITH ANALOG MAGNAVOX TV COMBO MWC24T5B?
they sell those cable adapters almost every where tv antennas & cables are sold even home improvement stores like home depot and Menards
Sep 22, 2015 | RCA Televison & Video
Have a Panasonic TH-37PX60U tv - can I hook it up to a HD Satellite receiver - have a Bell hd but don't get any reception
Your plasma tv will display HD content when you connect an HD source (Blu Ray Disk, Sony PS3 / PS4 or Xbox 360, HD Cable Box, HD satellite, etc) via the TV's HDMI1, HDMI2, Component1, Component2 jacks or if you connect a UHF/VHF TV antenna (not cable box, etc.) to the "Ant" connector *and* you're close enough to a broadcaster with HD content to view.
Using any other input will produce only the lesser quality SD video signals. Review the manual - linked below - to help you connect the components you have.
http://service.us.panasonic.com/OPERMANPDF/TH37PX60U.PDF
May 13, 2015 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Can I connect two tv to one television converter box to watch local channels
If neither TV has a digital TV tuner, you will only be able to watch one channel on both TVs with one converter box. You will also need some sort of RF repeater if you want the person in the second room to change the station without moving the box. You will need a splitter/amplifier connected to the converter box TV out. (I'll assume you are using the coax out.) If you will only watch one TV at a time, then use an A/B switch on the converter box TV out.
If one of the TVs has a digital tuner, put the splitter/amplifier between the antenna and the converter box and the TV with the digital tuner.
Note: amplifier/splitters and switches do fail. If you get a "no signal" message, take out the splitter and connect the converter box directly to the antenna or one of the TVs depending on your set up.
I hope this helps.
(I use an A/B switch between the antenna and the TV and converter box for feeding an old VCR/DVD recorder.)
Mar 08, 2013 | Televison & Video
No antenna port for Olevia TV How do I connect outside antenna to Olevia monitor
you will have to use a VCR, DVD player that has a built in tuner, or an HD converter box. The HD converter box will have an antenna connection for the outside antenna. But will also have RCA outputs to connect your TV to the converter
Feb 05, 2013 | Olevia 237T 37 in. LCD TV
Do i need a converter box for my rca true flat 27 in? if not how do i connect a digatal antenna i have lost my manual
Your TV will require a Digital Converter Box to recieve over the air Digital Television Signals. You will need to hook up the antenna to the converter box and then hook your converter box to the TV. Hooking your television directly to a digital antenna will not get you Digital signals...only analog signals.
Jun 25, 2010 | RCA TruFlat 27F520T 27" TV
Connect to Converter Box
There are a fews ways of accomplishing this.
On the back of your converter box and TV/VCR there are two coxial connections an (OUT) and an (IN):
Step 1. Connect the coxial cable from the antenna to the (IN) connection on the back of the converter box.
Step 2. Connect one end of a spare coxial cable to the (OUT) connection on the back of the convert box.
Step 3. Connect the other end of the Coxial cable to the back of your TV.
I hope that you find this solution helpful. Please take a moment to rate tis solution.
Jan 19, 2009 | Panasonic Televison & Video
Cheers
Nov 11, 2008 | GE Televison & Video
Hook up old tv antenna to converter box
how do you hook up a tv with just screws to a converter?
May 27, 2008 | Televison & Video
Televison & Video Logo
88 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
