Question about Western Digital 160GB MyBook Essential Edition 160 GB USB 2.0 Hard Drive
HARD DRIVE DISK DOES NOT SHOW
WHEN I TURN THE COMPUTER ON THE LIGHT ON MY HARDDRIVE COMES ON BUT THE DISK DOESN'T SHOW ON MY MAC SCREEN.DOES THE EXTERNAL HARDDRIVE NED REPAIR
I have the same problem
Posted on Jan 12, 2009
Dell latitude d600 setup screen
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
May 11, 2013 | Computers & Internet
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
http://www.xbitlabs.com/misc/picture/?src=/images/storage/wd-passport-250gb/p3.jpg&1=1
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
http://www.xbitlabs.com/articles/storage/display/wd-passport-250gb_2.html
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
Solution?
Simple.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
Acer Aspire 5732Z won't turn on - the light comes on for a few seconds and then turns off - whilst the light is on the disk drive will open - the screen doesn't show anything
Could be bad ram,hard drive or possibly a bad display panel or video card.Try using different ram and removing the hard drive then try it.Also,connect it to an external display and see if it shows video or not.If after trying these things it still isn't showing let me know and i'll try to help more.
Nov 22, 2011 | Computers & Internet
Hey my Buffolo harddrive wont show my files, i can see that there are files, i have used 180 out of 200GB, but when i click on my harddrive icone on my computer it sayd folder is empty.. PLEASE HELP
There are generally 2 formats for Hard drives, the NTFS for windows and the FAT 32 for MAC. If you previously used windows then mac wont see it and vice versa. You can check this by right clicking and see the properties. If you want Mac to back up as well as using it on windows, you need to partition the Hard disk by going into the Mac Applications folder then select Utilities. If the Hard drive is connected you should see it and can select erase from the menu tab to format the disks according to your needs. This solved my problems and I hope this helps.
Apr 10, 2011 | Buffalo Technology DriveStation HD-HC500U2...
Hi I cannot access my buffalo portable hard drive series HDPX320U2 can you help please?
If you have already attached your external hard drive to the computer and already installed the driver disc that comes with your portable hard drive (if one is provided, sometimes one is already installed in your harddrive) and you get nothing when looking in the "my computer" for your portable harddrive, it could be a issue with your portable harddrive, First check to see if proper connection are made and are fully connected. Check your portble hard drive if you turn it on and the power light is on. If you still get nothing then your harddrive disk is either bad or your harddrive enclosure is bad. If you know how to take your harddrive disk out, and connected to a computer usually via a sata cable and see if the computer detect it that way. If you done this and get nothing, then yup your harddisk is history. If you have extermly important files, such places as bestbuy, office depot, will do a recovery for you, which can cause up to couple of bills large for the amount of recover data they get you. More data, more money.
Jan 27, 2011 | Computers & Internet
The icon for my lacie exyernal hard does not show
Here's two suggestions. (If your using Mac OS X 10.x)
Make sure external hard drives are to be shown by clicking "Finder" in the menu bar then "Preferences" and under the "Sidebar" section selecting "External Disks".
Also check that the hard drive is mounting by opening "Disk Utility" by first opening the "Applications" folder then the "Utilities" folder and double clicking "Disk Utility" and in the left sidebar checking to see if your external hard drive is listed as one of the mounted drives. Hope this helps, don't forget to comment/vote if this helped. Thank you.
May 30, 2010 | Apple Computers & Internet
Blue screen after logging into adminstrator but no desktop icons?
Start with OS X cd/dvd. put the cd in and restart, hold down C after you turn the laptop on. when the disk starts up, try to repair the hard drive (verify and repair permissions). I'd also try getting your hands on Disk Warrior, which can fix lots of hard drive problems. You might have to reinstall OS X though if it's bad. If you have to do this, you may want to upgrade the harddrive because that might be what caused the problem in the first place. If you go to repair permissions and it finds problems and repairs them. Try it again. If it finds problems the second time, you may have a bad hard drive. See how my answer is longer than your question. It really helps to provide details and specifics if you want a good answer. just keep that in mind if you reply. thanks. good luck.
Apr 06, 2009 | Apple Computers & Internet
Harddrive is not recognised by my Mac OSX (10.4.8)
When you reboot and hold down the option key, does the drive show up during that initial process? Is the weird noise more like clicking or more like a high-pitched whirring? If the drive has been damaged on a hardware level (causes too numerous to list... age, power fluctuations, being knocked over or dropped, corrosion, poor workmanship...) and won't show up at all, it is probably now a paperweight. There are a couple of utilities available to troubleshoot disc problems for Macs. The most popular are Disk Warrior and Tech Tool Pro. They can often "see" a disc that Disc Utilities misses, and assist you in copying the data from the drive. This process is important to be cautious with, however, since your drive is making noises it should no longer be considered reliable and the best hope is to retrieve your data and then get a new one or have yours replaced [if it is under warranty].
Aug 12, 2007 | SmartDisk Crossfire Desktop (xf160f) 160...
Western Digital 160GB MyBook Essential Edition 160 GB USB 2.0 Hard Drive Logo
192 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
