Question about Ricoh Aficio CL3500N Laser Printer
What does "replace black pcu" on a Ricoh SP-C410DN printer mean?
drichards
  • 87 Answers
SOURCE: Ricoh SP C410DN error code SC306
Reaseat the cyan photo conductor
Posted on Feb 23, 2008
Unfortunately the newer ricoh equipment may include a chip like the HP toner. This allows the printer to track the usage so the printer can "intelligently" determine how much toner remains in the bottle. The chip overides all other factors on the remaining toner. Hence, if the chip "thinks" that the toner bottle has little or no toner left, it will give you a false toner low message. Presently, you can only replace the toner with a new bottle.
Posted on Oct 30, 2008
  • 111 Answers
SOURCE: cannot faind Ricoh Aficio SP C410DN Laser Printer driver
you can find the driver here http://www.ricoh-support.com/enduser/downloads/downloads.asp?fileid=11540&ricohmodelid=6342&url=http%3A%2F%2Fsupport%2Ericoh%2Ecom%2Fbb%2Fhtml%2Fdr%5Fut%5Fe%2Fre%2Fmodel%2Fcl410%2Fcl410en%2Ehtm
Posted on Mar 21, 2009
  • 95 Answers
SOURCE: Ricoh Aficio SP C410DN "set toner cartridge correctly"
It sounds like the part the toner bottle slides under to lock in place is broken. you could try and fold some paper and tape it to the toner to hold it down.
Posted on Apr 23, 2009
  • 161 Answers
SOURCE: not printing double sided
check the driver
does not print from bypass tray (manual feed)
does not print on thick paper (check paper type)
Posted on May 06, 2009
Error sc 366
TD sensor: Output minimum error [C]
Defective connector connection
Decreasing toner density
1. Replace the CYAN PCU.
Apr 14, 2013 | Ricoh Aficio SP C410DN Laser Printer
SC366 on SP410DN
This is a TD sensor output error.
Causes:
Defective connector
Replace the Cyan PCU.
Mar 01, 2013 | Ricoh Aficio SP C410DN Laser Printer
I have a ricoh c410dn and it has an sc364 error.
sc364 is a black toner density error. Typically, replacing the black PCU will get rid of the error message.
Feb 18, 2011 | Ricoh Aficio SP C410DN Laser Printer
I have an Aficio SP C410DN with error code SC361. Any ideas what that could be? thanks.
Hi, SC361 is a Toner Density error in the Magenta PCU. Your best bet is to replace the Magenta PCU.
You could go in to the service menu, if you now how and do a TD Initialize on the magenta PCU - Service menu 3.801.004, but it may still not resolve the problem.
Go with the 1st, hope it helps.
Dec 27, 2010 | Ricoh Aficio SP C410DN Laser Printer
I am getting an error message: replace PCU: color soon and my printer is not working at all. What does this mean?
you must replace all 3 color Priter Cartrige units, approx. $600 cost; slide in from left side of machine
Jul 27, 2010 | Ricoh Aficio SP C410DN Laser Printer
Error code sc490 on aficio sp c410dn
SC490 High Voltage Power High voltage output error Error signal is detected for 10 times consecutively. One of the DC bias outputs for each PCU is shorted or one of the transfer belt bias outputs for [Y], [M] and [C]. • Power leaking • Defective connection • Disconnected cable • Defective PCU • Defective High Voltage Power 1 1. Replace the High Voltage Power 1. 2. Reset the cables and components. 3. Replace the PCU.
Feb 11, 2010 | Ricoh Aficio SP C410DN Laser Printer
Ricoh Aficio SP C410DN toner error.
Did you follow the instuctions to shake gently then remove all tags prior to placing the toner? Is it a toner/drum unit. look underneath if theres a green drum. After market toner will not work.
Aug 16, 2009 | Ricoh Aficio SP C410DN Laser Printer
Color Laser Printer prints a streak
Usually a yellow streak would mean the yellow pcu needs to be replaced. You can order pcus from a dealer and put it in yourself.
May 11, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh c410dn sc307
That crosses over to the Lanier LP226cn.
SC307 - Charge AC bias error [Y] (Level D Error)**
Symptom: The charge current less than 200 ìA is detected.
Possible Causes / Required Actions:
• Defective charge roller
• Defective connectors
• Disconnected harness
• Defective high voltage power 1
1. Check the connectors.
2. Replace the PCU for yellow.
3. Replace the drum positioning plate.
4. Replace the high voltage power 1.
** (Level D Reset Procedure) Turning the main switch off then on resets SCs displayed on the operation panel. These are redisplayed if the error occurs again.
- Lanier Tech
May 21, 2008 | Office Equipment & Supplies
Ricoh Aficio CL3500N Laser Printer Logo
23 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
