Question about Microwave Ovens
KOT 152 UB parts
I need to get Vent grill; Touchpad and door of Ewave KOT152 UB
MicrowaveSvc
  • 9047 Answers
SOURCE: Ewave kot-131UB pops breaker
Yes, this is caused by either a bad door switch or a loose door or loose door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 18, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Ewave OTR Microwave Oven, Model KOT-153UW. Light
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 13, 2009
hiltonjug
  • 612 Answers
SOURCE: Ewave over the stove microwave fuse blows when I
The light is the only thing that comes on when you open door. You either have a shorted door switch (Micro switch) or a shorted bulb. You have either a shorted bulb or bad socket. From my experience, it's the bulb. Just because it may seem to start to come on when you open the door, it's most likely bad. At least it not expensive.
Please rate solution
Posted on Aug 28, 2009
Testimonial: "Thanks, yes the light comes on for a second then fuse blows. I'll replace it, thanks!"
taran_2005
  • 10515 Answers
SOURCE: Replace handle on Ewave microwave
A common Guide that would help you :-
http://www.applianceaid.com/oven-hinges.html
Generic Procedure on most of the Ovens :-
Set the door on the ground with the hinges facing up. You will need to push down on the hinges and extend them by hand. It's probably best to put something in the palm of your hand like a handle of a screwdriver so that you can push on the hinge and open it up (you will still have to push hard). When you open the hinge up you will see a tiny hole appear about the size of a pin head. You will need to stick a screw or something inside this hole so that the hing will not close again. When you have both hinges locked out you can then reinstall your door at about a 45 degree angle. Open the door up all the way and remove the screws or pins you placed through the door and then you can shut the door all the way again.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 19, 2010
SOURCE: How to replace the door handle on an Ewave KOT 170SW Microwave
Ewave KOT 170SW Microwave, it starts runs for a few mins. then stops. Shorter then time set for.
Posted on Dec 15, 2010
E Wave Above Range Microwave Model KOT152 UB
Please check your e-mail inbox. I answered privately this is detail.
For others, it may need circuit board repair. The service manual is here and the disassembly video is here.
Jun 09, 2013 | Microwave Ovens
The turntable on our Ewave KOT 170SW Microwave oven has quit rotating. Other than that the oven works fine. Any troubleshooting tips? If the turntable needs to be replaced, how big a job is it? I'm not...
i went to replace lite bulbs but didnt unplug it..removed cover and shorted out...now no lite and no turntable but does come on & heats food is it fixable.......ewave microwave kot-131uw....
Feb 28, 2011 | Kenmore 80412 Microwave Oven
you'll have to remove the molding and the handle clips in to place and also has to screws that hold it in place, after that reassemble the door outside trim.
Jan 19, 2010 | Microwave Ovens
Dec 10, 2009 | Microwave Ovens
Aug 28, 2009 | Microwave Ovens
Replace OTR Microwave
Thanks for responding. It is a EWave KOT-152UW. I think EWave is part of Magic Chef. I think it is the door switch. When I opened the microwave, the circuit breaker tripped. I reset the circuit breaker, and it worked for several days, but the last time, the microwave went dead. The reason I want to use the same bracket is it has through the wall (horizontal) venting to the outside, and I am not keen on trying to cut more holes.
Nov 04, 2008 | Microwave Ovens
Mar 13, 2008 | Kenmore 80412 Microwave Oven
Microwave Ovens Logo
29 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
