Question about Hotpoint Washing Machines
How to fit heat element on hotpoint wt761 - Hotpoint Washing Machines
5 Suggested Answers
  • 958 Answers
SOURCE: Hotpoint Aquarius Washer dryer WD64 Not Heating Wash Water
hi pw82,
its seems you're doing your home work. that cylindrical part is the thermostat itself. it should have a resistance in the range of kilo ohms. around 10 kohm to 25 kohms. you can try to change the range of your testing equipment so that you could be sure that te thermostat is really open circuit.
if there is no resistance, then that is the problem. if there is resitance in the kilo ohms range then it could still be ok and you need todo some further testing.
you can check for voltage presence at the terminlas of the heater. if there is no voltage then it could be the relay on the power board that supply voltage to the heater.
or the board itself.
i hope i was able to help..please rate me..tnx
drcool299
Posted on Jul 11, 2008
  • 323 Answers
SOURCE: I've had an issues on my Hotpoint WT761 Washing Machine tripping
take off the back and reset the overheat protection, it should be a little red button , maybe the unit was not reset when installed
Posted on Oct 03, 2009
SOURCE: hotpoint wt761 error code f-08
call in hotpoint
Posted on Oct 07, 2009
Testimonial: "a"
  • 1527 Answers
SOURCE: the tumble dryer on my
hello i'd check the heat sensors first there may be 2 of them you will need a multimeter to test them if 1 is faulty change both of them hope it helps
regards
shaun
Posted on Mar 11, 2011
I have flashing lights on Hotpoint WT761 washing machine when I turn it on?
SOURCE: have a hotpoint wt761 washing
http://www.recommendedbuys.co.uk/household-appliances/washing-machines/hotpoint-wt761.htm
as you can read in these site that is a grate problem with the model allso the company tech is talking about to chage the machine insted repair so all I can say is that you have problem with the computer board of the machine,
Oct 05, 2014 | Washing Machines
Hotpoint wt761
Crash on progrmming
Apr 08, 2014 | Washing Machines
My hotpoint wt761 is okay on pump out but nothing happening on spin and showing no error code
Could well be worn motor brushes if no action from the drum>Common fault on machines over 4....5 years old...Parts cost around £18....Fitting quite simple...Good luck
Apr 04, 2011 | Hotpoint Washing Machines
I have a Hotpoint Aquarius FDW 60 dishwasher. Crockery was with greasy smear on it. Since then the drying does not appear to be working. Seems the drying element has malfunctioned, can we replace this...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 08, 2010 | Hotpoint Dishwashers
Hi we have a black overcounter microwave..9 power levels it will not heat was wondering if have heating element
They are not fitted with a heating element, they are fitted with a magnetron. It sounds as if there is a fault with the magnetron.
Feb 17, 2010 | Hotpoint RVM1435 Microwave Oven
F-08 error message on Hotpoint Washing machine WT761? The original fault on the machine was that it was tripping out and taking out a resetable fuse in my fuse box a few seconds after turning the machine...
If it works fine with the heater off then i would say that fault appears to be element..the readings you get seem okay, put you meter onto megs and check, with wires off if you get electrical leakage between live and earth...Body....of element, it could be element is heating with no water in machine causing it to burn out..this is a problem with this machine...Wish you well
Oct 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Elements over heating on hotpoint ctd00 condenser dryer
Did you check the fuse in your unit ?
Check the fuse whether it is burned.
Mar 13, 2009 | Hotpoint Dryers
Have a hotpoint wt761 washing machine which is displaying a f-08 error code
as you can read in these site that is a grate problem with the model allso the company tech is talking about to chage the machine insted repair so all I can say is that you have problem with the computer board of the machine,,,,good luck and rate me
Jan 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
