Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
DOES NOT MAKE ICE AND RED TROUBLE LIGHT COMES ON
I HAVE A HOSHIZAKI MODEL IM 25CLE ICE MACHINE. I START THE MACHINE AND IT SOUNDS NORMAL HOWEVER, AFTER A WHILE IT SHUTS DOWN AND A RED TROUBLE LIGHT APEARS AND NO ICE WAS MADE. I CALLED A LOCAL REFRIGERATON SPECIALIST HE REPLACED A FUES AND RESTARTED THE MACHINE. IT DID THE EXACT SAME THING. THE SPECIALIST SAID HE WOULD HAVE TO REPLACE THE CIRCUIT BOARD AND IT WOULD NOT BE COST EFFECTIVE. GIVEN THE AGE OF THE MACHINE I WOULD AGREE IF THE CIRCUIT BOARD IS THE PROPLEM. IS THERE ANYTING ELSE I CAN TRY BEFORE I GET RID OF THE MACHINE?
    Scholar:
  • 89 Answers
Well if the repair man wasnt willing or able to reprogram it might be in your best intrest to replace the unit. nothing says you have to get new though. if you do a little searching you should be abelto find some great deals. if you need some help shoot me an e-mail on here
Posted on Jan 12, 2009
Hoshizaki ice machine will not power up
with not model or serial numbers, I can only suggest that it may very well be the "bin stat". This is a thermostat that has a sensing bulb that is in the bin and senses the ice when it touches it to shut down the machine. If this is bad, no power goes to the control board. Try jumping this out with a jumper wire and see if the machine comes on.
Dec 18, 2016 | Hoshizaki Freezers
Why did my hoshizaki ice machine stopped making ice?
bin stat is what is used to shut machine down. if it goes bad in any way, no power will go to the control board. Start there.
Aug 11, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Where is th float switch on hoshizaki ice machine
If the machine is a small self contained unit it is normally on the right side of the unit next to the water pump. It has two wires (usually red and black) encased by a grey cover.
Jul 16, 2014 | Hoshizaki Freezer Commercial Ice Machines...
My Ice maker doesn't make ice anymore
90% of ice maker problems are water related. Sounds like water may be continually seeping in from the inlet water valve (normal thing to do if the water level is low). This will not allow the water to get down to freezing temperature. You have to identify the reason that water is constantly running in. It's probably "leaking" out at the dump valve. Or does that unit have a float valve that may be leaking. Check your drain to see if water is leaking out during the freeze cycle.
Jul 07, 2014 | Hoshizaki Freezer Commercial Ice Machines...
The ice maker make too much ice
Too much ice is usually and indication that the bin thermostat is not functioning correctly. It has either come out of it's holder, is not calibrated properly, or has lost it function and needs replacing. The thermostat "Kills" power to the control board when Ice comes in contact with it and shuts the machine down. Hoshizaki says it should happen within 6-10 seconds of ice contact after the end of a harvest cycle. I would start there first.
Apr 09, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Hi i have km-320-mwh hoshizaki ice machine, this machine is discharging water in drain continuesly except when it is dumping ice is this normal ...too much water is being lost please help many thanks...
By looking at the model number it is a water cooled unit. It will dump water down the drain continuosly as that it how it cools the compressor. If it was a MAH it would be air cooled and no continuos dump of water.
Aug 09, 2011 | Hoshizaki Freezer Commercial Ice Machines...
I have a model # f-450 mah ice machine. After the bin gets full of ice it stops making the ice but the water continues to run and runs out of the machine. Any ideas on how to stop this?
Sounds like the water valve is stuck. Probably needs replacing. Turn off water after machine shuts down and see if water stops. If it does, water valve is most likely the issue.
Mar 01, 2011 | Hoshizaki Freezer Commercial Ice Machines...
I have got Hoshizaki Ice Machine which makes three beep sound every 2 second continuously. I turned off the machine. It looks it needs to be cleaned. Can anyone help me to resolve this problem so that it...
I am assuming that it has run two consecutive cycles. I would first clean the machine inside and out. it should drop ice once cleaned, if not then open up the control box and find out which lights are flashing. I am almost certain that once it is cleaned it will drop ice.
Jul 21, 2010 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki ice maker am-50bae . Made ice regularily--- filled ice bin half way...next day-- all ice melted away with no more new ice? next day shut off for 3 hours now o new ice.
make a few quick checks. If there are water filters on the system, be sure they are not restricked. Could be clogged. Next, check the bin stat. It usually is mounted in the ice bin. If it breaks or goes bad, it shuts down the machine. Start there and let me know if I can be of any further help.
May 19, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
154 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
