Question about Video Game Consoles & Games
Cannot open the xbox 360. I saw some tools made by Microsoft online for $8.97. However, the unit does not have any screws to open it with.
    Scholar:
  • 35 Answers
Step 1
If you're opening up a 360 you're probably going to backup some games. so take the tub your spindle of discs came in and cut a bit from the side of it and put it over the console as shown, then mark out where the holes are:
cannot open the xbox 360. - 1.1
... then make it into a key like this. the tabs need to be about 1cm long:
2.2
Then do the same for the other side and you'll get two xbox 360 case opening keys that look like these:
Step 2
Open the front of the console as normal and put a bit of newspaper or something inside the case to hold the front open a bit, then insert the key, push with a bit of force and you should hear it click acannot open the xbox 360. - 5.5the case will open:
5.5
... repeat for the other side and you're done!
6.6
Posted on Jan 12, 2009
  • Sheldon Scott
    Sheldon Scott Jan 12, 2009
    Since the images didn't work the first time, here they are:
  • Sheldon Scott
    (the above images are shown in the order they appear in the solution)
Hello, I have a problem with my Xbox 360 console. I'm attempting to open my Xbox 360 for the fifth time, and this time, one of the silver screws will not come out. When I use my power drill on it, it
I actually had a problem very similar to this, although it was with one of the black screws. If the screw i indeed stripped, CAREFULLY take a dremel tool and cut a small slot into the top of the screw so that you can use a flathead screwdriver to get it out. However, do this as a last resort.
Nov 18, 2011 | Microsoft Xbox 360 Console
My xbox tray wont open i have xbox open right now opens when it wants to
PROBLEM WITH YOUR XBOX 360 DVD DRIVE.
BUY A NEW ONE. MAKE SURE YOU THE ONE THAT IS COMPATIBLE WITH YOU XBOX
FOR EXAMPLE
XBOX
XBOX 360
XBOX SLIM
JUST GOOGLE XBOX THEN THE MODEL OF YOUR XBOX THEN DVD DRIVE.
BUY IT THEN BUY THE TOOL TO OPEN IT. (THIS IS VERY IMPORTANT)
DISCONNECT THE CABLES THAT WENT TO IT THEN REPLACE IT WITH THE NEW ONE
HERE YOU GO.
HERE IS THE LINK http://cgi.ebay.com/DVD-Replacement-Drive-Xbox-360-BenQ-VAD6038-TOOL-/170550438207?pt=Video_Games_Accessories&hash=item27b599293f
IT COMES WITH TOOLS. EVERYTHING REQUIRED.
CLOSE IT BEFORE TURNING IT ON TO STAY AWAY FORM RED RINGS(OVERHEATING)
PLEASE RATE IF THIS HELPED YOU
Apr 10, 2011 | Microsoft Xbox 360 Console
I put in a disc into my xbox 360 and i just keeps reading th disc and saying open tray, I open tray, put in disc and close tray, it reads the disk and just repeats message open tray?? Please help
You can do it yourself by opening the xbox 360 case and the dvd rom with a proper tools.. tighten with a screw (counter clock) right there!! (see the picture)
Feb 16, 2011 | Microsoft Xbox 360 Console
I can hear my xbox but can not see it.i've tried it on 2 different tv's and no picture. i have also tried new wires but still no picture.
As you have tried new wires, if you have some other TV at your place or some friend's place you may try connecting this xbox 360 to that TV and check if the monitor is compatible and to see whether the fault is with the TV or console.
However, I would suggest you to go through the following link, as it explains complete procedure to narrow down and troubleshoot the issue with pictures in it.
Do not open the console, as it could void your warranty.
http://support.xbox.com/support/en/us/xbox360/kb.aspx?ID=916158&lcid=1033&category=hardware
Further here is a link to customer care department of xbox 360
United States customers - Online console repair
Outside the United States - Online console repairNote: Online console repair service is currently not available in all countries and regions.
For information about how to contact Xbox Support directly, please visit the following Web site: http://www.xbox.com/support/contact This solution is absolutely FREE, please rate and give positive feedback. Thanks :)
May 09, 2010 | Microsoft Xbox 360 Console
When i opened my xbox 360, i saw that my laser isn't powerful enough to read the disc,,,it's like you don't see the red dot of the laser.... Any game that i put in it it say "Open tray" ... it was working...
I come across this problem myself and I fixed it by ordering a new Hitachi drive for my Xbox 360. I then took my Xbox apart and replaced the drive with my one I ordered online.
I wouldn't do that though, especially if you still have your warranty.
If I helped you out please rate me.
Good luck,
Brandonmxb
Dec 12, 2009 | Microsoft Xbox 360 Console
Xbox 360 disc reading problem
these are solution
clean the optical cd
or maybe that cd is corrupted
your disk or xbox 360 is damaged....try repair a disk drive..
Nov 26, 2009 | Microsoft Xbox 360 Console
My xbox 360 will not play any games, it says open tray so I do an close it but it will say open tray agin.
You need to replace the drive. Take it to an Xbox 360 Repair Tech. You can often find these people in Game Stores some even have same day repair.
You also can do this on your own. However it requires an understand of some rather technical work. Also you need a special tool to open up the Xbox 360.
Jul 13, 2009 | Microsoft Xbox 360 Console
My disc in my xbox 360 is not spinning
you can try to oil the motor with a "drop counter" instrument.
I think you should send your console to microsoft or replace it yourself if you cant oil it
Jun 20, 2009 | Microsoft Xbox 360 Console
Taking apart the xbox 360
You actually have to order a special kit to open it, Safely anyway. Another way is by brute forcing with a hammer and screw driver and basically any tools you can find that would be helpful.
Feb 04, 2009 | Microsoft Xbox 360 Console
360 elite top fan not working
take the xbox apart as much as you can then open up the xbox this will void your warrenty if you still have one then then undo the screws that allow to take the top case off and check the wire hasnt come loose or been burn in anyway if so replace it with another fan unit thyen put the consloe back together
Jan 22, 2009 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
