Where is the WPS button on my canon MX430 printer?
I am unable to locate the WPS Button on the printer when trying to set it up wireless to my lapton. I have Windows 2008. It looks like the printer is the default printer, however when I try to use it, it states it is offline?
SOURCE: canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
I have canon PIXMA ip3000. After power cut at night printer doen not print. I re installed the drivers but no result. When try to print message appears printer is offline. POwer button is flashing shorthly green after orange lights. Error code 5100.
Please advice what can I do urgently.
Posted on Mar 12, 2008
MerlinTech
  • 197 Answers
SOURCE: Canon iP4300 is noting "offline or no power" blinking orange light 3 times then turns off
maybe you have some driver issues..
go here, get new ones, re install
Posted on Jun 16, 2008
Rider On Way
  • 1679 Answers
SOURCE: HP Photosmart printer gives me
If your router does not has WPS button, there is another way to Enable it from Router configuration under wireless settings
If you enable the WPS option from Router, you will have to press the WPS option from printer for automatic setup of printer on wireless network.
If you are not able to locate it then the WPS on your printer is of no use ( to connect to router )
Instead, I believe you have wireless router and you want to setup the printer wireless on network.
This is touchsmart printer and it has a setup button
Press SETUP option
Press WIRELESS option
Check for Wireless Setup Wizard
If it has Wireless setup wizard, select it and continue to search for wireless router and enter your network key if your router is secured with a key.
Run the software disk on pc and choose wireless connection and continue with the rest of the installation screen to complete.
If this option is not available, you will have to setup the printer thru usb cable and make it wireless
Run the disk on your pc
Choose Network Wireless connection
It will prompt you to connect thru USB
follow the instructions and it will ask you to disconnect
Continue with the remaining instructions.
Posted on Oct 23, 2010
SOURCE: 1720dn Laser Printer: printer offline. unable to set online....
I Open my browser....I signed in to my router as administrator ....
Mine is 192.168.1.1 ....
I went to status in my router ....
Then to local network ....
Then to DHCP Clients Table ....
This is how I found what printer address the was.... Then I typed the printer ip address into my browser
Mine happened to be 192.168.1.105 ....
Yours will probably be different....That got me to the 1720dn printer menu ....I clicked on Configuration ....
I clicked on Print Server Settings
I clicked on TCP/IP
I clicked on Set static IP address.
I changed IP address from 192.168.1.105 To 192.168.1.125
and Submit....Now you can get to the printer menu at 192.168.1.125
Go to run....
Printers & Faxes
Right click on Dell laser printer 1720dn
Properties. Ports ....
Add port ....
Double click on Dell Enhanced TCP/IP ....
I named the port My dell laser 1720 dn....Where it said enter a single IP address or host name I entered the new address 192.168.1.125
the clicked OK ....
Properties....Ports
Choose your new port ....
Posted on Dec 02, 2010
  • 3 Answers
SOURCE: Wireless printer problem
Brother has posted a Network Connection Repair Tool on their site under downloads. Worked great to put my MFC printer back on line with my network.
Posted on Mar 13, 2011
Where/what is the WPS button on a CANON MX454 printer
The WPS button is not on the printer. This button would be located on your router itself.
If your router does not have a clearly marked 'WPS' button, please use the CD with your computer to perform the standard wireless installation.........
or try this link...
where is the WPS button
Dec 09, 2016 | Canon Office Equipment & Supplies
Where is wps button?
About 49,500 results (0.39 seconds) Search Results
    What is WPS and how do I use it to set up the printer on the ...
    https://support.usa.canon.com/kb/index?page=content&id...
    Jan 15, 2016 - Use the , , and keys to select WLAN setup , then press the OK button. The printer will search for Access Points / Routers. If a WPS-compatible ...
    where is the WPS button? - Canon Community
    community.usa.canon.com/t5/Printer...Support/...WPS-button/td.../8893
    Dec 27, 2012 - Hello dmlarsen. The WPS button is not on the printer. This button would be located on your router itself. If your router does not have a clearly ...
    How to perform the wireless LAN setup using WPS connection
    support-th.canon-asia.com/contents/TH/EN/8200685600.html
    Dec 10, 2009 - Press and hold the WPS button on the access point (for about 5 ... If the Printer Connection screen appears instead of the screen above, the ... images for Printers & Copiers Where is wps button
Jan 23, 2016 | Office Equipment & Supplies
I cannot find my WPS button on my Wifi printer. I have pressed WPS on router but no different
Dec 27, 2012 - It asks for me to push the WPS button, but can't find? ... Now I am afraid to unplug the printer and move it back to my desk because it will ... starting only 2 days back, it was daily "dropping" my wifi connection with my MacBook.
WPS access point - Canon Community
community.usa.canon.com/t5/Wireless.../What...WPS.../11819
Jan 19, 2013 - What and where is the "WPS access point" button required to set up wififor the ... What and where is the "WPS access point" reqired to use wifi for the MX432printer .... My WPS button is on my the back of my router (blue button) ... I have a tp-link model tl-wr841n and I can't find the access point in the router ...
Connecting your HP wireless printer ' Wireless Printing ...
Nov 19, 2015 | Computers & Internet
I am connecting my new canon wireless printer and it says to push the wps button for 5 seconds where is that button
Press the WPS button on your WiFi Router (if equipped) to automatically negotiate and store a secure password for the printer when opting to connect via WPS.
Oct 29, 2015 | Canon Office Equipment & Supplies
WHERE IS THE WPS BUTTON ON A MG5650 PRINTER, TRYING TO SET UP THE PRINTER AS WIRELESS
The WPS button is on most wireless routers.On the printer go to tools and wilan setup and hit ok after you push the WPS button on the router
Feb 07, 2015 | Computers & Internet
What is the wps button
If you're setting up for wireless connection, it's the button on your router, used to initiate communication with a new device/printer. It's usually marked WPS / RESET. Press it momentarily then press OK button on printer.
Aug 18, 2014 | Canon PIXMA Office Equipment & Supplies
On installing the canon pixma printer it says hold down the wps button what is this button where is it located
That would apply only if your modem (router) has a WPS (WiFi Protected Setup) button on it. It is located on the modem (if applicable), not on the printer. Hope this helps.
Jul 10, 2014 | Canon PIXMA MP600 all-In-One InkJet...
To adapt N300 Wireless Adapter, I need to press the WPS button on wireless router or gateway. Unable to locate WPS button.
The reason you may wish to press a WPS button is to connect to a WiFi network. The WPS button will be on the router, not on your computer. If no WPS button on the router you will need to enter the WEP/WPA password to connect to the router.
Nov 14, 2013 | Samsung Computers & Internet
What is a WPS button and where is it on canon pixma
The WPS button would not be on the Canon Pixma printer. It will be on the router (or wireless access point) if your router can search for devices to be connected to the wifi network. (Not all routers do this.) If you add a comment with the make/model of your router, I may be able to tell you where the WPS button is. (Usually it will be on the back of the router but the exact location will vary depending on the model.)
It's much easier to use the standard setup to connect the printer to the router. When you choose that option, you will see a list of identified networks (if they are set up to broadcast). Then you select the network and enter the network password. (This should be set up when you set up the wireless network. Note: a default password is set on most routers; this should be changed during the initial set up. I prefer to use a wired network connection to enable the wireless network and set the password.)
I hope this helps. Please add a comment with more information about your network for additional support.
Apr 22, 2013 | Canon PIXMA MX512 - Multifunction fax /...
I am having problems with setting up my printer (Epson TX710W) to run remotely from my router. When I attempt to setup the router it wants me to use it for internet connection but I am running my internet...
Hi Robert_fl657,
For any printer to run on the network (wired or wiireless), aside from just a router, you will need a print server. Now, since this printer has wireless capabilities, i am going to assume that you might have a wireless prinet server built in (WPS). If your wireless router does not have that function, i suggest you buy a wireless print server to accomodate the printer that you would want to hook up.
Possible Solution 1: Sync wireless printer with WPS button on wireless router
1. Try and locate the WPS button (if any) on the wireless router.
2. Once located, go to the network options on the wireless printer and select set up by WPS.
3. Once you have selected that option, the printer should be in a seeking mode. Select and hold the WPS Button down on the wireless router.
4. If all goes well, you should have established connectivity with the wireless router.
I hope the above information helped. Please do let me know if there are other queires regarding this. Also, pls remeber to vote for me if you find this solution useful. Thank you.
Regards,
Technomancer
Apr 04, 2010 | NetGear DG834G Router
1,185 people viewed this question
jasbo
jasbo
