Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Quicktime will not load on vista laptop dv9626us HP
Windows installer says
appdata%\micros-1\internal-1\is unavailable
(the hyphen symbols are squiggly lines I could not find them on my keyboard)
then uninstalls it?????
  • tracy13459 Jan 12, 2009
    well if that is so then what do I do????
    I have downloaded it a zillion times and they all can't be corrupt???
    Thanks
    Tracy
  • 449 Answers
Hello, the quick time player installer you are trying to install is corrupt.
Posted on Jan 12, 2009
Alright this may sound big but I have a windows vista hp operating system installed on my #1 hard drive. I am getting the blue screen error, and no longer cant fix it, so as in it's done. I bought an...
Make an clean installation of Win 7 and repartition your Hard disk.Use Genuine Windows 7 to avoid blue screen error.AVG 2011 is a very good antivirus.Use Hard disk sanitizer given in Bios settings.Use Tune up utilities 2011or System mechanic latest version.I think your problem will be solved
Dec 23, 2010 | HP Pavilion DV7-1020US Laptop
How to install the magic jack to window 7
To magic jack its works fine in windows 7, you should do the following things:
1. Copy the mjusbsp folder from a working install on XP or Vista to the C:\Users\UserName\appdata\Roaming folder in Windows 7.
2. Start it the no splash way to make it to load "C:\Users\UserName\appdata\Roaming\mjusb... ck.exe" /scf _magicJackPersonalDataRoot X:\magicJack
What's more, at the time of installing magic jack, do right click on the exe file and select the "Troubleshoot Compatibility". A window showing that Windows is testing the software. After completion it shows "Try recommended settings". Click on this settings that you will use. Click the "Start the program". Follow the on going instructions.
Nov 28, 2010 | Computers & Internet
When I try installing Itunes half way through installing a pop up comes up saying- "Could not access network location %APPDATA%\." Can u help me fix this.
Please take note that the following steps is in assumption that you are using a Windows operating system.) As I have found out in the iTunes support in apple.com, this symptom may be caused by anti-spyware software preventing iTunes from installing correctly. One such application is SpyCatcher. Before installing iTunes, temporarily remove this software to allow the iTunes installer to complete.
If you are still having trouble installing iTunes for Windows, follow the troubleshooting suggestions described in this article.
General installation troubleshooting Important: iTunes installation is successful a majority of the time after completing these troubleshooting procedures. If one step does not resolve your issue proceed to the next.
1. Empty your Temp directory and restart
Windows XP:
  1. Choose Start > My Computer (or double-click My Computer on the Desktop).
  2. In My Computer or Computer, open the "C:" drive.
  3. Open Documents and Settings.
  4. Double-click the folder titled with your username.
  5. If you see a Local Settings folder, skip to step 10. If you don't see a Local Settings folder, proceed to the next step.
  6. Choose Tools > Folder Options.
  7. Click the View tab.
  8. Select the option to "Show hidden files and folders."
  9. Click OK.
  10. Double-click Local Settings.
  11. Right-click on the Temp folder and choose Delete.
  12. In the confirmation dialog that appears click Yes.
  13. If you are unable to delete the Temp folder, close all programs, especially those in the Notification area ("System Tray") of the Windows Task bar and repeat step 11.
  14. Restart your computer.
Windows Vista and Windows 7:
  1. Choose Start > Computer
  2. In Computer, open the "C:" drive.
  3. Open the Users folder.
  5. If you see an AppData folder, skip to step 10. If you don't see an AppData folder, proceed to the next step.
  6. Choose Organize > Folder and Search Options.
  8. Select the option to "Show hidden files and folders." (In Windows 7 this option will be called "Show hidden files, folders, and drives").
  9. Click OK.
  10. Double-click the AppData folder to open it. If Windows needs your permission to continue click Continue.
  11. Double-click the Local folder to open it.
  12. Right-click on the Temp folder and choose Delete.
  13. In the confirmation dialog that appears click Yes.
  14. If you are unable to delete the Temp folder, close all programs, especially those in the Notification area ("System Tray") of the Windows Task bar and repeat step 12.
  15. Restart your computer.
2. Completely remove iTunes and QuickTime
For Windows XP, follow instructions in Remove and Reinstall iTunes, QuickTime, and other software components for Windows XP.
For Windows Vista or Windows 7, follow instructions in Remove and Reinstall iTunes, QuickTime, and other software components for Windows Vista.
Note: Songs you purchased from the iTunes Store or imported from CDs are saved in your My Music folder by default and are not deleted by removing iTunes.
3. Install the latest version of iTunes
Once you have completed the above steps to Empty your Temp directory, Completely remove iTunes and QuickTime, and Clean up iTunes installer files on the computer, you can install the latest version of iTunes from http://www.apple.com/itunes/download.
Additional troubleshooting Make sure you have administrator-account access To install iTunes or QuickTime software, you need to be logged in as an administrator on the computer. If you're not sure if you have administrator-account access, contact the owner of the computer or your system administrator.
Get the latest Windows updates The first thing to do when troubleshooting an installation issue on a Windows computer is make sure you have the latest Microsoft Windows updates installed—to get the latest updates, go to the Microsoft Windows Update page.
iTunes and QuickTime software for Windows require Microsoft Windows XP or Microsoft Windows Vista with latest Service Pack installed.
Disable other conflicting software In Windows, some background processes can cause issues for other programs and processes. These conflicts can prevent applications such as iTunes and QuickTime Player from installing. See Using MSCONFIG to troubleshoot conflicts in Windows XP or Using MSCONFIG to troubleshoot conflicts in Windows Vista and Windows 7 for assistance disabling conflicting processes.
Additionally, some third-party security software cannot be disabled using Selective Startup (MSConfig). Because of this, it may be necessary to temporarily manually disable such software while troubleshooting installation. For assistance in configuring or disabling your security software, please contact the manufacturer.
Make sure your folder names don't contain strange characters If the iTunes installer (iTunesSetup) is not responding or appears frozen after launching the installer then the folder where the installer is stored may contain unusual characters. If you notice that the iTunes installer or stored in a folder like this, either rename the folder or move the iTunes installer to another location such as the Desktop before launching.
More help If these steps don't help, you may be able to find a solution to your issue by searching the Microsoft support website.
If the above troubleshooting steps have not helped, proceed to the following steps Solutions to common installation errors Here are some common symptoms you may see when installing iTunes and QuickTime for Microsoft Windows. If you are experiencing one of these symptoms, try the suggested troubleshooting steps:
If you only need to install QuickTime, or if iTunes installs but QuickTime installation did not complete Try downloading and installing the standalone version of QuickTime from http://www.apple.com/quicktime/download/. Be sure you download the version that does not include iTunes.
Aug 06, 2010 | Apple iTunes
When I install Itunes this is the Error message I get verify access npitunes.dll C:\Program Files\iTunes\Mozilla Plugins\npitunes.dll
Windows XP:
  9. Click OK.
  9. Click OK.
Jul 29, 2010 | Apple iTunes
I need to turn off a firewall on my laptop and dont know how
if you are using Windows (Windows XP) Click on Start -> Settings -> Control Panel
In control Panel...you will see Windows Firewall, open it and choose the OFF option
Aug 26, 2009 | HP DV9626US Pavilion Notebook
Unable to update my protection after uploading new 2009 Micro Trend Internet Security package using a 64-bit operating system. Error message advises to check my proxy settings. I've done that. System is...
this is the resolution i got from trend micro regarding this error. it worked for me, so i thought i should share: I have reviewed your case and I understand that you are getting an error message that says “Unable To Update Your Protection” when updating the Trend Micro Consumer Product. With regard to your concern, this problem happens if there’s a missing component in your computer’s Registry. Let us configure the registry of your computer using the Registry Editor of Windows. Refer to the following. 1. Click on the Start button or the Windows Orb Button. 2. Windows XP: Click on Run then type regedit on the text field then click on the OK button. Windows Vista: Type regedit on the Start Search above the Windows Orb button then press Enter key on your keyboard. And the Registry Editor window will appear. 3. Click on the plus sign (+) or the arrow sign (>) besides HKEY_LOCAL_MACHINE. 4. Click on the plus sign (+) or the arrow sign (>) besides SOFTWARE. 5. Click on the plus sign (+) or the arrow sign (>) besides Microsoft. 6. Click on the plus sign (+) or the arrow sign (>) besides Windows. 7. Click on the plus sign (+) or the arrow sign (>) besides CurrentVersion. 8. Click on the plus sign (+) or the arrow sign (>) besides Explorer. 9. Click on the Shell Folders. 10. Look for the Common Appdata entry on the right panel. If there’s a Common Appdata entry on the list: - Double click on the Common Appdata entry and the Edit String window will appear. - Windows XP: Type C:\Documents and Settings\All Users\Application Data on the text field under Value Data. Windows Vista: Type c:\ProgramData on the text field under Value Data. - Click on the OK button. If there’s no Common Appdata entry on the list: - Right click on an empty space and options will appear. - Click on New and options will appear. - Click on the String Value option. - Set the name to Common Appdata. - Double click on the Common Appdata entry and the Edit String window will appear. - Windows XP: Type C:\Documents and Settings\All Users\Application Data on the text field under Value Data. Windows Vista: Type c:\ProgramData on the text field under Value Data. - Click on the OK button. 11. Close the Registry Editor window. 12. Restart the computer for the changes to take effect. After doing the suggested solutions, you should now be able to update the program successfully.
Jan 22, 2009 | Computers & Internet
Widows XP
(1) go to Hp.com - load load the necessary Xp drivers for your unit - burn them to cd - then aquire a replacement hdd - install Xp on that - install the required drivers and walla you have one hdd with vista and another with XP
Jan 21, 2009 | HP Compaq 6720s PC Notebook
Vista Premium on HP DV9626us laptop can't load programs
hello sir,
Do few steps,n all will b fine
1. go to control panel
2. click on classic view on the extereme left
3. go to user account
4. go to turn user account on off
5. uncheck(unmark) the statement n click OK
6. restart
now check
do reply if it is or not working
Abhinav
Jan 11, 2009 | Microsoft Windows Vista Home Premium with...
Microsoft Office Suite 2008
Do a "Complete" install - the next screen should give you the chance to select the items that you want to have installed on the computer.
Click on each one that you DO NOT want - select "Entire feature will be unavailable" - and leave Word alone.
Continue the Install process and only Word will be installed.
Good luck.
May 27, 2008 | Microsoft Windows Xp Home Edition English...
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
61 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
