Question about DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
Dish 625 shuts off without warning and fan runs high
Once a day, my brand new Dish DVR 625 will shut itself off and the cpu fan will run high. The green light under TV1 will stay on but that is the only light that will stay on. I have tried resetting it, unplugging it, and all the other useless stuff Dishnetwork has told me to do. They are sending another 625 to my house via UPS in a few days. I think it's the software, which is up to date, but I think it's buggy. It will eventually go to the aquiring satellite signal screen after turning itself off and on twenty times or so. My satellite signal is good and my outlet is good according to the technician. I am at a loss as to what to do.
  • 2 more comments
  • wellsrobk Apr 06, 2009
    I was hoping to make it through tonight without it cutting off during the NCAA Championship game. Anyway to extend its running time. Blowing cool air on it, raising it up on blocks...anything?
  • Anonymous May 02, 2009
    Dish 625 fan comes on itself and is on, what do I do to correct it from coming on...or why does it come on? Its very annoying,
  • newyorican79 May 06, 2009
    My DVR 625 shuts off unexpectedly and the cooling fan runs constantly. The power light also goes on and off. I've tried resetting it and unplugging without success.
  • Anonymous May 07, 2009
    Same thing here with my 3 month old 625. Just went into the blinking light of death mode.
  • 374 Answers
Unfotunately this is an event known as power cycling and the only resolution is another receiver. This issue is due to faulty internal components and has nothing to do with anything other than that fact. If you have further questions feel free to contact me. Thanks for using Fix Ya.
Posted on Jan 16, 2009
Why does my Dish Network DVR-625 DTV receiver sound like it is running all the time
The Dish 625 as with the other Dish DVR systems has a fan built into the back of the unit. The fan runs nearly all the time to keep the internal drive cool. Sometimes the fan sounds louder that normal. what I do from time to time is take my shop vac and or the small vac u you use to clean your computer. and clean the vents around the fan. I do this on my desk top computer also.. Hope this helps.
Sep 03, 2014 | DISH Network DVR-625 DTV Receiver /...
How do I get closed captioning on my 625 dish dvr.
Guest,
The 625 receiver does not have a setting to control closed caption. This is a setting from your TV itself. I would look at your TV manual to see how you can turn the feature on. I hope this helps.
Ray Calo
DISH Network
May 19, 2010 | DISH Network DVR-625 DTV Receiver /...
My Toshiba P35-S611 shuts down without warning a short time (2 min-45 min) after it boots up. The battery isn't hot but the heat dissipation fins in the back are very hot.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
May 09, 2010 | Toshiba Satellite P35-S611 Notebook
My laptop shut down after powering out with no warning and will not restart.... Toshiba L550 screen stays black but when I hit the enter key it beeps........any suggestions
“My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.” This complaint we hear from our customers over and over again. About 15-20% of all Toshiba laptops we get for repair, suffer from an overheating problem. Yep, OVERHEATING!
This is one of the most common problems with Toshiba laptops we deal with.
Solution:
May 04, 2010 | Toshiba Computers & Internet
My DISH Network dual dvr that I had a year started shutting down on its own. The lights would go off but the fan would still run on high. It would do this 15-20 times a day. Got a brand new dvr last week....
sudel9302,
That replacement receiver may be experiencing technical problems. I apologize for the inconvenience of having the 2nd receiver shutting on/off. If unplugging and plugging the receiver back into the electrical outlet hasn't resolved the issue, please call 1-800-333-3474 so we can either send a replacement or have a tech come out to your home. I hope this helps.
Ray Calo
DISH Network
Apr 08, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Laptop shut downon its own
Your fan has failed! Your cooler not working properly, clean your cpu-fan. Your CPU is over-loading temperature is too high without an working fan! This is your Problem!
Sep 03, 2009 | Lenovo 3000 C200 Notebook
DISH NETWORK RECEIVER 625 WONT STAY RUNNING???
Unfortunately, there is no way of saving your DVR, i would ask Dish for an upgrade to a Vip series rec, for example a 622 or 722 which can allow the use of an external hard drive. it also sounds like your root problem is with the voltage in the outet your dvr in connected to, try to plug directly into wall, if it is already, have an electrician check your voltage to prevent future issues.
Jun 25, 2009 | DISH Network DVR-625 DTV Receiver /...
My computer keeps shutting itself down without warning. I have live one care which prevents virus to pass through the system but the computer will stay on for a little while then shut off then stays on for...
It is possible this is caused by overheating. Check the power supply fan first, probably in the back of your computer tower. Do you feel any airflow? If so, the next thing to check would be the CPU fan/heat sink. Many motherboards have a temperature gauge software nowadays, or you can download one for free online to see how hot your CPU is running.
2 Possible solutions:
  1. Replace Power Supply if there is no air flow.
  2. Put in a new Processor Heatsink/Fan
Mar 12, 2009 | Computers & Internet
Hp pavilion shuts off after booting up
do you have an extra power supply?
if it has...isolate your power suply...so that you will know that your power supply work properly..
thanks........
Jul 26, 2008 | HP Pavilion a800n (PP163AA) PC Desktop
Lines on TV with DVR-625
try using a better cable from the receiver to the tv. sometimes less expensive cables dont "ground " as well as they should after a few years. the more shielding the better. the cable here will sell you the cable much cheaper then going to any store and its better quality, even if your not a customer of cable.
hope this helps
Mar 12, 2008 | DISH Network DVR-625 DTV Receiver /...
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
1,568 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
