Question about Whirlpool MDBH989AWS Builtin Dishwasher
MDBH989AWS dishwasher start button does not work
Start button is not working. The other buttons are lighting up, but does not start nor does the start button flash. First the problem was intermittent now it is a hard problem
SOURCE: Need help with dishwasher
I misplaced my diagnostics paperwork, but I found you here and you saved my life!  The wife is much appretiative!
~Teddy Bear
Posted on Oct 20, 2007
SOURCE: My whirlpool gold dishwasher GU180 wont start
I had the same problem with the exact same model - put your washer on the lowest wash setting - press and hold the start button for about 3 seconds. THe washer will run for about 5 seconds and then turn off (do not have the heated dry setting on when you do this).
Turn it off (turn the dial), and then try to re-wash.
Posted on Dec 27, 2008
SOURCE: whirlpool dishwasher # quiet partner II
Pushing and holding the 'Heated Dry' button should turn off the light over the padlock symbol and get you going again.
Posted on Jan 22, 2009
jsrock516
  • 5911 Answers
SOURCE: clean light flashing off and on dishwasher will not start
This may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Posted on Sep 09, 2009
jan mczeal
  • 632 Answers
SOURCE: 'clean' light flashes
Press the normal wash then heated dry buttons in the same sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the cancel button.It will clear any existing faults and makes the dishwasher to operate normally.
To prevent the issue from recurring, run your hot water faucet first to ensure that hot water is present in the entire supply line before starting the filling.
Posted on Oct 18, 2009
Kenmore Ultra Wash 665 dishwasher: start button not lighing
It sounds like you have a bad control console, and the problem is that your START button (the most critical one!) is bad. You can't replace just that button or key; you have to replace the entire control console.
Jul 02, 2012 | Kenmore Dishwashers
Dishwasher will not start
These get broken solder joints on the control panels which cause some buttons and functions not to work, If you are handy with a soldering iron you can re-solder the joints yourself.
Mar 07, 2012 | Maytag Dishwashers
Whirpool Dishwasher ADP5966 Turned dishwasher on. Only light that comes on is normal wash light. Start button is flashing when normal wash light is on. On pressing start button dishwasher does not work
Most likely the door switch is not making proper contact when you shut the door or the Start button is faulty. Needs someone to look in the door panel to fix.
Feb 15, 2011 | Whirlpool Dishwashers
Installed new dishwasher, everything works, but it will not fill with water MDBH989AWS
Hello- Check these things- 1- water to valve. 2-120v at valve when started. 3-Float assy and switch operate properly. Let me know if this info helps- have more if needed.- Thanks- ED
Mar 08, 2010 | Maytag Dishwashers
Kitchen Aid dishwasher will not start
Can not start KitchenAid dishwasher..."child lock" light keeps coming on. Help!
Aug 24, 2009 | KitchenAid Dishwashers
Dishwasher (Whirlpool ADP 952) not working
I have a whirlpool ADP 952 and the start button is flashing and it won't work
May 25, 2009 | Dishwashers
Cancel light and rinse only light keep blinking and wont start
Hopefully you have resolved your issue. I have not heard of the cancel light flashing issue. I have had problems with the clean light flashing seven times over and over and the control panel will not operate. Here is the solution to that. Maybe it will work for your issue as well.
Open dishwasher door,
Push Hi Temp Scrub button,
Push Saver Dry button,
Push Hi Temp Scrub button again,
Push Saver Dry button again,
All lights on control panel will come on.
Close dishwasher door,
Push Baked on Cookware or Normal Button.
Dishwasher should start and complete cycle.
It is good if you have kids that play video games. Their fingers are used to pushing buttons quickly. I guess this resets the control board. The service guy let me have this info as I used to deliver appliances and work on them somewhat.Hope this helps.
Good Luck,
Tom
Nov 26, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
Frigidaire Dishwasher GLDB957JS0 (built-in)
Door switch had to be replaced. Turn off circuit breaker first.
Feb 27, 2007 | Frigidaire 24 in. GLDB957A - Multiple...
Whirlpool MDBH989AWS Builtin Dishwasher Logo
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
