Question about HP® LaserJet M5035 MFP Laser Printer/Copier/Scanner/Fax/Digital Sending - Same Day
HP LaserJet M5035 MFP Offline issue - HP® LaserJet M5035 MFP Laser Printer/Copier/Scanner/Fax/Digital Sending - Same Day
Fixe_You
  • 1800 Answers
SOURCE: my printer name is HP
fixed the problem by removing the scanner cover and sprayed compress air on the scanner light bulb and cleaned it out.Put back together
Posted on Jan 22, 2009
  • 102 Answers
SOURCE: how to intalling network sanner HP LaserJet M1522nf MFP
If your printer is connected in the Network and you are able to print fine than there is no communication Error.
In htan case if you are not able to scan then you need to upgrade the firmware of the printer and install it and i m sure your printer wiill scan scanning on the Network.
Mentioned below is the link to download the latest firmware of the printer.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3442750&prodNameId=3442754&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-70811-2
However before you start sending firmware to the printer you need to make sure that printer driver is installed on the PC.
Thanks and Regards
Neeraj Sharma
Posted on Jul 01, 2009
  • 241 Answers
SOURCE: IS THERE A PROGRAM TO DOWN LOAD FAX NUMBERS FROM A
Fax numbers can be imported by csv file to the embeded web server of your M5035.
Steps
1.Export a csv file from Microsoft Outlook contacts. From file menu choose Import and export choose export to file then next, choose comma separated values then save to file location.
2.Next open the embeded web server (type the IP address eg. 19x.16x.0.10x in the address bar of a web browser).
3.Choose the digital sending tab at the top of the page.
4.Select address book on the left side of the page.
5.Then click browse and select the file saved in step one.
6.Choose import.
This will import the csv list of fax numbers into your M5035
Posted on Jun 11, 2010
SOURCE: how do I create a quick access folder on the hp
hi
it there in user manual
just refer you manual u will gind you solution
Posted on Jun 15, 2010
  • 143 Answers
SOURCE: scan note working (Hp Laserjet
Lets check whether windows detects your scanner
Right click My Computer > Manage > Device Manager
Under Device Manager check Imaging Devices
If there Double click Imaging Devices and check the device under that. If you find your scanner there .Then the scanner is installed properly
Now Lets try a test scan
If Windows Xp do this .
Click start > Run > Type wiaacmgr.exe press enter key
Now take a test scan
If your windows is vista / win 7 then
click start > All programs > accessories > Run
on Run window > Type wiaacmgr.exe press enter key
Hope this would work
Please rate me if you are satisfied with my answer
Posted on Mar 20, 2011
Hy I have a hp m5035 mfp showing 6050 turn off and on,pls how can I solve this?
Olaide,
Here is a link to HP Support. There you can find drivers, manual, issues/solutions and more for the printer.
Good Luck!
JP
HP LaserJet M5035 Multifunction Printer series
Oct 25, 2015 | HP Office Equipment & Supplies
Initializing scanner
Update the firmware
Restored factory defaults
Initialization of the hard disk.
If it still doesn't work try to clean the scanner head under the glass. Clean the lens with some alcohol but be careful not to scratch the lens.
Mar 12, 2013 | HP LaserJet M5035 MFP Printer
HP Color Laserjet M5035 get`s error 30.01.34
First, this model is not color laserjet, only black.
30.1.34 Cable error or loss of communication with the formatter.
1. Turn the device off and then turn the device on.
2. Make sure that the ribbon cable between the scanner control board and the formatter is not damaged and is correctly seated.
3. Make sure that the hard disk drive on the formatter is connected correctly and that the hard disk is functioning correctly.
4. If the message persists, replace the scanner control board or replace the formatter.
Aug 30, 2011 | HP LaserJet M5035 MFP Printer
How do i Print individual usage report on Hp laserjet M5035 mfp multifunctional Printer.
Usage page
Shows a page count for each size of
paper printed, the number of one-sided
(simplexed) or two-sided (duplexed)
pages, and the average percentage of
coverage.
1. From the Home screen, touch Administration.
2. Touch Information.
3. Touch Configuration/Status Pages.
4. Touch Usage Page.
5. Touch Print
Feb 21, 2011 | HP LaserJet M5035 MFP Printer
Unit only prints black and white. How do i get colors?
Purchase an HP CM6040 or HP CM4540. The m5035 is black and white only.
Jan 08, 2011 | HP LaserJet M5035 MFP Printer
Hp printer lj m5035 in 69.30 error
According to Hp official site,
A temporary printing error occurred.Turn the device off, and then turn the device on.
If this message persists, contact an HP-authorized service or support provider.
Goodluck
Dec 06, 2010 | HP LaserJet M5035 MFP Printer
How do I create a quick access folder on the hp laserjet m5035
hi
Jun 15, 2010 | HP LaserJet M5035 MFP Printer
My printer name is HP M5035 MFP LASERJET serial number cncxbo4735.it can't scan or photo copy error code 30.1.19
Jan 22, 2009 | HP LaserJet M5035 MFP Printer
HP® LaserJet M5035 MFP Laser Printer/Copier/Scanner/Fax/Digital Sending - Same Day  Logo
43 people viewed this question
Seeker5211
Seeker5211
