Sky code for LCD2010A
Code for sky remote
SOURCE: Sky remote code for LG 42LC46 tv
After spending hours on this I found that code 0206 worked on my sky+ remote(with LG 42LC46). On an old sky remote, prior to version 4 (inside the battery compartment), just use 206.
This code was actually for a LG 42PX5D but it works perfectly on my tv.
Posted on Aug 04, 2008
SkyGuy08
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
EngineerMC
  • 186 Answers
SOURCE: sky remote code for lg m227wdp
press tv button
then red and select together for 2 seconds the led should blink twice
enter the code
press select
try it...
one of these codes should work... but its a bit trial and error 0056 065, 405, 318, 245, 275, 037, 060, 391, 137, 459
good luck
Posted on Feb 14, 2010
SOURCE: cant get code for 40 inch evotel to work sky plus
I've tryed all the codes I can find and still nothing!
Posted on Feb 21, 2010
welsh babe
SOURCE: REMOTE CODE FOR SKY REMOTE FOR BUSH A642F LCD
the code is 253
Posted on Apr 17, 2010
What is the code for a Ferguson TV
Ferguson tv sky remote codes ' AVForums
www.avforums.com > ... > Satellite TV, Sky TV & FreeSat
Sep 24, 2014 - Hello, does anybody know what the sky remote control codes are for aferguson television. I have tried to find the solution on the internet but the... Sky Remote Code for Ferguson TV
Sep 28, 2014
Sky code for Ferguson Tv
Apr 22, 2010
More results from www.avforums.com
Remote Code For Ferguson TV - Sky - Digital Spy Forums
Dec 15, 2015 | Televison & Video
What is the code for LG 37LE4500 TO WORK WITH SKY REMOTE CONTROL
I also have an LG TV. I used this 4 digit code: 0742.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Mar 12, 2011 | LG Televison & Video
Unabel to use sky control for sound
You have to programme the correct code for your TV into the Sky remote.
You can get these via "Sky Active" (if your box is connected to a phone line) or from the Sky website, or google search: "Sky remote codes".
However your sky remote wont necessarily control more recent televisions unless you have a REV8 remote control. You can check this by taking the battery cover off your remote and looking at the sticker inside. If it says RC1600/00 you're probably not going to be able to control your TV. REV4 and REV6 are more likely to work - but not guaranteed. If it says REV8, then you are probably not using the correct code or you're not programming the remote correctly.
If you have REV8, the correct code for your TV (according to Sky) is: 0678 or 1678 or 0254
Sky remote code finder page is here: http://sky.uebv.com/
Sky guide to finding your remote code and programming remotes is here:
http://www.sky.com/helpcentre/tv/sky-remote-control/program-your-sky-remote-control-to-work-with-your-tv/
Please rate my solution if you find this helpful. Thanks.
Oct 13, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Sky remote code unavailable? Is it possible to use sky remote for hanspree tv?
Hi you can get your sky remote code by pressing interactive then going to sky customer service (Option 4) then choosing your code it will remind you what it is :) I hope this helps and also im pretty sure you can use your sky remote for a hanspree tv they work with almost every tv
Jul 18, 2010 | Televison & Video
I NEED A CODE FOR SKY REMOTE
Hi.
Here available codes for Sky Remote: sky remote codes
Nov 05, 2009 | Televison & Video
Sanyo ce32ld47-b code for sky+ remote
  1. Turn your TV on.
  5. Key in the code 0157. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code you entered and start again at Step 1.
Oct 12, 2009 | Sanyo Televison & Video
Pin code for wharfedale tv
1 am looking for the sky remote code for a wharfedale ltf42k1cb teley
Oct 18, 2008 | Televison & Video
Sky code for remote
The code for you sky remote is 0125.
4 digit' method
1. Turn on your TV.
5. Key in the Brand Set code for your brand of TV then press select. The light on the Sky remote control blinks twice.
If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press tv , then press the on/off button. Repeat this (press tv , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press tv guide .
If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide,you must now set the TV Guide function as follows:
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
Feb 13, 2008 | Televison & Video
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
