Question about Dishwashers
What does error Version 77 mean on an Electrolux Dishwasher mean
Electrolux dishwasher model EWDW65O5GS
COXY
  • 76 Answers
SOURCE: Electrolux Gallery Dishwasher Error Message AL3
It sounds like it could be a heater problem, I would check this first
Posted on Nov 27, 2007
SOURCE: error message ''CL'' on electrolux dx302w dishwasher
The label says this is the child lock. You can cancel it by holding the two buttons (program & start/pause) simultaneously for 5 seconds. i tried it on mine & it seems to work.
Chris
Posted on Sep 08, 2009
SOURCE: error code on electrolux dishwasher,
electrolux wave touch dishwasher giving error code 1?
Posted on Oct 20, 2009
SOURCE: electrolux dishwasher error code 01
I found the error codes in the owners manual, (01) is a leak. I called customer service (no wait time) and they said there is pan under the tub that will contain and detect water if it leaks. They said I could wait for it to dry out. They said there could be a hose that became loose or had a pin hole in it. After I hung up with customer service I did my own problem solving. The diswasher washing cycle was just started. Then then the door was opened 5 to 6 times to add more utensils and dishes while the the machine was running. Then the error code came on. this was the first time this had happened. I beleive water seeped doen through the hinges and the seal into the pan. I unpluged the dishwasher and disconnected the water line and pulled it from under the counter. Then lifted the diswasher onto 4 inch blocks of wood placed under the feet. This made it easier to access the pan. It had 2 screws inthe front and 1 in the rear with 3 clips. I removed the pan and dried it. Inspected the hoses under the unit and determined none of them had appeared to be leaking. I positioned a fan to blow under the unit to speed up the dry time, about 1/2 an hour. Put everything back together and ran a high pressure hot water cycle and found no leakes, so far.
Posted on Jan 12, 2010
tattootech2
  • 72 Answers
SOURCE: EWDW6505GS0 Model Electrolux dishwasher 10 months
Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Posted on Apr 07, 2010
I have an error code on my Electrolux dishwasher EO?
Hello Judy, thank you for your post!
I understand that your Electrolux dishwasher is displaying an error code of "EO". The error code "EO" means that you could have a possible issue with the flow controller. I would recommend performing a reset on your dishwasher and this could help clear out any potential miscommunications. You can reset the dishwasher by disconnecting power from it for at least ten minutes. If the reset does not help correct the error code I would recommend having a professional technician out to perform a full diagnosis. Hopefully this information is helpful to you. -Matt
Feb 03, 2016 | Electrolux Dishwashers
What does 01 error mean?
Hello Ned, thank you for your post!
I understand that your Electrolux dishwasher is displaying an error code of "01". This error code means that a leak has been detected. Have you noticed any water coming from the bottom or near the dishwasher? This could also be a miscommunication within the control of the dishwasher and a reset may help clear that out. You can reset your dishwasher by disconnecting power from it for at least ten minutes. If that does not help to resolve your issue I would suggest having a professional technician out to perform a proper diagnosis and repair. I hope this information is helpful to some degree. -Matt
Jan 22, 2016 | Electrolux Dishwashers
Error code CO HOW DO I CLEAR IT ON THE DISHWASHER
Hey Robert, thank you for your post!
Based off the information you have provided your Electrolux dishwasher is displaying an error code of "CO" and you would like to clear it out. The error code "CO" means that there is a miscommunication within your dishwasher. The best way to clear the code out is to perform a reset and you can do that by disconnecting the power cord for at least ten minutes. If the code continues to display this could mean that your keypad, a wiring harness, or control panel may need to be replaced and I would recommend having a professional technician out. They would have the appropriate tools needed to disassemble your dishwasher and test each component. This will help protect you from any unnecessary part purchases. -Matt
Jan 15, 2016 | Electrolux Dishwashers
Model EIDW6305GSI error code 03 comes on after about an hour after cycle starts could anybody tell me why this happens thanks
Good Morning steven hutchings, thanks for your inquiry!
I understand that your Electrolux dishwasher is displaying an error code 03. Normally, error code 03 means an issue with the wash motor, wash motor hall sensor, or control panel. I would suggest performing a reset on your dishwasher that could help clear any false error codes. You can reset your dishwasher by flipping the household circuit breaker in the off position for ten minutes. If you continue to have an issue with your dishwasher displaying an error code 03, I would recommend having a professional technician come out and properly diagnosis your dishwasher. This will help to avoid any unnecessary part purchases. Hope this is helpful. -Matt
Dec 04, 2014 | Electrolux Dishwashers
How do i fix electrolux dishwasher when error code 1 is flashing
Hello friend, thanks for your post!
I see your Electrolux dishwasher is displaying an "E1" error code. "E1" stands for a leak detected which means your dishwasher base has detected a leak. If you can't see a leak you may want to perform a reset on your dishwasher you can do that by disconnecting the power from your appliance for roughly ten minutes.
If that does not correct the issue you may want to seek assistance from a technician. They would need to come out to diagnosis and repair your dishwasher. I hope this information has been helpful. -Matt
Oct 03, 2014 | Electrolux Dishwashers
F0
Hello Friend, this is Z. I am pleased to help you!
I see that your post is listed under Electrolux Dishwasher; however please help me understand what your concern is? Is your dishwasher getting an error code F0 or are you seeking an Owner's Guide? May I have your model number please? The serial tag, which lists your model number, is typically located on the right side as you open the door. Thank you!
Jul 14, 2014 | Electrolux Dishwashers
I have the EIDW6305 it's flashing the numbers 77 and 35 on the screen shouldn't be anything what does that mean
Hello Donal Holtman - Try resetting the dishwasher by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately. Unit could possibly be experiencing a communication issue with the control panel or wiring failure which would need further diagnosing.
Nov 23, 2012 | Electrolux Frigidaire Professional Series...
All the light on my new, Electrolux dishwasher are
Remove the kickplate at the bottom of your dishwasher and see what error you are getting. Likely a leak error.Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Jan 25, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
Dishwashers Logo
218 people viewed this question
Top Dishwashers Experts
Owen Barnes
