Question about iLO MP3 Player
Wont let me feformat help
I turn on my mp3 and and is stuck at the booting up part i plugin my pc and it wont let e reformat wot do i need 2 do r is down n out redy 4 the bin
That is easy thake it out from the bottom
Posted on Jan 16, 2009
Need to reformat an oqo model 2 disk - windows wont boot - can i fix by booting from a usb?
If your USB stick has a bootable system on it, (format the USB with system files before adding your system) and if you set the BIOS to use USB as boot device.
Mar 07, 2011 | OQO model 2 PC Notebook
It wont format, it wont let me delete or even add songs? what do i do?
There are two to reformat your device. Just follow these instructions
From menu of your device:
1. Turn on your Sansa C240
2. From the main options menu, select " Settings "
3. Select " Format " and " Yes "
Formatting Manually:
1. Turn off Sansa C240
2. Slide the " Hold " switch on the bottom of the device to the " On " position
3. Press and hold the " Play " button. Press and release the " Power " button.
4. Hold the " Play " button until the LED screen displays the message " About to format device."
5. Release the " Play " button and press the " Next " button once.
Try these steps and let me know if you manage to reformat your device.
I could instruct you on how to reformat this device on your pc just post back.
If these solutions helped you.. please rate this answer and leave some testimonial too.
Thank you
Nov 17, 2010 | SanDisk Sansa c240 MP3 Player
My mp3 player is frozen help!! it won't do anything
Try to reformat it. It might be a virus or a bug.
Apr 27, 2010 | Sylvania SMPK8858 MP3 Player
My Acer Aspire 3050 laptop can not boot
Hi
Thank you for your query
unfortunatley you are stuck in a windows loop and will need to reformat your PC
Please do the following to reformat
1) Put your recovery disc into your PC and allow the PC to restart
2) The laptop should pick the disc up and boot from it
3) Follow the onscreen instructions to complete the rest of the install
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 17, 2010 | Acer Aspire 3050-1733 Notebook
My M4208 MP3 player will not turn on at all..
Try resetting it with a paper clip or toothpick through the hole in the back. Its pretty deep but if you push gently you'll feel the slight click as the button goes down.. You can also download the firmware update from the rca site . You can use this to reformat your player. I was messing around with one that was given to me last night until I got a boot error. I reset and reformatted. Might could have just gotten away with reformatting.
Feb 23, 2009 | RCA M4208 MP3 Player
Sansa stuck on finalizing update
Remove the battery for at least 3 minutes and then put it back in.. be sure it''s fresh and fully charged
2. VERY IMPORTANT...Turn the "Hold button" ON.. (slide it to the right)
3. Now, plug it into the computer, it would be better if you used a USB 2 port that is located on the back of the computer (it''s on the motherboard)
4. Go to "MY Computer" and see if it shows up as a "Removable disk"
5. If it''s there, then reformat it to ...FAT32...not FAT.if you need help with reformatting let me know.
EDIT* When I called Sandisk on 1-3-07, the tech I spoke with instructed me to reformat to FAT32. Now (2-14-07) I get this from them..."(select "FAT" if the capacity of your Sansa is less than 2GB. For larger players, select "FAT32"). I found I lost a few megs when I formated to FAT32 on my m240, but didn't notice any other difference.
6 Unplug it and let it finalize. Give it lots of time.
7. Return the "Hold button" to off.
I hope that help
Please rate accordingly
Thank you
Computerrep
Nov 17, 2008 | SanDisk Sansa m240 MP3 Player
Player wont open; is reformat possible?
you have to get a toothpick and then stick it where it says restart.
then it should work =]
Oct 06, 2008 | Creative Labs Zen Digital Media Player
ILO 2GB MP3 Player
reformat it using itunes software
Sep 10, 2008 | iLO (2 GB) MP3 Player
Dell dimesion 4600 won't boot up
u try to just hold in power button shut down all way for min then back on
Feb 09, 2008 | Dell Dimension 4600 PC Desktop
Won't Turn on
It seems to me like your mp3 player booting software has corrupt, keep trying it it doesn't work after so long you may need to format your mp3 player.
To format you can use the software provided (if there was any.) If there wasn't any software provided follow these steps below:
First connect your mp3 player to the computer, once you've done that go to "Start" - "My Computer" - now look for something called "Removable Disk" which is your mp3 player, once you've found it "Right-click" on it then click "Format", once format as complete put music back on your mp3 player then, unplug it from your PC/Laptop which ever you have, then try switching it on & the problem should have been fixed.
Good luck. Hope my solution was helpful in some way. Further problems, leave a comment on here and i will get back to you a.s.a.p.
Nov 25, 2007 | iLO (2 GB) MP3 Player
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
