Question about Kenmore Dryers
My 90 series Kenmore dryer (model 66914691) shuts off before cycle is done, then will start up again after a while. I can't even restart it manually until it is ready. It's like it has to cool down first. It usually makes a squeaking sound for a while before it shouts off, but not always. Occasionally it will make the squeaking sound as it starts up. Once it screeched pretty loudly when I tried to start it, but then did fine after I took some heavy towels out. I don't know if the two problems (the noise and the shutting off) are related, but they did start happening at about the same time.
catriver
  • 878 Answers
SOURCE: Squeak
Pinot, usually the squeak on these 417's is coming from the drum ball and plastic bearing. Sometimes they crack and sometimes just need to be greased. Go to this link http://www3.sears.com/ and enter your model number, upper left hand corner. Follow the link and click on view diagram, page 1. Look at number 12 and 34. This is the drum hitch and plastic bearing. Your husband will have to remove the top and once he has the belt off, pull up on the drum to get it off the bearing, (plastic coupling that the ball sets into. If it's not cracked and the ball is is good shape, just grease it. If it's cracked and the ball is a chewed up, replace them both. This job is done better with 2 people cause it's not the easiest deal. You can find the part numbers on the parts link right next to view diagram. Let the cat know if you need any more help, Catriver.
Posted on Jan 06, 2008
  • 65 Answers
SOURCE: Kenmore 70 series dryer shuts off and won't restart
IT SOUNDS AS THOUGH THE MOTOR IS OVERHEATING AND SHUTTING ITSELF OFF. THAT IS ABOUT THE ONLY THING ON THE DRYER THAT WOULD SHUT IT OFF AND NOT ALLOW IT TO START AGAIN RIGHT AWAY, BUT LET IT START AFTER A WHILE. MAKE SURE THE MOTOR TURNS FREELY. IT SHOULD NOT DRAG OR HUMM WHEN TRYING TO START.
Posted on Jan 28, 2009
  • 770 Answers
SOURCE: Kenmore 90 series dryer screeches when starts
The likely cause is your belt slipping. The reason it is louder when you start is just that...It pulls harder to get the tub rolling and as it gains momentum the belt doesn't have to work as hard. Your belt is worn and will eventually break. When it slips, it is wearing at a greater rate, so you may want to go ahead and replace it.
Posted on Jun 21, 2009
canbruce75
  • 1776 Answers
SOURCE: Kenmore Gas Dryer Gets Hot, Shuts Off Early in Cycle
Sounds like a faulty high limit or cycling thermostat. The thermostat tells the dryer to heat until the interior of the dryer reaches a certain temp. It should be mounted on the exhause duct inside the back of the dryer. It should look something like the one in the picture:
Hope this helped and best wishes.
Posted on Jul 27, 2009
MARCLAVORIS
  • 110 Answers
SOURCE: kenmore dryer 90 series shuts off and then won't
okay, you have a bad motor, this motor is caused by bad ventillation, instead of your lint going outside it is getting on your motor. i am sure your dryer was taking a long time to dry.
replace the motor and you will be fine.
Posted on Sep 11, 2009
Kenmore dryer 90 series shuts off and then won't restart. the start button makes the normal noise when first pressed, but then makes no sound. the dryer restarted this morning and worked for a few loads,...
Sep 09, 2009 | Kenmore Dryers
Kenmore Dryer 90 Series will start but suddenly stop...
Hello , Sounds like your motor is over heating , it will run until the sensor shuts it down from getting to hot , it is most likley because the motor is covered in lint and needs cleaned. Hope that helps.
Dec 30, 2008 | Dryers
Kenmore Dryer-Model#66914691
possible you blown the thermal overload fuse located on back wall of unit behind rear panel, small 2" long saftey fuse, if blown will prevent dryer from operating
Nov 11, 2008 | Kenmore 62872 Electric Dryer
Kenmore electric dryer series 90 model 66904691 will not start. Dryed a load of clothes went to start again will not do anything , checked fuse box, fuse not blown what could be the problem
Check the automatic door shut off switch and wiring. When the door closes it actuates a switch (completes and electrical circuit) which allows the dryer to operate.
Aug 23, 2008 | Kenmore Dryers
what starts and stops? the entire dryer or maybe the drum? Do you do anything to make it restart other than pushing the start button? This initially sounds like a temperature switch is opening and resetting after it cools. If you can describe the problem a little more in detail it would help.
Jan 27, 2008 | Kenmore 659 Electric Dryer
Kenmore dryer runs then shuts off
The parts store should have never sold you the motor. They rarely if ever fail on a dryer. It sounds like a limit switch or sensor wire was damaged by the burning. Check out the wiring and if you feel comfortable jumper out one switch at a time to see which one is not working. Do only one at a time. Photograph everything before you take anything apart.
Mar 04, 2017 | Kenmore Dryers
Dryers Logo
67 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
