Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
We were putting a new pull starter rope on an older homelite 240 chain saw and accidently dropped the cover. The spring came out. Now we are having a very hard time trying to get it back in. Is there an easy or easier way?
  • Anonymous Apr 24, 2009
    hey I have a homelite 240 chainsaw  and the pull string was all the way out when my friend gave it to me im sittin here trying to just rebuild the thing but i dont understand  how the spring system works it has a coil type spring that the plastic piece that holds the pull string is attached to but I cant get it to feed back into itsself alone
  • David Ford
    David Ford May 11, 2010
    Does the spring look like a fish tape for electrical wiring? If so when that happened to me I would just have to take my time and coil the spring back into the housing with one hand putting some pressure while the other pushes the spring into it. If not let me know what it looks like and I will research further. Good luck
    Scholar:
  • 149 Answers
Wear saftey glasses...
hold the middle coils and keep pulling the outer coil slowly hold the spring with long nose pliers. keep tightening it up un till its smaller than the case hole...
make sure its on the right side..
Posted on Jan 15, 2009
How do I put a new pull rope on my 5hp MTD Chipper?
pull the starter cover pull rope out to length lock the housing the rope is in, in place with a tool pull out rope. reinsert new rope into retaining hoe tie a not and cut off excess rope. put ropr through handle hole reattach handle and remove tool you used to hold the rope housing. This is if your spring and starter assembly are ok. Or you could stop being a cheap and let a shop do it for 5 minutes labor.
Jun 29, 2014 | Husqvarna Chain Saw 20" Bar
Installing a spring in an MS240 Stihl chain saw
I have not worked on you type saw. I have put new starter springs in other saws. One end of the spring fits into the housing and the other in the pulley. Once you have that done there should be a notch in the pulley that you put the rope into that will allow the spring to be wound up without taking up the rope. It is a trial error problem now. If the spring is wound too tight you will not get full rope travel. If it is too loose tilt will not pull the rope in fully.
Jun 01, 2013 | nwp Starter Recoil Spring Fits Stihl 024...
How does the recoil spring,waher,2 hairpins pins,dog footand rope pulley get reassembeled?
the rope rotor will go on first, then the washer goes on, put the dogs in then put the spring on. insert the rope into the rotor, wind it up, feed the rope through the starter cover, carefully allow the rotor to wind in the rope a ways then put the handle on.
Dec 20, 2012 | Stihl MS 290 Chain Saw include 20" 50cm...
Homelite chain saw XL925 cord pull too hard but if you remove the spark plug then it pulls OK.
I have a Homelite XL and was having problems with rope pulling from difficult to unable to pull rope while trying to start saw. I removed the muffler, squirted some WD40 through the exhaust port ABOVE and BELOW the piston compression ring. Then pulled the rope about 20 times without spark plug to fully lubricate the piston and cylinder. Left it till the next day, pulled it through about 20 more times, put the spark plug back in,and it works well now. Guess it was just gummed-up a little and the lubrication freed it.
Oct 31, 2011 | Homelite ZR10926 16 Chain Saw
Pull cord will not rewind
  • 1
    Turn the Homelite chainsaw so that the bar and chain are laying flat and the starter cover is facing up. Loosen the four starter cover screws by unscrewing them counterclockwise with the screwdriver.
  • 2
    Take the starter cover off of the engine. Turn the starter cover over to work on the pull starter. Pull the rope out about 6 to 8 inches.
  • 3
    Twist a loop into the end of the rope. Insert the intersection of the two ropes into the notch on the upper flange of the pulley. Rotate the loop back and forth until you notice the recoil spring has disengaged. Unwind the rope from the pulley. Cut off any old rope if you need to replace it with a new rope.
  • 4
    Unscrew the screw holding the pulley to the starter cover using the screwdriver. Take the pulley off the starter cover. Turn the pulley over and remove the recoil spring cassette from inside the pulley.
  • 5
    Inspect the spring inside the cassette to see if it is damaged or overstretched. Replace the recoil spring cassette if it is broken. Lubricate the post on the starter cover using about a dime-sized amount of engine grease.
  • 6
    Put the recoil spring cassette back into the pulley. Set the pulley onto the starter cover and tighten the screw down with the screwdriver. Wind the starter rope back around the pulley in a clockwise direction.
  • 7
    Leave about 6 to 8 inches of rope unwound. Form another loop at the end and insert the loop into the notch on the pulley. Rotate the loop back and forth until you notice the tension is set on the recoil spring.
  • 8
    Remove the loop and place the starter cover back over the engine. Pull the rope out 6 inches and tighten the starter cover's screws using the screwdriver. Release the rope and it should automatically retract
  • hope this helps
    John
    Sep 09, 2011 | Homelite Garden
    How to put a new pull rope on it How do I put a new pull rope on
    It realy depends on what model we are talking about, so i will give a general disciption, remove the four screws retaining the starter to the saw, remove the starter, if the cord is still under tention, pull the starter handle out approx 8", whilst held out hold the pulley to stop it retracting, let go the starter handle and unwind the now lose cord from around the pulley, once enough cord has been unwound let the pulley slowly turn until all the spring tention has gone, remove the center fixing screw, and remove the pulley, pull the old cord away, refit a new suitable diameter cord, knot the end and pull the cord into the pulley so as the knot sits flush into the hole in the pulley, wind the cord fully around the pulley,now refit the pulley to the cover, refit the centre screw ,push the other end of the cord through the cover eyelet and refit the starter handle with a suitable knot, now wind the cord around the pulley a further two times by turning the pulley and winding up the spring, allow the spring to pull the cord in, if required wind the pulley a further turn until the cord is suitably tentioned in the cover, replace the cover on the machine, pull the cord out to make sure it has engaged fully into the pawls before fully tightening the fixing screws.
    Aug 18, 2011 | Husqvarna Chain Saw 20" Bar
    I havea 16 inch Homelite chain saw , I 've had it for about 25 years.I cannot not pull the starting rope. If I take out the spark plug ,it pulls with no effort.I have taken the starting rope cover off and...
    If someone put the wrong sparkplug in the saw it would do the same thing. The plug threads could be too long and when the piston comes up it hits the plug and stopps. If the electrodes on the new plug extend farther out of the sparkplug the piston will come up and hit it and the engine will not turn.
    Mar 14, 2011 | Homelite Garden
    Homelite model No. 10609. 1H2100076 My pull rope won't recoil.
    Not that i know of, take the cover off and rewind by hand, use greese on the coil and pull the rope in and out, if the rope doesnt recoil you are going to need a new pull start assembly
    Apr 28, 2010 | Homelite ZR10926 16 Chain Saw
    Recoil spring on homelite chain saw doesn't retract pull rope
    Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
    Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
    Pull cord on chain saw will not retract.
    Most of the rancher models are easy to look at. Take the four screws off that hold the starter cover on.When off have a look to see if the pulley is ok or one of the starter dogs(pawls) is jamed . If dogs ok take the screw out of the centre of pulley and remove it ,check for spring tension. if there is just be carful to leave sring in housing. look at spring if broken or out of shape renew it and rope.check for cracks in pulley. When renewing spring and rope get correct rope length and diameter. don't over tension new spring. hop this helps
    Jan 02, 2009 | Husqvarna Chain Saw 20" Bar
    Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
    142 people viewed this question
    Top Homelite Garden Experts
    roeb
    Roland W VanLue
    Roland W VanLue
    Mike Squire
    Are you a Homelite Garden Expert? Answer questions, earn points and help others
