Question about Miele 24 in. G646SC Plus Free-Standing Dishwasher
MIELE G 646 SC START & END LIGHTS FLASH - Miele 24 in. G646SC Plus Free-Standing Dishwasher
Miele G641 SC Plus Drain /inlet light 4 short 1 long flash. How do I find a fault code chart?
Inlet / Drain is a general fault meaning there was no water movement when it was necessary to start the pump. Either it didn\'t drain out or it didn\'t fill the last time.
Call 800-999-1360 for free Miele tech support. They will advise you free of charge. You will perform step by step control board operations over the phone to clear the fault code as well as advise you how to cleanout the drain pump.
Dec 27, 2014 | Miele Dishwashers
Miele G 694 SC Plus Dishwashers : Cannot exit Test Program
Ok,if you unplug it,it should reset it.
Mar 09, 2014 | Dishwashers
G 646 sc pump still runs when programme is off
I had the same problem, the drain pump kept working even on the off program. After a little investigation i found out that there is a leak sensor that triggers the drain pump continually until it does not "sense" water anymore.
Firstl i tried to open the rear panel with no success.
Next i tilted the dishwasher to the left and let all the water drain out, plugged the dishwasher back to electricity and it worked!!!
I hope it will help you.
Jan 02, 2013 | Miele 24 in. G646SC Plus Free-Standing...
Miele G 646 SC, Leaking.? My Miele G646SC is leaking, the red inlet/drain light is on and I suspect it may be one of the pump seals has perished. The machine is 11 yrs old and has never had a problem of...
The dishwasher must be removed from the counter so you can gain access to the pump. I would check with a parts supply company first to see if the pump is still available, and the cost. It may be too expensive to repair a dishwasher that old.
Removing the dishwasher is not very hard. Turn off the electrical breaker. detach the DW from the counter. Pull out. disconnect the water supply and drain. disconnect power supply if required.
Nov 28, 2017 | Miele 24 in. G646SC Plus Free-Standing...
Miele G892 SC Touctronic dishwasher, intake/Drain light came on. How do I clear the drain?
Evening to you - empty the trays out of the washer - remove bottom wash arms by pulling upwards - below tha is a steel mesh - turn the plastic handle to unlock & remove the mesh - on the left of the tub locate a steel clip - below this is the housing for the pump - unclip & lift upwards - you will get a rush of water its ok - then clean the foodstuffs etc from in here as the propeller or impellar is found - turn machine on as the machine will a;lways start with a pump run - switch off after 20-30secs - check if all clear - clean up & assemble - should be good to go...
Jul 01, 2011 | Miele Dishwashers
Lights flashing at end of cycle, dishes not clean
I switched it off at the wall and left it for a minute and set the dial to Stop and then set it again from the beginning and so far it has been fine. Thanks, DCD
Oct 02, 2009 | Miele Dishwashers
3 lights are flashing at end of dishwashing cycle cycle
I shut off the dishwasher, held a few of the buttons together at the same time, let it sit for 5 minutes, then restarted it and it worked!
Mar 21, 2009 | Miele Dishwashers
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele g 646 sc (not plus)
check the inlet where it joins onto the tap as mine has a fine filter and debris from the fresh water builds up. Simply remove the pipe from the tap and **** ,this should remove /dislodge any scale etc that could be causing the inlet light to come on. Make sure you spit out the water that comes back from the machine!
Apr 20, 2008 | Miele 24 in. G646SC Plus Free-Standing...
Miele 24 in. G646SC Plus Free-Standing Dishwasher Logo
96 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
