Question about Kodak ESP 5 Printer
Kodak esp5210 error code 3527
Says the printhead carriage is jamed? and the inkcartrdige section will not move to the middle when i open the lid. Cant see anything jamming in there, followed all the options to fix on Kodak's website and they are now telling me that the hardward has gone! :(
  • 96 Answers
SOURCE: kodak all in one printer instalation error codes
Unfortunately, the only way to possible fix this error is to get the printhead out and reseat it. You can do that by removing the ink cartridges. Right above where the black ink cartridge was, at the top left hand corner of the printhead, if you push up towards the ceiling there should be a button that releases the printhead. You should now be able to tilt the printhead forward and pull it out of the printer. Reseat the printhead by putting it back in the printer and pushing straight back on the back wall of the printhead. It should snap into place. Replace the ink cartridges and close the printer. If the error clears, download the newest firmware from kodak.com so this never happens again.
If these steps do not clear the error however, call Kodak AiO tech support at 1800 421 6699 to get a new printhead.
Posted on Jul 21, 2008
  • 1218 Answers
SOURCE: printhead carriage jam facult is showing. No jam,
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Posted on Nov 15, 2010
  • 2246 Answers
SOURCE: New Printer. Printhead carriage jam message.
http://store.kodak.com/store/ekconsus/en_US/pd/ESP_7250_All-in-One_Printer/productID.169935600
Posted on Jan 07, 2011
SOURCE: Kodak ESP 3250. Error 3527. I put new ink
Contact Kodak. I think it's the batch of printers that were made around this time. I just contacted them (mine is the same age and I'm getting the same error), and they are sending me a new printer.
Posted on Mar 09, 2011
Joed911
  • 4338 Answers
SOURCE: How do you get the
Remove and inspect the paper tray.
CAUTION: Do not place the printer on its top or right side when you remove the paper tray. Ink could possibly leak into the printer and cause damage.
  1. Turn off the printer.
  2. From the back of the printer, disconnect:
    • power cord
    • USB cable (if used)
  3. Turn the printer on its left side.
  4. Open the paper tray.
  5. From the bottom of the printer, do the following depending on your printer model:
  1. Check the paper tray for the following:
    • surface scratches
    • bends
    • ink contamination
    • broken parts
  2. If the paper tray is broken, contact Kodak to order a replacement, otherwise do the following:
  3. Install the parts that were removed in Step 5.
  4. Place the printer upright.
  5. Connect:
    • power cord
  6. Turn on the printer.
  7. Make a print to check the functionality of the paper tray.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Posted on Mar 18, 2011
Code 3527 office hero 6.1
Please follow the below link to the Kodak website for this code:
Printhead carriage jam or all in one printer error code 3515 3525 3527...
Nov 13, 2017 | Cell Phones
Kodak esp 2170 carriage jam problems
The carriage operation is not synchronized. It will have to be adjusted to normal
Aug 14, 2016 | Kodak ESP Office 2170 All-in-One Printer
Print head jam
Check the LCD on your printer control panel or the status monitor on your computer for an error message. If there is an error message, follow the instructions to clear it.
If there is no error message, or if the problem continues:
  1. Open the access door.
  2. Disconnect the power adapter from the back of the printer.
  3. CAUTION: Do not use force on the printhead carriage to move it. Gently move the printhead carriage from side to side to see that it moves freely and there are no obstructions.
  4. Remove any obstructions that may prevent the printhead carriage and ink cartridges from moving to the center position.
  5. Close the access door.
  6. Connect the power adapter to the printer.
  7. Remove the ink cartridges from the printhead.
  8. Verify that the labels on the ink cartridges are intact, and that the cartridges are not damaged.
  9. firmly until you hear it click into position.
  10. Insert the color ink cartridge into the printhead, then press down firmly until you hear it click into position.
  11. Close the printer access door.
  12. Press OK to clear the error.
  13. Make a print.
May 06, 2014 | Kodak Office Hero 6.1
It all depends on who made the product. There are often times simple solutions but they need to be found by searching on the web and talking to service people about the unit. Some print head motors were known to fail or develop bearing noise over time in the HP line. Many of these things are really not prone to be fixed as the repair cost is sometimes the same as a new unit.
I would contact the warranty center- even if out of warranty and see if you could talk to a technician to start.
Aug 29, 2012 | Kodak ESP 5250 All-in-One Printer
Clearing Code 3527 from Kodak Hero 9.1
Hi friends,
I was able to solve this problem (error code 3527 on Kodak hero 9.1) by opening the printer entirely (dis-assembled), Checking the cartridge carriage assembly, i discovered that the belt that drive carriage assembly had a locker that was broken as such, the carriage assembly could not move in the direction as the motor drives the belt on.
I simply inserted the belt in position and drop a little drop of super glue to it, let it dry off.
Assemble my printer, and it was ok and is working.
Aug 01, 2012 | Kodak HERO 9.1 All-in-One Printer with...
Code 3527 Printhead carriage jam on Kodak ESP 5210 All in one
the only thing i can think off is there is a problem with the head sensor, the heads move back and forth on a rigid belt but the head case also runs along a see through plastic strip, this has lines in it and tells the printer were it is, other thing i can think of is the head cleaner, they can get stuck in them sometimes and cause misalignment and damage the reader. also anything they like to use on printers is a inc use chip that can make faults come up so you have to buy a new printer. this has been in a few articles. business printers don't have this feature. hope this helps
Jun 05, 2017 | Office Equipment & Supplies
Printhead cartridge jam code 3527
Contated Kodak about the error code 3527 and was advised I needed to purchase another printer and they would give me a 30% discount. Why would I do that when my Kodak printer is only 14 months old! My Dell is 9 years old and works fine! Dell ink cartrides are expensive and can only be ordered online. That is why I switched to Kodak. Do not buy Kodak!
May 01, 2011 | Kodak ESP 7250 All-in-One InkJet Printer
Printer error code 3820
  1. Open the printer access door.
  2. Disconnect the power adapter from the printer.
  3. Gently hold both sides of the carriage, located immediately behind the printhead, and make sure the carriage moves freely.
  4. If the carriage does not move freely, contact us.
  5. Remove the printhead and ink cartridges.
  6. Reinstall the printhead and ink cartridges, making sure each clicks into place.
  7. Connect the power adapter to the printer.
  8. Turn the printer on, if necessary.
  9. Close the printer access door.
aFor more help visit cbrtechsolutions
Dec 05, 2010 | Kodak ESP 5 Printer
Paper jam press ok to fix-then I get error code 3820
To resolve this error:
  4. Remove the printhead and ink cartridges.
  5. Reinstall the printhead and ink cartridges, making sure each clicks into place.
  7. Turn the printer on, if necessary.
  8. Close the printer access door.
If the error continues, contact Kodak.
Sep 24, 2010 | Kodak ESP 5 Printer
Kodak ESP 5 Printer Logo
279 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
