Question about Canon PIXMA MX310 All-In-One Printer
Canon MX310 not printing properly
All is working OK on my MX310 but the printing is crooked and the boxes and straight lines ar crooked/slightly stepped
  • Anonymous Mar 14, 2014
    my canon printer iP2770 print a crooked lines,how can i fix it
  • 4 Answers
If you are running Windows XP, you should be able to go to Control Panel> Printers and see your printer. Right-click and go to properties. From there you should be able to align the print cartridges and that should fix the problem. If problem persists, contact your manufacturer.
Posted on Jan 13, 2009
Using Canon mx310 with windows 8: The printer works fine EXCEPT the font quality
I have had this problem too. It only happens occasionally, and I have never really sorted it. I have made a test sheet with the same line (including some bold and some italic) copied some 15 times, starting with a 20 point font , and decreasing down to about 8 point (Times New Roman)
Print that a few times and see if any faults are repeated on each sheet. It may just be wear and tear.
Feb 25, 2014 | Canon PIXMA MX310 All-In-One Printer
Canon mx310 is printing everything double
Have you tried installing the latest drivers?
or is this happening when you print from any computer?
Mar 12, 2012 | Canon PIXMA MX310 All-In-One Printer
How to remove duplex printing from mx310
1. Select Properties from the Print dialog box. Note: Properties may be indicated as Advanced, depending on the application software.
2. Click on the Page Setup tab.
4. Click on Apply and then click on OK to apply the settings.
May 02, 2011 | Canon PIXMA MX310 All-In-One Printer
How do I fix canon mx310 which prints with lines
please check doc. page setup, may be outline or outside margin resulting not space.
Apr 15, 2010 | Canon PIXMA MX310 All-In-One Printer
Brother mfc-440cn printer printing crooked
There is the possibility that the scanner assembly has jumped a tooth on the drive belt on one side so the scanner is just slightly crooked. To correct this the scanner assembly would have to be taken apart enough to correctly line the assembly back up. I wouldn't recommend that you try this yourself unless you have some experience at this sort of thing. Contact Brother for an authorized repair center near you for assistance.
Sep 04, 2009 | Brother MultiFunction Center MFC-440CN...
Prints vertical lines crooked
You should be able to go into the print driver settings and do a print head alignment.
That should cure the problem.
Jan 15, 2018 | HP PSC 500 All-In-One Printer
To add my new canon mx310 to my mac
u do't have proper driver install in your pc firstly u have to install same driver to u have taken to printer other wise print not come..ok u have install the proper driver
Apr 03, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon mx310 feeds paper w/out printing
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | Canon PIXMA MX310 All-In-One Printer
Printer will not allow paper to flow freely; it jams on the left side and prints crooked.
first cancel all the prints going on and switch off and on the printer and keep the paper slowly
Aug 07, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
660 people viewed this question
old marine
old marine
