Upgrade ram gateway ze7, having trouble with removing back panel
5 Suggested Answers
nickuk23
  • 34 Answers
SOURCE: Fujitsu Siemens AMILO Pro V3405
i might be wrong but i thought on the fujitsu laptops you have to remove the keyboard to get access to the ram and there wasen't a access pannel on the back.
might be wrong but i have upgradedb quite a few.
if it is on the back the clips that hold the pannels in are normally quite chunky and require a bit of persuadence :) dont be afraid to give it a tug :)
have a look on the net for dissmantling guides for your model.
hope this has helped.
Posted on Dec 07, 2007
dutchman05
  • 487 Answers
SOURCE: Upgrading
goto the gateway site and check what memory type you need.
If you upgrade to 1064Mb that will increase the performace of your machine
Posted on Apr 20, 2008
  • 64 Answers
SOURCE: How do I remove the
It looks like it wont be easy, I looked up the PC and it seems the only way would be to open it completely. Basically you will have to at least have to remove the entire back cover, possibly more to get access to the ram.
Posted on May 17, 2011
  • 1479 Answers
SOURCE: How do I remove the back of my Gateway all in one
Never seen or worked on this model pc so I did a bit of digging and it seems this question has been asked here before.
http://www.fixya.com/support/t9203256-recently_purchased
Some manufacturers will go to any lengths to stop the end user updating their own equipment so you have to go back to them. Bad practice all round and only serves to drive customers away.
Posted on May 30, 2011
I have a gateway laptop model MT6821 how do i identify the type of ram installed so i can upgrade
go to control panel , computer , properties and the details of the chip , motherboard and ram is listed there
as the ram is itself a circuit board that is put into a slot, the only upgrade that may be possible is to insert a second board of the same make and capacity to double the ram
talk it over with a computer repair shop as to the possibility of what you want to do
Jun 22, 2016 | Gateway Computers & Internet
Gateway ZE7 ram
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible
Hope this helps.
Nov 28, 2012 | Computers & Internet
How do I upgrade my ram on my Gateway All in one zx4250?
I too purchased a Gateway ZX4250 and a 4 GB RAM upgrade kit. It took me awhile to figure out how to open the case. Here is what I found.
1) Remove the two rubber pads at the bottom of the case (don't worry they pop right back on).
2) Open the small back cover.
3) Remove the one screw.
*****CAREFUL****
4) This part is a little difficult but just be careful not to use too much force. Take two small flat head screwdrivers and slowly separate the plastic silver front panel from the plastic black back panel. Start at the bottom where the two rubber pads were removed. Work your way around the case, you can see how the clips are connecting the two panels as you work your way around the all-in-one. It shouldn't be too hard just be careful on how much force you use.
5) Once the panels are separated you can now access the hard drive, optical drive and some other components.
6) Disconnect the Hard drive sata cable from the motherboard.
7) Disconnect the other cable right next to the sata cable on the motherboard (I'm not sure as to the purpose of this cable.
8) Remove the screws from the metal plate covering the motherboard. Take careful note that a grounding cable is connected to one screw.
9) Install your RAM.
10) Reverse the procedure to put everything back together.
This whole procedure to upgrade my RAM took about 15 minutes. I hope this helps some of you that are trying to upgrade your RAM. If you have any questions PM me.
Jan 03, 2012 | Gateway ZX493131e Notebook
I have all screws out of back of gateway ma3 all tabs are clear on top of key pad but wont come out
The only things you could hope to upgrade in a laptop that old is the RAM and the hard drive. if it's an x86 computer the most you get get is 4GBs of ram and maybe a 250GB IDE drive in that. Laptop's are not really meant for upgrading. It isn't cost effective to upgrade laptops anyways. Spend $300 on a new low end laptop and you will have something at least twice as powerful as this laptop you currently have.
Dec 16, 2011 | Gateway MX6453 Notebook
How do I remove the access cover to upgrade the RAM on a gateway all in one ZX4931-31e
May 17, 2011 | Gateway ZX493131e Notebook
How to open and upgrade RAM memory of gateway netbook model LT2704u?
This netbook is really the Acer Aspire One D255. You have to pop off the keyboard, then remove 4 screws that hold the back panel in place, which will allow you to remove that back panel in order to get to the memory.
Here's a video - blurry but it tells the story: http://www.youtube.com/watch?v=6KYNTvF0-5M
A better video on removing he keyboard: http://www.youtube.com/watch?v=FoTwln2SyQ4
Mar 01, 2011 | Gateway Computers & Internet
Want to add memory to Gateway 700x
Upgrading RAM on your Gateway 700X (DDR) Computer is easy, Gateway 700X (DDR) Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. RAM Type, and comes installed with 512 MB (removable) of RAM.
You can upgrade your Gateway 700X (DDR) Computer to up to a maximum of 2.0 GB RAM, the Computer has 4 sockets to install RAM, already with 512 MB (removable) standard RAM installed. For best Computer performance use the maximum amount of allowed RAM per slot for your system.
Dec 08, 2008 | Computers & Internet
Memory
no it does not support ddr2 ram.
goto this link for mor ingormation.
http://support.gateway.com/s/PC/R/3724/4365sp3.shtml
good luck
Jul 09, 2008 | Gateway 504GR PC Desktop
Upgrading
Apr 20, 2008 | Gateway MX3228 Notebook
Computers & Internet Logo
516 people viewed this question
David Payne
David Payne
