Question about Lexmark X544dw All-In-One Printer
Lexmark x544 is saying paper tray empty but it's not
I have paper in my printer, but it keeps saying 'Load Paper'. When I open and close the tray it is not feeding and saying 'Paper Jam'. I have cleaned everything up, tried to check if there is a Jam...there isn't! Is this a common occurrence? I've tried everything suggested from these forums...can anyone else offer some expertise?
SOURCE: paper source
I would suggest checking printer properties in the computer and ensure the paper size and source is Letter and set to Automatic Choose. Another choice may be to deleted the printer driver and re-install it. You can also go into the menu options until you get to Set factory defaults, press Select, then try the print job again.
I really suspect a program is controlling this from the computer.
To get a list of the existing printer settings, Select Menu and use the Right Arrow button until you get to Printer Menu Settings. The printed report should tell you what your actuall settings are. Maybe the default is set to Custom, instead of Letter.
The Set Factory Defaults option should fix most problems.
Good Luck John Moser
Posted on Jan 08, 2009
SOURCE: paper does not feed into lexmark X5470 all in one printer
feeding problems
not take apaper
not feed a paper
hey im tuval from israel,
first of all im sorry about my english :)
and now to the point.......
look, if you know where the feeding wheel its good (like elastic material over this wheel) , now take a"nail cleaner" (aceton)
and clean this wheel (the elastic thing), i did thet and the problem is gone!!!
after the cleanning send 15-20 empty doc to print (remember - empty, dont use you ink - you dont have to - save money), if all the paper is out from the printer,
you fix that.
i hope i help you.
tuval.
vaadk3@netvision.net.il
hope fore replay.... :)
Posted on Jun 20, 2009
  • 583 Answers
SOURCE: Paper will not feed through the printer . . ,
behind the printer there is the tray that can be opened easily to check if the printer is jammed in or the paper feed sensor is stuck up.just open the back tray of your printer and check.
get back if you require more assistance on this.
thanks.
Posted on Jul 08, 2009
SOURCE: 202 paper jam
I have this problem too, but the 2 sensors on the fuser are not stuck and seem ok to me. Any other suggestions?
Posted on Nov 16, 2009
thunderbo611
  • 66 Answers
SOURCE: Lexmark T630 paper jam 238 it says check duplex.
in the back
Posted on Jan 26, 2010
I have a lexmark e238. Keeps showing paper jam light after cleaning rollers even though no paper is in there.
Either paper is moving too slow through the paper path or one of your paper path sensors is not registering. Pull the paper tray out and check to make sure the little plastic sensor is swinging free. That sensor tells when the tray is empty. Follow the paper path thru the printer checking all the sensors to make sure they are "opening" and "closing".
Apr 07, 2015 | Lexmark E238 Laser Printer
Lexmark E232, keeps telling me paper tray is empty even though it has paper in the tray, then it just keeps clicking instead of picking up the paper and feeding into the printer? Please help
Go the Lexmark website and search on support for their telephone number. I've always had a experience with their support team even if the printer is out of warranty.
Apr 05, 2012 | Lexmark E232 Laser Printer
What is the problem when the display keeps on showing Tray 1 load ltr on Lexmark c500
Load ltr means to load letter size paper. If its saying try 1 load ltr - its saying that you are out of letter size paper in tray number one of your printer.
Aug 27, 2011 | Lexmark C500n Laser Printer
I don't have the manual and the red light is on. Is that the toner needing replacing and how do I do it?
Here are the things that a steady red light may indicate (from the Owner's Manual):
led-erroron17.jpg A paper jam has occurred. To solve the problem, see "Clearing Jams in the Paper Tray". The front cover is open. Close the front cover. The top cover is open. Close the top cover. The paper tray is empty. Load paper in the tray. See "Loading Paper". A toner cartridge is not installed. Install a toner cartridge. See "Installing the Starter Toner Cartridge".
• A paper jam has occurred. Check the paper tray area.
• The front cover is open. Close the front cover.
• The top cover is open. Close the top cover.
• The paper tray is empty. Load paper in the tray.
• A toner cartridge is not installed. Install a toner cartridge.
Jul 26, 2011 | Dell 1110 Laser Printer
Paper keeps jamming. we get a partially printed page,then jams about 2/3 of the way and we have to pull it out.
You can avoid most paper jams by correctly loadingpaper and other media in the printer. Tips on how to help prevent paper jams · Do not loadwrinkled, creased, or damp paper. · Make sure thepaper is not buckled in the tray. · Never mixpaper/media types within a single tray. · Flex, fan, andstraighten paper before you load it. · Do not exceed themaximum stack height. · Push all papertrays firmly into the printer after loading them. · Make sure theguides in the trays are positioned snugly against the paper. · Do not remove anypaper trays while a job is printing. Wait for a Load Paper light sequencebefore you remove the tray. See the 'Load Media' section on page 61 of theUser's Guide for more information. · Use onlyrecommended paper. Consult the CardStock & Label Guide on the Lexmark web site for more information aboutwhich paper provides optimum results for your printing environment. For additional assistance, please contact LexmarkTechnical Support.
May 31, 2011 | Lexmark E232 Laser Printer
HP 2200D Amber light keeps flashing! ..and nothing else
Following are the reasons and its solution for amber light keeps flashing:
1. Toner have been empty.
Sol : Refill you toner.
2. Printer's paper tray do not close properly or paper in not in the tray.
Sol : Close the paper tray properly and keep some papers in the tray.
3. Any door of printer is open or not properly close.
Sol. : Check all the doors that is close properly or not.
If problem is still remaining then contact a professional to repair this printer.
Regards
Ashly
Feb 25, 2010 | HP LaserJet 2200D Printer
Paper jam
The way you describe your error, it seems that there is still some residual paper stuck inside the printer that may cause subsequent paper to be mis-aligned.
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 07, 2010 | Lexmark X5150 All-In-One InkJet Printer
Tried to print and it says remove paper jam and press start, tried that several times, put more paper in, powered off and it stil says paper jam...opened it up and no paper i can see thats jammed..
Jan 06, 2010 | Lexmark Pro X125 All-In-One InkJet Printer
The paper feed jammed allowing some print/now says empty but not
Look at the paper path very carefully. There might be a piece of paper that got torn off and is either jammed up in the fuser or the registration assembly.
Jan 06, 2009 | Lexmark E232 Laser Printer
Lexmark T632 says "Load MP Feeder Letter
Hi Pqpoppa,
Check the paper size setting in the printer. Set it to the paper size you normally use such as A4 and the default tray. Check the default paper size in the printer driver in your computer and the default tray. Finally, check the paper size of the document you are printing. If all these match, it should not try to be smart and ask you to feed paper.
Rgds
S88
Nov 03, 2008 | Lexmark T632 Laser Printer
Lexmark X544dw All-In-One Printer Logo
436 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
