Question about Acer TravelMate 240 Notebook
Acer 240 laptop keyboard took sip of coke
My acer 240 took a sip of coke on key board some are ioperable aome are i belive are stuck on i have to hit shift i works for a few minutes then no key board resoponse exept by hitting shift obviously a stuck key problem Q: can I fix this my self I my have the right skills but need guidance before I pry, or is it just not worth it??
Rick
    Scholar:
  • 35 Answers
Proper cleaning and lubrication as described here will restore your laptop keyboard to the snappy and smooth performance it had when new. This will require about 2 hours time once you have collected the proper cleaning materials.
Cleaning materials:
  • Cotton swabs
  • Cosmetic foam rubber cleaning pads ( use only with naptha (lighter fluid), NOT alcohol)
  • Paper towels
  • Rubbing alcohol
  • Water
  • Lighter fluid (naptha)
  • Fine tipped tweezers
  • Scissors
  • Kitchen strainer
  • Household cleaner, Windex or equivalent
  • Super Lube Dry Film spray (critical - DO NOT SUBSTUTUTE !) K-Mart automotive. This is a PTFE (teflon) based lubricant which dries perfectly DRY and is ideally suited for this application.
Proceed as follows:
DISASSEMBLE
IMPORTANT: Make a keyboard map so you know where each key goes.
Carefully pry each key loose with a small screwdriver and place in a container. They pop off. DO NOT use excessive force. There may be a small rubber piece for each key. Remove all of these and place in a separate container. CAREFUL, these are small and like to jump away.
CLEAN KEYBOARD
Do this well...... you will be wonderfully rewarded
Clean the keyboard with cotton swabs SLIGHTLY DAMPENED with water. Replace these often and BE SURE they are only slightly damp. If they are too wet the excess water will contaminate the keyboard through capillary action. This will clean all water soluble contaminants like Coca-Cola, coffee, and sugar residue. For the very small places, cut the foam rubber into small pieces and use the tweezers, again SLIGHTLY DAMPENED, for cleaning. You must clean each and every key space, inside and out, this is critical since this is where the key touches and moves.
Repeat this procedure again using rubbing alcohol and cotton swabs but NOT the foam rubber as it disintegrates when used with alcohol.
Finally repeat this procedure using naptha (lighter fluid) and foam rubber. You can clean even the smallest key guides with small pieces of foam rubber and tweezers. This action will remove any petroleum based contaminants as well as the grease that is sometimes used on the wider keys which may have guide wires, for example, the SCACE BAR.
CLEAN KEYS
Some keys may have wires attached and some grease on them, clean these first with cotton swabs and naptha (lighter fluid). Remove all traces of the grease.
Place all keys in a kitchen strainer. Spray with household cleaner and let stand for 5 minutes. Rinse thoroughly with hot water and place keys on paper towels to dry. Let dry completely.
CLEAN RUBBER COMPONENTS
Place all rubber components in a kitchen strainer. Spray with household cleaner and let stand for 5 minutes. Use stopper in the sink so that you don't lose these if they jump out of the strainer. Rinse these thoroughly with hot water and place on paper towels. Fold the towels over and press to squeeze most of the water out of the pieces. Let dry completely. LUBRICATE KEYS
Place all keys bottom-up on a paper bag. Lightly coat the keys, at a 45 degree angle with Super Lube Dry Film lubricant. Do this from all 4 sides to assure penetration and coverage into the small and critical guide spaces inside each key. Let dry ( this happens nearly instantly). DO NOT overdue this step as the carrier solvent may affect the plastic.
LUBRICATE KEYBOARD
Mask off the laptop with paper and scotch tape. Apply lubricant (as above in LUBRICATE KEYS) to the keyboard and let dry.
Alright, you now have perfectly cleaned and lubricated keys, keyboard, and rubber components.
REASSEMBLE
Place all rubber components into the keyboard.
Install keys with wires. Make sure wire is secured in the key, usually snapped into place. Place ends of wire in the guide slots adjacent to the key location as you align the key. Firmly press down to snap the key into place.
Install the rest of the keys by aligning and firmly pressing down.
CONTRATULATIONS, you now have a squeeky clean keyboard!
Posted on Jan 12, 2009
My keyboard on my acer aspire 5336-2524 got wet on few keys i wiped it off shutt it down tipped upside down cleaned with alcohol wipes turned it back on and now none of it works its like keyboard was...
Well it depends on what the liquid was and how much went in. If the liquid was a fizzy drink like coke then the sugar works as an acid and dissolves the carbon tracking within the layers on the board and renders it useless. However some keys will work and others not. In your case nothing works and that sounds like the motherboard has got wet and if that is the case then it will be useless. The only way you could use the laptop if everything else works would be to buy a usb keyboard and use that. not very portable though!!!
Jun 19, 2011 | Acer Aspire AS5336-2524 Laptop
I have fractions on my keyboard, how do i get them on my screen?
It's either a Shift+ the key with the character you want to print or an FN(The Fn Key)+ the key that has the character you want to print. This assumes your drivers for that keyboard are actually loaded in the OS you are using and the OS recognizes the special keys. These are not normal keys.
Oct 29, 2010 | Acer NSK8458AN Keyboard
Dear sir/mam I have a sony vaio vgn fj270 laptop,3 days ago small amount of sprite spilled overthe key board and aome of the keys became stuck, a professional cleaned the keyboard unffortunately something...
There is not so much that could be done to repair a keyboard. Disassemble the laptop, check the ribbon cable connecting the keyboard to the motherboard. If the ribbon cable is loose, tighten it. If it is tight, replace the keyboard with a new one
Oct 13, 2010 | Sony VAIO VGN-FJ270/B Notebook
When i type f it searches, when i type m it minimize the application, when i type L it loguot...my laptop is acer aspire
The Ctrl key got stuck, either mechanically or electrically (liquid spilled?).
Sometimes it helps to hit the stuck key (actually two, left and right) numerous times, and restart the computer.
Sep 23, 2010 | Acer NSK8458AN Keyboard
HOW TO YOU REPLACE THE WHOLE KEY BOARD FOR A ACER 4720Z I SPILLED COFFEE ON THE KEY BOARD. EVERYTHING WORKS BUT THE ANY KEY I HIT I GET A I THAT IS STUCK
IS YOUR MACHINE IS UNDER WARRANTY IF YES LOOK FOR ACCIDENTAL COVERAGE OR CLAIM A HARDWARE FAILURE....THIS WILL REPLACE UR KEYBOARD FREE OF COST...OR YOU CAN BUY FROM HERE
Jun 16, 2010 | Acer Aspire 4720 Notebook
My laptop Acer asphire displays the symptoms of a stuck key error, but when I removed the key board the same problem occurs. the nuber 5 key still stuck.... but there is no keyboard installed anymore.
Since I see that you are comfortable with your computer I would like to recommend trying two different things. First off try using an external keyboard. See if this stops the error. If that does not then take the computer apart and remove the CMOS battery from the motherboard.
Jun 04, 2010 | Acer NSK8458AN Keyboard
Coke spilled on to the keyboard for my laptop, but i still can turn it on and the mouse will work but the keyboard won't, i took off the keyboard to dry under it and put it back together but keyboard still...
Take it to the closest computer repair shop... And have them clean your laptop... Maybe the coke short circuited something on the board, and now it doesn't work ...
Mar 18, 2009 | Acer TravelMate 270XV Notebook
Spilled coke on my laptop, now keys aren't working correctly.
thank you for choosing Fixya.com
i strongly advice you that don't use your laptop as of now.
the reason why keyboard are malfunctioning is the subtance of coke are go inside your unit and if you will still use it it may caused you a much problem.
you need to look a technician and open your laptop to take or dry any subtances come inside your laptop.
Hopefully you will consider my suggestion.
please don't forget to rate our answers properly.
Feb 22, 2009 | ASUS 90-A4C1K1000 Keyboard
I have a Compaq R4000 and recently spilt coke on the keyboard, the keyboard is now malfunctioning with wrong keys appearing on screen and some not working at all. Im pretty sure I will have to bring it in...
The keyboard is fixable depending on the amount of coke spilted on it and how long it took before removing the coke but it can be fixed. It won't cost nothing much because is just taking out the keys and spraying the board itself so the coke particules be remove throughly. Im sure its least that $40-$50. Depending on the specialist you carry it to.
Get back at me!
KJ
Apr 17, 2008 | Computers & Internet
Spilled Coke...
Yes, it can be replaced.
Its a matter of taking screws out and a small ribbon cable connection
Nov 10, 2007 | Acer Aspire 5100-5033 Notebook
Acer TravelMate 240 Notebook Logo
196 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
