Question about Samsung SyncMaster 931B 19" LCD Monitor
SyncNaster 931B how to clean screen
Take a soft cloth (type used for cleaning glasses) and moisten it with a small amount of water on one corner.
gently wipe the wet portion of the cloth across the screen (if you have any weak alcohol based cleaners you can try it. I have used hand sanitizer before on my 931b w/out problems, I wouldn't use any extremely strong liquid cleaners though).
Use the dry part of the cloth to wipe the area dry, then move to another part of the monitor once you are satisfied.
Posted on Mar 10, 2009
Hello, I took apart my system to move furniture around and to clean. When I reconnected everything, all was well except all white areas on the screen have turned PINK! I tried going thru the...
Hi
This is a problem with a high magnetic field hence you need to de-goz the screen. Or leave it un-used for some time and it will be alright by itself.
Maybe when you were shifting you have kept a speaker with big magnet around the monitor thats why this has happened.
Dont worry it will go bad to normal by itself.
Jul 16, 2011 | Samsung SyncMaster 931B 19" LCD Monitor
931b flashes on &off
You need to open it up and look for caps with bulging tops. Common problem with ALL brand of monitors.
http://s807.photobucket.com/home/budm/allalbums
http://www.axtsystems.com/index.php?option=com_content&view=article&id=83:samsung931bfix&catid=48:fixingstuff&Itemid=81
Please post back what you find so it will help other people also. Use good caps, PANASONIC FM or FC series from DIGIKEY.
Apr 07, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
If computer and samsung 931b monitor have not been used in a couple of hours the screen comes off initially and then shuts back off. I've been resolving this problem by turning the screen off and on...
More likely to be bad caps with bulging top or leaking liquid in the power supply for monitor this age, you need to open it up and inspect the caps first, post back what you see so we can guide you further, see example of faile SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 01, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
Screen blinks on /off - can syncmaster 931b be repaired?
This model was released in 2001, you need to open it up and look for bad caps with bulging top first, the problem can also be in the backlight inverter circuits. Post back what you see so we can guide you further, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 27, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
Cant get size from display settings for external 19" Samsung Sync Master 931B cant see start button everything to large
See if you can pull up the menu on your monitor. If you can reset it to factory defaults.
If you still can't see the screen properly then you need to on your computer. Go into the device manager and make sure its seeing your video card properly. Look underneath display adapters and be sure its seeing something other then standard display vga.
If not then your display adapters are missing so once you install those, the computer will recognize your monitor.
Dec 18, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Samsung 931B Monitor Screen will not stay
jane657, Hi there. Will you stop pushing the On/Off button on your lcd/fpd. It's Broke. Period. End. Finito!!! You will not fix it. However there is one test that you should do to determine hoe bad the problem is. You will need to reconnect the 931B to a known good pc that has been fully booted and has the WIN-DESKTOP or IE fixya web page showing. quickly connect the931B to the wall outlet and the PC. Turn on the monitor!!! Yes, I know it will only come on for a second..After the screen goes to BLACK, Shine a bright flashlight onto the screen at different angles, 1-2 inches from the screen. Let me know if you see something even though the screen is black. Anyway here are your options as a consumer/user. 1. Check if unit is under warranty. 2. Check withh Samsung to see if they have a SWAPOUT program. You send them your monitor+$40-$90 and they return a refurbished same model to you with a 30 day warranty. 3. Trade in for new monitor. 4. Check with local TV/Monitor repair guy who knows all there is to know about cold-cathode-fluorescent-tubes, their power-source(inverter type) and lcd monitor power supplys (SMPS) 5. Repair on your own. Not recommended for amatures with no solid state troubleshooting skills and no instrumentation for support. Bye for now. I'm louie12fix on fixya or lmistyrel@ aim.com
May 14, 2009 | Samsung SyncMaster 931BF LCD Monitor
931B tries to come on but shuts back off
Problem solved by changing 3 capacitors (C112, C113, C316).
Replace the 470uF 25V with a good quality low ESR type and the two 820uF 25V with 1000uF 25V low ESR types.
The 1000uF caps should be 10x20 in size, however I managed to get 13x20 caps in, but it was a bit tight.
Apr 03, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Samsung SyncMaster 931B 19" LCD Monitor Logo
182 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
