Question about Motorola Mobility S305 Bluetooth Headset
Motorola S305 Bluetooth can I pair to iPhone 5?
How do I restore the ability to pair
Go to the Apple Store, they will fix this for you in 5 minutes for no charge.
Mar 31, 2015 | Motorola Radio Communications
I lost pairing to from my moto tx550 bluetooth speakerphone to my iPhone and cannot get it back
Try pairing again.
TX550 Bond Pair
Be sure Bluetootis enable on your iPhone when you search for your tx550.
Mark
Motorola Support
Mar 03, 2015 | Motorola Mobility 89589N - SonicRider...
I need guidance in pairing my apple 4g iphone to my motorola T215 Bluetooth
Ensure your t215 is not connected to another device. Then turn it on and let it start pairing mode. Once on then enable bluetooth on iPhone and search for the t215. It should ask for code. 0000
once paired and connected you can usit to make calls.
Mark
Motorola Support
Jun 22, 2014 | Motorola Mobility T215 Car Hands- Kit -...
Pairing to panasonic
Put your S305 in pairing mode and then have your Panasonic search for the Headset.
https://www.motorola.com/moto_care/manuals/S305_QSG.pdf
Mark
Motorola Support
Jun 12, 2014 | Motorola Mobility S305 Bluetooth Headset
Cannot pair S305 to iPad 2
If you have the headset paired w/ another device, you have to "forget" it on that device and then try to pair w/ the iPad.
I was having the same issue w/ new iPhone 4, but this solved it for me. It is a bit annoying to have to forget and unpair every time you want to switch devices, but oh well.
Apr 02, 2011 | Motorola Mobility S305 Bluetooth Headset
Need instructions for connecting ear piece to iphone 4
Hi,to complete the look of a tech-savvy, iPhone-using individual, you must have a Bluetooth headset to accompany it. You can pair any Bluetooth headset with an iPhone. The Motorola HS850 is no exception to this. Both Motorola and Apple's Bluetooth set-up process is fast, so you'll be talking with people through your new Bluetooth on your iPhone in a matter of minutes.
Instructions
Charge the Motorola HS850 headset fully before attempting to pair. Usually, it takes two to three hours to charge the headset.
Press and hold the "Call" button (has a phone icon on it) on the headset for six to 10 seconds. The outside LED light will turn on indicating that the phone is in pairing mode.
Choose "Settings" on the iPhone homescreen.
Select "General," then "Bluetooth."
Select to turn Bluetooth on.
Wait for the phone to search for in-range devices.
Select theMotorola HS850 from the list of devices.
Enter the headset passkey to complete the pairing. By default this is "0000."
Have a nice day..
Feb 23, 2011 | Motorola Mobility HS850 Consumer Headset
How do I pair my Motorola H12 with my iphone
1)Turn on the bluetooth headset.
2) Turn on bluetooth on your phone. It starts looking for bluetooth devices in the vicinity. Your headset will be detected as "bluetooth headset" or "Motorola H12 Headset".
3)Once its located then select it and follow the onscreen instructions like choosing a passkey etc., to complete the pairing process.
Dec 03, 2009 | Motorola Mobility Motopure H12 Bluetooth...
How di I pair my motorola H720 bluetooth to my ,
On the PHONE
Turning on and pairing a Bluetooth device
To turn on and pair a Bluetooth device, perform the following steps:
1. At the Home screen, press the Menu key.
2. Touch Settings.
3. Touch Wireless controls.
4. Touch Bluetooth to select the check-box and turn on Bluetooth.
5. Touch Bluetooth to select the check-box and turn on Bluetooth.
NOTE: The device searches for Bluetooth devices and display a list under Bluetooth devices.
6. Touch the Bluetooth device that you want to connect to.
7. If required, enter the PIN and touch OK. the Pin/passkey: 0000
On Bluetooth headset
Step A - ENSURE HEADSET IS IN PAIRING
MODE
Power on headset by sliding the Power switch
towards the microphone to initiate easy pairing. After a few moments, the indicator
light will be steadily lit in blue to indicate headset is in pairing mode.
Select OK.
Oct 25, 2009 | Apple iPhone 3G
How to pair Motorola H12 with iphone?
I just figured it out myself!!
here is how:
1.) press your home screen button at the bottom of your iphone
2.) open settings
3.) go into your general settings (same gear picture as home page)
4.) touch to open bluetooth
5.) turn on your H12 headset and place close to your iphone
6.) turn on bluethooth on iphone and it will automatically find the headset
7.) touch the motorola H12 button and it will enable the connection
Jan 08, 2009 | Motorola Mobility Motopure H12 Bluetooth...
Motorola Mobility S305 Bluetooth Headset Logo
150 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
