I have a Pioneer Cassette Changer that has out of place some tiny parts and by this the transpont doesn't pick up any cassette but it, the thansport, moves like it should. Do you know how can I di
  • Fernando Silva Dec 08, 2012
    Thanks for your 3 answers, but I think I have not explined well the situstion. These decks have a "way" thru the cassettes go to the play/record section and is this path that doesn't pick up the cassettes properly because one section in it is out of place and this is why the cassettes are not transported in this path. I hope now you friens have understood my problem. Thanks!!
  • Audio Player... Master
  • 1,267 Answers
Changers are notorious items to have failure- that is why most Technicians have high end single well decks. There is no secret way to fix changers. You need to get the service manual to know where and how the parts go into the unit and then get into the transport of the unit to restore that parts into position. In my experience with plastic part changers, they do not stay in the correct shape and parts work out of reference which result in jam ups and further problems down the way. Most of my work was done in CD changers but I did a few cassette changers and they are all disasters designs.
Posted on Dec 10, 2012
5 Suggested Answers
  • 319 Answers
SOURCE: pioneer multi cassette changer info
Place tape to be recorded from in deck w/out button. Place tape to be recorded in other. Make sure anti record taps are intact on both cassettes. Press "record".
Posted on Apr 25, 2008
caroldon
  • 17130 Answers
SOURCE: cassette deck plays without cassette, makes clicking noise
The fault is that the reel drive of the deck is not picking up the tape and so to avoid the tape to entangle it rejects. Try to load a different cassete and see it this loads. If not you have a bad belt in your set. you will need to remove and change the belt. Also check for the reel drive to see if there is any slackness in taking up the reel. Since there are reel sensors that act when the reel pulse does not come on rotation of the reel, the set shifts to the other side and then ejects. Open and check this out and I am sure you can sort this out. Good day
Posted on Jul 20, 2010
SOURCE: Sony TC-K690 3Head Cassette Deck - no playback
It needs a new rubber belt for the mechanism control.
It is a smallest of th 3 rubber belts.
Posted on Jan 25, 2011
  • 65 Answers
SOURCE: RE:JVC CASSETTE DECK MODEL #
it sounds like your tape heads are worn they will strip your cassettes every time and give you very poor sound reproduction it can be repaired but costly to be honest you would be better off with a new deck and it will be cheaper all round.
Posted on May 24, 2011
I have a Memorex 9200M am/fm stereo ,double cassette turntable and 3 cd changer and it will no turn on, I've only used it 8 or 9 times. How or can I fix it ?
If you bought this new, I strongly suggest taking it back. There are no servicable parts inside and taking it apart will void warranty
Mar 04, 2012 | Memorex Televison & Video
Paper feed results in a clicking and no feed
This sounds as if the paper pick up assembly is not lifting the paper-up to meet the rollers. This is like a ratcheting sound when lifting. When the paper gets high enough it hits a sensor arm and the copier will indicate paper in the cassette. If it doesn't lift it will quit but will never indicate paper in cassette. Does the other paper cassette feed? I know I've had to replace the paper pick-up assembly before because of this problem and is very expensive. Good luck.
Sep 27, 2011 | Canon imageRUNNER 210S Copier
I've just fitted a second-hand replacement cd changer in my car, but the cartridge will not eject from the cassette. Any ideas?.
There is an easy fix for this. The rootcause is most likely related to your disc tray (crooked carrier or broken spring). Just get a small screwdriver and take out the two black srews of the inner faceplate, covering the cassette tray itself. Please make sure you do not drop those tiny screws. Use a magnetic tip screw driver. Take the faceplate off. You will see a litlle lever in the center. Just push it aside and your cassette will pop out with no problem. Thanks
Feb 17, 2011 | Philips CDC775 5-Disc CD Changer
Cassette adapter and MP3 not working
Usually a dirty tape head. I recommend adding a 3.5 jack to your radio through an fm modulator.
Apr 24, 2009 | Sanyo FXCD-500 RB CD/Cassette Receiver...
Clarion 6 cd changer cassette will not eject
Don't waste your money and buy those repair manuals. There is an easy fix for this. The rootcause is most likely related to your disc tray (crooked carrier or broken spring). Just get a small screwdriver and take out the two black srews of the inner faceplate, covering the cassette tray itself. Please make sure you do not drop those tiny screws. Use a magnetic tip screw driver. Take the faceplate off. You will see a litlle lever in the center. Just push it aside and your cassette will pop out with no problem. That simple. So don't waste your money!!!
Mar 28, 2009 | Clarion DCZ625 6-Disc CD Changer
Pioneer multi cassette changer CT M6R
I have had this same problem too. I fixed it by taking the tape transport out of it and removing both capstans with their flywheels and oiling the capstans. However this only fixed the problem for a few months. Maybe you need to more a most soild oil since i used just regular motor oil.
Oct 17, 2008 | Pioneer DEH-1600 CD Player
Pioneer multi cassette changer info
Jan 31, 2008 | Audio Players & Recorders
No rca jacks
these are designed to hook to a head unit from Pioneer. There are many units that will work if they have a P as part of the unit number. There are some with some cassette units, some with CD units, some with other connections.
Dec 27, 2007 | Pioneer 12DISC CHANGER
46 people viewed this question
 Grubhead
Grubhead
