Question about Wasp WLS 9000
Set carriage return in wasp 9000 barcode scanner
3 Suggested Answers
Corster
  • 79 Answers
SOURCE: problem with scanner
Yeah, from the manual, scan the following settings:
Scan Suffix
7
0
0
9
Scan Options
<DATA> <SUFFIX>
Enter
It's best to copy the necessary barcodes from the manual at 200% zoom, into a Word document and print it out.
Posted on Jan 03, 2008
pan_stak
  • 182 Answers
SOURCE: Hello, I have charged the
Perhaps the battery has moved (due to a shock of the device) and is not connected (as it should be in the device).
Open the device and check that the battery is connected properly.
Then try to recharge.
Also, it's a good idea to remove the battery and test (with a voltometer) that it has some voltage.
Finally, if the battery was used for a long time or charged too often (without the battery being fully decharged), you might have to replace it.
If I were you, I would replace it with a stronger battery. according to specs, WWS500 have a 700mA battery, I would put a 100mA battery instead.
Posted on Aug 01, 2011
How do I get my scanner to go to the next line/box when using Excel?
In your programming manual there is a barcode scan that needs to be scanned in that adds the carriage return function. To do this you will first need to scan the barcode to put the unit into program mode, then scan the carriage return barcode, then scan the end programming code. Now when you scan a barcode the scanner will add the return to the sequence it sends to the computer. If you can't find your programming book you can download the sheets from the Symbol web site.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 14, 2010 | Symbol LS2208 Handheld
LS4004 Scanner displaying 2 random digits on scan?
Hello coreyog. I think I can help you with at least part of this. The "suffixing with an enter" you're describing is called a Carriage Return. If you go to your manual, you'll be able to find the Carriage Return enable and disable barcodes. Disabling the Carriage Return should fix that part at least.
As far as the digits not found in the barcode, there are about a thousand and one reasons it could be doing this. Generally, I suggest to my clients that they use the manual to reset the defaults of the scanner while plugged in to the problematic machine, after resetting, unplug the scanner and plug it back in. This should get windows to re-discover the device, as it were. This takes care of it about 75% of the time. I hope I've at least helped you get a start on fixing your scanner foibles. Good luck!
Jan 06, 2010 | Symbol LS 4004i
Manual carriage return necessary after scanning barcode
With the Symbol scanners, they usually come with a sheet at least of scan codes to configure the scanner. One of those bar codes will have the option of not needing to manually hit the carriage return. What model scanners are they? You can probably find the codes from Symbol.
Sep 17, 2009 | Symbol LS 2208 Barcode Scanner
I have lost my installation disk for my printer. How can I install my printer on my new computer with out it SCANER
Hi
Please try to download the printer and utility software from the site of your printer then install it
Thanks
Boopathy.t
Aug 23, 2008 | Computers & Internet
Beep Setting
On the left, at the rear of the scanner, there are three holes.
Place your finger...!
Print this message and scan one of the following barcodes:
Dec 05, 2007 | Wasp WWS800 Handheld
Problem with scanner
Scan Suffix
7
0
0
9
Scan Options
<DATA> <SUFFIX>
Enter
Feb 07, 2007 | Wasp WWS800 Handheld
Wasp WLS 9000 Logo
211 people viewed this question
Top Wasp Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Jude24
Andrew Taylor
Andrew Taylor
Are you a Wasp Computer and Internet Expert? Answer questions, earn points and help others
