Question about Polaroid TBX-2000AF 20 in. TV/VCR/DVD Combo
Remote control (1) I can't figure out how to change the batteries in the remote. The manual does not have pictures, I've unscrewed the back but nothing moves or opens. (2) I would like to program a universal remote for this TV but can't find a three digit code.
  • zakbak Sep 02, 2008
    i have the same problem.what do i do
    New Friend:
  • 129 Answers
You can open it the battery compartment its on the back at the bottom just puul it out making pressure on the arrow marks. the original remote cost its 29.00 at partstore and the part # is 8201803680L just incase you need to order a new one
Posted on Jun 10, 2007
  • Luis Amado Jun 12, 2007
    did you try . need more help let me know
How to remove battery digital picture frame
How to replace the battery in the remote control:
1. Hold the remote control with the buttons facing down.
2. Push and hold the small release tab while pulling the battery tray out.
3. Replace the "CR2025" Lithium battery on the tray with the positive (+) side facing up.
4. Push the tray back in until it clicks into place.
You can download the manual here:
http://www.robholland.com/blog/wp-content/uploads/2011/01/User-Guide-for-Pandigital-PAN7000DW.pdf
May 03, 2014 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Remotes suddenly stop working #85095-01, and FCC ID IN2TX13
1) clean the contacts batteries, with cleaner contacts
2) tight the spring contacts with pliers for better contacts
3) resolder the wires connector from contacts batteries
4) open the remote c, and clean the keypads with contacts cleaner
God bless you
Jul 02, 2012 | Hunter 27185 Remote Control
Hi My matsui tv 1409T remote died (due to battery leakage!) so I have got a signalex universal remote as a quick fix replacement. I have set the remote to switch the tv on/off, change channel and adjust...
1) Change the batteries by alkalines
2) Retight the springs contacts with plyer for better contacts.
3) clean the contacts with special spray contacts.
4) Downloa the code or proceed with your instruction manual.
5) If the problem persist, you must return you remote control and buy other from Radio Shack I am recommending.
God bless you
May 14, 2012 | Televison & Video
My Sony RM V301 remote control code for my panasonic tv/vcr combo isn't working i've tried 018, 016, 017, 007, 049, 067 are there any others?
go www.fitness.manualsonline.com or www.remotecodelist.com
and follow the instruction manual procedure
1) tight the spring contacts with pliers
2) clean the batteries contacts
3) change new batteries
4) Resolder wires contact batteries and proof again. Otherwise you must go to repair shop
God bless you
May 10, 2012 | Sony (RM-V301) Remote Control
I can't figure how to change the battery on this hardcase lantern took off the rubber surrounding the lantern face, but nothing else seems to come off without unscrewing, But seems like those sre rivits...
I've owned this flashlight for years. In the comment above, ignore the instruction to remove the rubber casing around the lamp area. Simply grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
Apr 05, 2011 | Energizer Eveready TUF4D1E 4D Cell Lantern
Hello. the particular setup we are dealing with is
Hi Guest, I can definitely help you with that, however if the screen is snowy we won't know if it's working until we get a picture.
To do that try changing TV2 to channel 60 and 73. If it only goes up to 69 put it on 60, if it goes to 73 then good. If still snowy, then go down to the main television and follow these steps. Menu -> System Setup(6) -> Installation(1) -> Modulator Setup(5). Go to TV 2 Out and change mode to Air if you put the TV2 on 60 and Cable if it's on 73 and select Done to save.Check the second TV for picture, and if it's still not showing then check cabling.
Once you have a picture back the remote should be working with it, if not feel free to post here!
Tommy Faust
DISH Network
Jun 19, 2010 | DISH Network IR Remote Control
Remote control for Smart Parts 11" digital frame (SKU SP11008) doesn't work. Have changed battery, but cannot get any type of connection between remote and frame. Received as gift over a year ago, but did...
We have to check the remote control first. After that check the digital picture frame.
Follow the instructions below please;
We must be sure the remote control is working;For this control:
1. Take a digital photo of this remote control while pressing the remote control button.
2. If it is working then the picture must shows the led lamp of remote control as firing.
3. If the picture does not show that it is firing, then, you should control batteries of the remote control.
4.Check the battery and the battery polarity of the remote control.
5.If it is firing. You should control Digital Picture Frame.
6. If the battery of the digital picture frame does have enough energy or not. If battery is low then you shoud use it from the closer distance.
7. I do not think that the Digital Picture Frame is out of order.
Regards.
Apr 21, 2010 | Smart Parts Digital Picture Frame
Replace battery on Nikon ml-l3 remote
On the back - area marked "batt" - place finger nail in groove and push section 1 to the right side at the same time that you pull out section two - use two fingers and it will glide out.
Jun 13, 2009 | Nikon ML-L3 Remote Control
My DVD playes only shows in black and white
Grab the manual and the remote, my guess here is you have accidentally changed regional setting, depending on where you live.
Some remote controls have a button, it's simply a matter of identifying the said button and pressing it again to change your regional setting back to it's original.
Jan 12, 2008 | Classic Electronics Classic DVD42S...
Open Questions:
See all Polaroid TBX-2000AF 20 in. TV/VCR/DVD Combo Questions
Polaroid TBX-2000AF 20 in. TV/VCR/DVD Combo Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
